  • July 06, 2025, 06:31:27 AM
Author Topic: Super Combat Streak Scratch Build  (Read 7508 times)
Offline Jerry Reider
« on: October 15, 2009, 12:28:18 AM »
I am building a Top Flite Super Combat Streak from scratch.  I bought the kit at an auction a couple of years ago.  Now that I want to build one I decided to photocopy the part sheets and build one from scratch rather than building the kit itself.  (couldn't bring myself to wrecking such a nice old kit) I duplicated the formed leading edge by planing a 30 degree angle on two pieces of 1" x 3/8" and gluing them together with a piece of 1/8" x3/8" between them in a 60 degree jig that I made.
My question is how do I get the 1/16" cuts to locate the ribs in the leading and trailing edges square and evenly spaced.  I found that by bolting two 24p hacksaw blades together that they mic 1/16".  I've had some ideas but nothing that really falls under the KISS method (Keep It Simple Stupid).  Some sort of simple 90 deg. adjustable width mitre is where I'm thinking I need to be.  It would be nice to be able to use the same tool for both the LE and TE.
« Last Edit: October 18, 2009, 10:54:05 AM by Jerry Reider »
Jerry
Re: Rib Spacing?
« Reply #1 on: October 15, 2009, 12:33:02 AM »
I couldn't fit the pic of my gluing fixture on the first post so here it is.  Looks crude but it gave me a nice straight LE.  I was fortunate enough to have some real straight 1x2's in stock.
« Last Edit: October 18, 2009, 10:57:25 AM by Jerry Reider »
Jerry
Offline Russell Shaffer
Re: Rib Spacing?
« Reply #2 on: October 15, 2009, 08:55:48 AM »
How about a cheap plastic miter box, the kind intended for use with a regular hand saw?  I think the saw blades will work best if you turn them to cut on the pull stroke.
Russell Shaffer
Klamath Falls, Oregon
Offline Bill Adair
  • AMA 182626
Re: Rib Spacing?
« Reply #3 on: October 15, 2009, 02:49:16 PM »
I've never tried cutting the slots myself, but thought about using my Dremel table saw. A better quality table saw would probably work much better, but I don't have one.
Select a fine tooth blade the width of the rib slots, and adjust the blade height for the rib slot depth you want. A fine Dado blade might give you a more precise slot width.
Clamp a piece of music wire exactly parallel to the blade, and use that as a guide for cutting the slots. It should be placed at exactly one rib space from the blade. Slide in the table miter guide, and adjust for a true 90 angle.
Lay the LE/TE piece flat against the miter guide, with one end just touching the music wire guide at one end. Now slide the miter guide and LE/TE stock slowly over the table saw blade to cut the first slot.
For each subsequent slot, index the previous slot onto the music wire guide, and cut the next slot. If done correctly, you should have perfect rib spacing between slots, and from the outside slot to the end of the LE/TE piece.
Then let me know if it works, so I can try it.  LL~
Re: Rib Spacing?
« Reply #4 on: October 15, 2009, 03:43:14 PM »
Excellent idea Bill.  That would have to make a perfect job al the way around.  Now, if only I would not have traded my table saw for a snowblower last year.  I have to cut the ribs and other parts out yet so I have some more time to mull this proceedure over.  Thanks for the input.  Worst case I'll put pencil lines on the LE and TE from a square and just eyeball it.  I'm pretty good at doing stuff like that.  This is my first scratch build so I'm learning as I go.http://
Jerry
Re: Rib Spacing?
« Reply #5 on: October 15, 2009, 11:09:35 PM »
I made a rib template out of .025 hard aluminum.  I have the first rib cut out and I used the square and two hacksaw blades bolted together method.  I think this will work out okay.  I can lay the main spar in the "V" of the LE when I cut and it marks the spar for location.  Since the back of the LE is angled I am only cutting up to the edge of the surface that will be on the outside surface of the wing.  I'm thinking as I type here, I can use my 12" square as a guide for the saw on the rest of the cuts.  I'll just hold the square against the LE while I start the cut.  If the rest of the ribs and cuts get as nice as the first one did it will all work out.
Jerry
Offline minnesotamodeler
  • Me and my Chief Engineer
    • Minnesotamodeler
Re: Rib Spacing?
« Reply #6 on: October 15, 2009, 11:52:32 PM »
HOW OLD is that wood you're using?  "Testors, 1/16x3x36, 16 cents"!?!?!
Nice job on the ribs/LE, by the way.
--Ray
AMA902472
Re: Rib Spacing?
« Reply #7 on: October 16, 2009, 01:11:46 AM »
Thanks.  How old is that wood?  Who knows.  I cut a few ribs out of that sheet and couldn't resist getting it in the picture.  It must have come from a box lot of balsa that I bought.  I also came across a piece of SIG balsa 3/32 x3 that is stamped 18 cents.  Actually, I bought a fair amount of balsa for this project from the hobby shop that is NEW.
« Last Edit: October 16, 2009, 09:02:03 PM by Jerry Reider »
Jerry
Re: Rib Spacing?
« Reply #8 on: October 17, 2009, 06:12:50 PM »
I'm philosophically opposed to cutting notches in LE's, TE's and Spars. It makes a stress riser where you don't want one. Don't do that!  H^^ Steve
Re: Rib Spacing?
« Reply #9 on: October 18, 2009, 10:47:42 AM »
Steve, thanks for the advice.  I had already made the ribs with the intention of cutting slots in the LE, TE, and spars so I had to continue on that method.  I had also cut some of the slots in the LE.   Had I read your post sooner I would have went without the slots.
I have the wing glued together.  It is real straight and all the rib to LE, TE and spar transitions are real nice.  It actually came out as good as or better than any kit wing I've ever built.  I built the wing by beginning with the TE pinned down to my bench and I figured I needed a 1/2" riser under the bottom spar to locate the TE on centerline of the ribs.  I tacked the ribs to the TE with thin CA and then removed the pins from the TE and pinned the bottom spar to the bench.  I moved the 1/2" balsa blocks to the TE and tacked the LE with thin CA.  Next I tacked bottom spar and then while it was still pinned I tacked the top spar.  I've removed the wing from the bench and now I have to finish glue it.  I'll use Sigment to do that.  It just seems that it would not be possible to glue the inside of the formed LE while pinned to the bench.
« Last Edit: November 03, 2009, 10:07:57 PM by Jerry Reider »
Jerry
Offline Bill Adair
  • AMA 182626
Re: Super Combat Streak Scratch Build
« Reply #10 on: October 18, 2009, 01:01:15 PM »
Hi Jerry,
Your wing is looking good!  H^^
I have to agree with Steve that slotting spars will weaken them.
You can't replace the slotted spars now, but I would bridge the corners between spars and ribs, with a very thin fillet of Sigment (since that is the adhesive you said you are using). The cement will transfer a tiny bit of the tension load from spar to rib, and rib to spar, around the existing joints and slots in the spars.
« Reply #11 on: October 18, 2009, 09:40:46 PM »
Got it.  The stress risers are "break here" points.  All ribs are Sigment glued at the LE, TE and spars.
Jerry
« Reply #12 on: October 19, 2009, 05:40:03 AM »
You have developed a great technique for copying the machined LE and TE as formerly provided by Top Flite. It sure beats buying a huge slab of balsa and machining it into 60-70% shavings and sawdust.
The notches provide in kits are for rookie builders and as stated many times, just weaken the final product.  Experienced buildings can measure and use drafting/carpenters triangles and table top fixtures to align the wing without notches.  Many Goldberg Voodoos were scratch-built with the readily-available LE and virtually nobody notched them.
« Reply #13 on: October 23, 2009, 09:21:11 PM »
Does anyone know off hand which tank to use the Super Combat Streak?  Plans call for a Veco T-21-C which I'm guessing is out of production.  I have a Brodak BH-597 that I can change the position of the fuel feed that will fit length and width but it is a 1/4" too high.  I'm thinking of using it and doing some sort of blend with the top of the fuse. It's 3 1/2oz
Jerry
« Reply #14 on: October 23, 2009, 09:50:17 PM »
What engine are you planning? Nice and sedate or fast and mean?  Please keep the pictures coming - I want to build one of these some day.
Russell Shaffer
« Reply #15 on: October 24, 2009, 08:12:16 AM »
Russell, I'm leaning towards fast and mean.  I like to fly fast.  I've had 2 regular Flite Streaks, one had an OS Max-s 35 and the other had an Enya 29 IVB (really powerful), they were fast and fun.  I feel fast is the way to go with a FS.  I'm not sure what I'm putting on this yet.  I have a Fox 35, GMS 25 or an Enya 35 available.  I have some other builds in mind for the winter and I'm not sure what engine is going where.  The GMS 25 makes .85hp, pretty much the equivalent of a 35.  I'll keep the pics coming.  I'm working on the fuse right now, mulling over my fuel tank options.  I haven't found quite what I want to put in.  I like a 4oz. tank but the availabe space is only 3"L x 2"w x 1 1/8".
« Last Edit: October 30, 2009, 08:09:45 PM by Jerry Reider »
Jerry
« Reply #16 on: October 24, 2009, 09:47:13 AM »
Since people have been saying that square tanks work fine, I built one to completely fill the 2 5/8 X3 X 1 space in my new Box Car Chief.  You gain some capacity by not using a wedge.
Russell Shaffer
« Reply #17 on: October 24, 2009, 09:39:12 PM »
I looked through my Brodak catalog and found that tank #BH-539 will fit.  It is a 3oz. Wide Wedge Standard Vent 1"h x 2"w x3"L.  I would rather have at least a 3 1/2oz. but that tank is #BH-597 1 7/16" x 2"w x 2 5/8"L Deep Wedge but that doesn't quite fit.  I could make the fuse a bit taller in the front and taper to blend.  I would also have to move the fuel feed line coming out of the tank.  I'm not sure that it's worth the trouble for an extra 1/2oz.
Jerry
Offline Bill Adair
  • AMA 182626
« Reply #18 on: October 24, 2009, 10:04:55 PM »
Jerry,
Brodak makes a med wedge Uniflow tank with the tubes out the top and side, so they don't protrude past the front of the tank. I had to use that style on my built Skyray 35, as standard tanks with tubes out the front would not fit.
They don't have a picture that shows the exact tank I have, but look on their web site to see wide wedge Uniflo tanks to get an idea.
« Reply #19 on: October 26, 2009, 09:32:05 PM »
An update on the progress.  The wing is all finish glued and it stayed straight.  I just dry fit it to the fuse to check the fit to the fuse since the halves are glued together.  Wing cutout in the fuse couldn't be any smaller, it just clears the ribs, LE and TE.  Also did the Z bend on the pushrod and needed to check the exit for the hole in the center sheeting.  Looks like I can have a straight pushrod.  The plans show a rather extreme bend to get the pushrod high enough to meet the control horn.  I wanted to avoid that because it looked like a flex point.   I used 3/32" music wire.  Bellcrank platform is ready for epoxy as soon as I attach the leadouts to the bellcrank.  I'll wait until later to put the wingtips on.  They always seem prone to getting damaged from sliding the wing in the fuselage.  I haven't spent as much time building as I would have liked to lately.  I've been busy with nonsense like work and getting the house and cars ready for winter.
Jerry
« Reply #20 on: October 26, 2009, 09:40:23 PM »
That's really looking great, Jerry.  ;D
I had a Super Combat Steak back in about 1973.  I used a Fox 35 on it and it was a great flying model.  I liked it better than the profile version!  Only complaint was the lack of tank space.......
Mongo
« Reply #21 on: October 28, 2009, 04:11:39 PM »
I have one of the kits sitting on the shelf and have considered throwing it together just for fun.  Have to remember most combat matches in the day seldom went over 3 minutes if they  went that far.  The construction is really fabulous in how you are reproducing the leading/trailing edges.  Have fun,  DOC Holliday
« Reply #22 on: October 30, 2009, 08:13:35 PM »
Thanks for the replies and compliments guys.  As far as the fuel tank goes, I ended up using a Brodak BH-539 Standard Vent Wide Wedge Fuel Tank 3 oz.  It is shown to have the dimensions of 1"h x 2"w 3"long in the catalog.  Since shipping was $7.99 for just the tank I decided to also order a clear canopy 9" x 1 3/4"w x 1 1/2"h and a 1/12 scale pilot as well.  Still $7.99 for shipping.  Of course the tank I received was 3 1/16" long.  I had to sweat the end off and cut the body of the tank since I had exactly 3" of space available to fit the tank into.  It worked out nicely, pressure tested, no leaks, exact fit into the space.  Landing gear is the next engineering project.  I don't like the one wheel landing gear set up the SCStreak has so I'm going with 2 wheels in the front and a 3/4" dia. or so tail wheel.  I have some ideas for the front landing gear.
« Last Edit: November 01, 2009, 08:24:14 PM by Jerry Reider »
Jerry
Offline Ward Van Duzer
« Reply #23 on: November 02, 2009, 08:12:59 AM »
I hope I'm not looking at a PERFECT BellCrank! They are way too soft and the holes will elongate in no time flat. Fox (aluminum) bellcranks and the old Veco's are OK. Brodak or Sig OK too.
W.
« Reply #24 on: November 02, 2009, 08:18:38 AM »
W.
Thanks Ward.  It is a Veco bellcrank.  Thanks for the reply.  I had heard that before about the Perfect bell cranks but hearing it a second time is good.  I'll remember that for sure this time.
Jerry
« Reply #25 on: November 02, 2009, 08:43:59 AM »
I'm ready to plank the top and bottom of the fuselage.  The grain on the sides of the fuse run longitudal but Top Flite plans shows grain on the top and bottom going crosswise.  Plans show 2" pieces with grain running side to side.  Will it matter if I cut one piece each for the top and bottom that goes front to rear.  I'm just wondering if the crosswise grain is critical to the strength of the fuselage.  I think it will make a much nicer job with the long pieces.
« Last Edit: November 02, 2009, 09:05:47 AM by Jerry Reider »
Jerry
« Reply #26 on: November 02, 2009, 01:27:27 PM »
I alway ran the grain across the fuse of the bottom of typical planes.  On the "Sweet Sweep" the grain runs length wise and seems to be just as strong.  Also crossed grain uses less material.
« Reply #27 on: November 02, 2009, 07:56:35 PM »
Thanks John.  I've already cut the top planking but I checked and I can use it to plank the bottom.  I'm going to plank the top with the grain running lengthwise.  It will make a much nicer job.  I'm waiting for glue to dry on the risers for the tank and I should have the top and bottom planked yet tonight.
Also, being the type of person who doesn't like to work any harder than I have to, I found a good way to cut plywood up to 1/8".  I use a Wiss tin snips.  It also works great for thin balsa.  I haven't tried it on anything thicker than 1/8".  Maybe it works for the thicker stuff.  Surprisingly it makes a very clean cut without crushing the wood.  I've also used a scissors for thin balsa.
Jerry
« Reply #28 on: November 04, 2009, 02:48:43 PM »
I forgot, I had to install the landing gear before the planking.  I don't like the one wheel landing gear that the SCS is supposed to have so I came up with a way to use a 3 wheel landing gear set up.  Here's some pics of the landing gear.  I epoxied a doubler behind the F2 bulkhead so the screws in the landing gear lugs would have some extra bite.  The screw and washer at the "V" of the main gear is mostly for a place for epoxy.  The "anchor" for the tailwheel wire is 1/4" thick pine.  The pine wedge got too narrow in the back but that worked to my advantage because that allowed me to position the wheel before I epoxied it, to the correct alignment.  Before I epoxied the tailwheel assembly to the fuselage, I cut a piece of 1/16" balsa to match the taper between the rear halves of the fuselage.  With the fuselage upside down, I then put the balsa in place between the fuselage halves, while pinching the rear of the fuselage to hold the balsa in place and I set the tailwheel assembly on top of it to adjust the pine wedge to be flush with the bottom of the fuselage.  I then removed the tailwheel assembly and C/A'd balsa to the fuselage.  That gave me a platform to locate the tailwheel while the epoxy dried.  I didn't have to clamp anything.  I hope that makes sense.  It worked great.  In essense I made a "cement form" to lay the tailwheel assembly in and locate it while the epoxy dried.
« Last Edit: November 05, 2009, 09:12:17 AM by Jerry Reider »
Jerry
« Reply #29 on: November 09, 2009, 10:13:27 AM »
Here's how I installed the wing tip weight.  It is a wheel weight.  I pushed a toothpick through the tip formers and coated the weight and toothpick with epoxy then while it was wet I put a piece of balsa along the top between the formers and I put epoxy on that too.
Jerry
« Reply #30 on: November 14, 2009, 07:03:17 PM »
I haven't posted the progress in a while.  I monokoted all the pieces first, then I assembled it.  I've never done that before, it worked out nicely.  I'll post this picture then it's off to the hangar to install the engine, hook up the control rod to the control horn, finish the monokote around the engine bay and maybe install the pilot and canopy.  I'll fly it tomorrow whether the pilot and canopy are installed or not.  I'm going to put my Enya 29IV on it for right now.  I bench ran my Enya 35 and I think it needs some more bench time before putting it on a plane.  They have the same mounting holes so it will be an easy swap.
Jerry
« Reply #31 on: November 16, 2009, 12:40:02 AM »
Well I got the SCS to the flying field today minus the pilot and canopy.  Couldn't wait to fly it.  Filled the tank, and no fuel would come through the feed tube.  I put my filler bottle on the feed line, and tried to push fuel through it, totally blocked.  It must have closed with solder when I soldered the back of the tank on.  WHAT A LET DOWN.  I was ready to wrap upmy lines and go home.  A friend said hook up another plane and take a flight.  I took the old faithful (too ugly to die) Shoestring up and all was fine.  Great flying day anyhow.
Jerry
« Reply #32 on: November 16, 2009, 12:41:28 AM »
Here's part of the fleet.  Couldn't fit it on the last post.
Jerry
« Reply #33 on: November 18, 2009, 12:58:48 PM »
That Streak turned out really well.  I may just have to do one.  What is the bipe?
Russell Shaffer
« Reply #34 on: November 18, 2009, 02:39:29 PM »
Thanks.  The SCS was a fairly easy build from scratch.  I made the parts accurately and from there it was pretty much assembly just like a kit build.  I put the pilot and canopy on it last night.  I had bought a 1/12th scale Sport Pilot and a Sig Clear Canopy 2" wide x 1-3/4" high x 9" long from Brodak.  I was unsure if I was going to install the pilot and canopy, but it just looked unfinished without it so I put it on.  The dash and seat back are just a 1/16th former planked with 1/32" balsa.
The bipe is a Brodak 38 Special.  I have an OS Max-s 35 on it.  Great flying plane.  It's advertised as being able to do the whole AMA pattern, I'd have to learn it before I could do it.  If I was good enough to do the AMA pattern I'm sure it would.  I've never tried doing the AMA pattern.  It flys as well as a plane with ailerons in my opinion and is an easy build.  One guy in our club has a 38 Special with an OS FP 40 and it is really fast and still a very good flier.
« Last Edit: November 20, 2009, 02:35:56 AM by Jerry Reider »
Jerry
« Reply #35 on: November 18, 2009, 06:52:05 PM »
The canopy and pilot really finish it.  Great job.
Russell Shaffer
« Reply #36 on: November 20, 2009, 10:14:32 AM »
Jerry, seeing the 38 Special is great.  It looks a lot better than mine.  The plane will do the full pattern.  Now seeing that great looking SCS I may have to build one of the kits I have.  That canopy does wonders for the plane.
Offline dennis lipsett
« Reply #37 on: November 20, 2009, 11:59:24 AM »
Jerry, the other guys 38 special has a Fox 40 on it. In fact it's a 1980 Fox 40 and was timed a little more aggressively then the current versions. Good for about 90MPH and a good adrenaline pump to make sure your still alive. I enjoy flying it and it seems to have some appeal when all of the maneuvers look like you were completely in control.. The things that we do for kicks.
Dennis
« Reply #38 on: November 20, 2009, 01:43:26 PM »
Dennis
Dennis... a FOX?  I think FP 40 was just a guess on my part.  I figured you wouldn't put a FOX in anything.  I didn't expect you to call me on it either. HB~>  I was bench running the Enya 35 today.  I took Randy Smith's advice and ran 25% oil 50castor/50syn., ran great, 2 to 3 flip starts and I could run 2 cycle the whole tank without tightening up.  I guess that means it's broken in.  I put my OS Max-s 35 on the SCS.  I didn't expect the Enya to be ready to go this soon and I didn't want to wait to fly the SCS.
Jerry
« Reply #39 on: November 20, 2009, 02:05:13 PM »
Thanks guys.  The pictures do my planes a lot of justice.  Trust me, they have their share of flaws.  The 38 has met the asphalt one time.  The 35 OS Max-s was having some issues on this particular flight and I was doing stuff that I knew I shouldn't have been doing with a poorly running engine.  I keep NOT learning that lesson, don't push it when it isn't running right.  End result, it shut off straight above me and I simply could not run out the slack in the lines.  Tough plane.  It went in at about 5 o'clock, inverted, and removed the top wing.  Some glue and monokote and it was good to go again.  It flys better now that it's been crashed and repaired.  That seems to be the case with my planes.  I 've lost count of how many times I've put the Shoestring in the picture above into the asphalt.  Seems to like it, every time I crash it and fix it, it flies even better than before.
« Last Edit: November 28, 2009, 07:04:03 PM by Jerry Reider »
Jerry
« Reply #40 on: November 21, 2009, 09:22:02 PM »
I flew the SCStreak today.  It flies real nicely, more responsive than the Flite Streaks, and it seems to be more stable too.  I didn't use nearly all the control, it seems to have lots of up and down.  I think I'll really be able to wring this thing out after I get to know it better.  I did some inside and outside loops, lazy 8's, classic 8's (the ones with a full round inside and outside loop) and I had it inverted for a while.  Just flying it to get to know it.  I swapped engines from the Model 5224 Enya 35 to an OS Max-s 35 because the Enya had some issues.  See "Tight Enya 35 Model 5224" in the Engine Set up tips section for details.  I wasn't quite happy with the engine run.  I'll have to work out a kink or two with it.  I know this engine is a good running engine.  Overall for a first time out I'd give the plane a 10 out of 10.  I really like the way it flies.  I'd say it was a good choice of a model to build.
Jerry
Offline Leester
« Reply #41 on: November 28, 2009, 05:01:15 PM »
Jerry, You did a great job on the SCS it really looks Fantastic.  y1 y1 y1
Leester
ama 830538
« Reply #42 on: November 28, 2009, 07:01:28 PM »
Thanks Leester.  I'm anxious to get some time on it and run it through the paces.  I put the Enya 35 back on it because I got that engine straightened out by running it on the bench.  The Enya was my first choice for it for an engine, that's why I put it back on.
Jerry
« Reply #43 on: February 04, 2010, 12:26:44 AM »
Hi Jerry,
Thanks for the link to this posting!  The SCS turned out great looking.  I know they fly real well, so you should have a ball with it.
You convinced me.......... ;D
Big Bear
Offline Michael Boucher
« Reply #44 on: April 12, 2011, 01:30:21 PM »
Jerry, I really enjoyed reading this topic. You did a great job making the leading and trailing edges for it. The canopy adds alot to it as well. Mike  :)
AMA 59633
