Building Tips and technical articles. => Building techniques => Topic started by: James Mills on July 07, 2011, 09:04:54 PM
I'm thinking of building a Caprice for classic, I have the wing from Bob. I'd like to try a take a part structure for the first time. I want to leave the wing in one piece. What is a good way to do this (and if you have pictures that would be a big help)?
James
I'll PM ya my pics (not of a Caprice) but an easy way to do one wing take apart
Thanks Wynn. I've wanted to try this for some time but have been apprehensive to go after it.
James
Wynn, could you send me the pictures also. Cars are getting smaller and planes are getting bigger.
Or, email will work - garympampa@aol.com
on their way Gary
I would like to see the pictures also.
RSM's plan of the Thundergazer would be a good method to use.
Keeping the wing one piece is the best way to go. THe RC guys have been doing this since, like, forever. There are a plenty of strong secure ways to accomplish it. Back in the 70's I converted a Sterling Scale P-63 RC kit to CL and used the take apart feature of the plane with small modifications to make it CL compatible. It was solid as a rock, at least until I packed it in by doing one too many loops. I wonder if any of the guys at Flusing Meadow Park remember that one. By doing too many loops I don't mean the wing joint failed. It was a three line setup and the lines got bound up after the 5th or so consecutive loop.
Or just take a look at the Flying Models Impact plans. That's how Paul did the original Impact.
Yeah, 2 x 1/4" wood dowels in front and 1 or 2 nylon bolts at t.e. must be the best way to go, if most of rc planes use that system.
1000000 flies can't be wrong.. L
The Caprice has a pretty slender fuselage. I would suggest a 2-piece wing as a better plot. y1 Steve
While I like the idea, the Caprice will fit in the average hatch back. That airplane has excellent penetration but I would watch the weight on a take apart. .02 cents
My Question would be why make it TA?
For the recent US Nats - Dad took over the Pitbull which is essentially a Nobler sized wing, it was TA build per the Walker system.
Watch the weight. Its not as critical on a 64 oz ship.. but 45 oz..
There are a few reasons why. I want to see if I can build one successfully before I try it on a full blown PA plane. My 9 year old is flying so room in the trunk of the car is at a premium so a take a part would make packing easier. Plus I thought making a muffled plane a take a part would be a bit easier than a pipe set up (having to work around the pipe tunnel).
James
Post some pictures of your take apart planes as I also need to build one. I want a one piece wing. Mustange convertibles don't have a lot of room inside. My SUV is long on miles and has 411 gears so it is not a great highway driver.
