Building Tips and technical articles. => Building techniques => Topic started by: Chris Fretz on July 25, 2016, 03:46:19 AM
What kind of glue will work for Styrofoam and Plastic? Epoxy? ???
I used to build a lot of indoor foamie airplanes, especially for other people. This was extremely popular. I like it a lot. But, epoxy works just fine. This glue is flexible, where epoxy is not.
https://www.motionrc.com/products/beacon-foam-tac-glue-2oz?utm_medium=cpc&utm_source=googlepla&variant=19074422278&gclid=CK3BtoLRjs4CFceBfgodjiAAZQ
Do hobby shops carry that do you know?
Epoxy tends to be heavy, and way stronger than it needs to be to get the job done -- but it does work.
Depending on the job at hand:
- epoxy with lots of microballoons mixed in
- Canopy glue (like "RC56" -- names often have "56" or "560" in them)
- foam-safe CA
- "low temperature" hot glue -- it's heavy unless you really control the film thickness, but it's fast and effective
- My favorite for crash repair on Phil Cartier-style foam wings is Gorilla Glue. Follow the directions on the package -- it needs water to kick it off. If you need to fill a big void, squirt some on a card and mix in a bit of water, then pour it in the hole.
GG (Gorilla Glue) the white stuff works very well. Most combat builders use it on foam to anything else.
Yeah I buy it at hobby people. But I belive hobby town usa carries it.
Also, like Tim and Ken said, the white gorilla glue is awesome. I forgot about that one
- foam-safe CA
I broke my cheap float
Gorilla glue. If that doesn't last, rebuild the mount with a 1/8" thick plywood plate that's about twice as wide and twice as long.
Cool! Thanks Tim I'll give it a try.
For that, I too nominate Gorilla Glue. Its all I use on foam and a lot of wood now too.
