  • June 19, 2025, 10:20:29 PM
Author Topic: Swaging Tool  (Read 1018 times)
Online Dick Pacini
Swaging Tool
« on: May 05, 2012, 10:02:46 AM »
I have read a great deal about Carl Shoup's swaging tool.  I have sent an email to Carl but have not heard back yet.
Can anyone post a photo of what this tool looks like?
Thanks in advance.
AMA 62221
Offline L0U CRANE
Re: Swaging Tool
« Reply #1 on: May 08, 2012, 11:23:48 AM »
Dick,
A word picture might be enough...
Six inch long, high quality* slim needlenose pliers, spring opened. A  finely machined drill hole, half in each jaw, located just the jaw side of the hinge. Ends of the hole are slightly and smoothly radiused.
Carl stresses that it takes numerous squeezes, with the "barrel" rotated slightly between each so you don't form a flat, or flat sided crimp. Easy to do a smooth, round-section crimped barrel of aluminum or copper tube, with a tiny, slightly raised 'rim' at each end. Part of the prep is to 'flare' the tube to remove interior burrs and create a slight radius. For Aluminum or copper, a twirl of a #11 blade does fine.
*- The hinge must be good enough to stay tightly aligned.
\BEST\LOU
Offline L0U CRANE
Re: Swaging Tool
« Reply #2 on: May 08, 2012, 05:16:24 PM »
Dick,
I managed to get a shot of my set of Carl's pliers. Hope it fits in here.
\BEST\LOU
Re: Swaging Tool
« Reply #3 on: May 09, 2012, 08:34:46 AM »
 He also makes two sizes.   The smaller one is for doing lines. H^^
