  • June 15, 2025, 05:54:15 AM
Author Topic: Stuka Stunt Build  (Read 22790 times)
Offline Jake Moon
Stuka Stunt Build
« on: December 27, 2024, 12:46:44 PM »
This is a build thread that starts in Pennsylvania, stops in Dallas, and ends in Asia.
As a lifelong plastic model builder, I love semi-scale stunt planes. The Don Still Stuka Stunt is no exception. I've wanted to learn and fly Old Time for years, and finally decided to do something about it. It starts with a friend in Singapore crashing his Brodak Oriental ARF. The wing was largely fine, but the rest of the plane was toast. So I asked him if I could have the wing and he kindly obliged. The reason I wanted the wing: The Oriental and Stuka Stunt airfoils are the same. Cut a few inches off the tips, reshape the flaps, and it's 98% a Stuka Stunt wing. Good enough for me, especially as it'll never fly in a contest!
Then came another stroke of luck. At this year's Brodak contest, Scott Richlen sold me, for the princely sum of $10, a started Stuka Stunt project: another wing, a fuselage, and stab and elevators. They were quite unfinished (just assembled, not sanded), but the work was good and the wood was light as a feather. An added bonus as the ARF wing was far from light! And better yet, since I was at Brodak's, I could go down to the hobby shop and buy things to finish the project with (the canopy and an elevator horn)
From there I hatched a plan: I'd leave the wing behind in my dad's garage since I already had a wing in Singapore (If anybody in Dallas wants a started Stuka Stunt wing, it's yours for $11). But everything else, including the fuselage, was small enough to fit in a box for my checked luggage back to Singapore.
Before going back home, I got a few things done. The engine bearers were too far apart (and already drilled out with threaded inserts) for my engine of choice, an OS .25 FP. So I cut the exposed part of the engine bearers (and the inserts) lengthwise, leaving about 3/8" of them left. I then took pieces of roughly 5/16" maple and epoxied them to the cutout in the existing bearers, then sandwiched them between pieces of 1/8" and 1/16" ply. Not ideal, but I think it should work for such a small plane and engine.
I also did a whole lot of sanding to make the fuselage symmetrical and airfoil the 1/2" stab and elevators. To make the top block, I laminated two pieces of 1/4", 5.5-lb balsa and sanded and hollowed it out. I made the rudder from bits of leftover leading and trailing edge stock. Here are a couple photos of it all mocked up with the wing I was leaving behind. After these photos I managed the dope and cover the tail surfaces. Other tasks included carving the nose block (big thanks to my dad for letting me have one of his last lser cut 1.75" nose blocks) and sorting the landing gear. The fuselage I bought had no front formers, so I cut a slot in the bottom of the fuselage just ahead of the wing. Then I made a former from 1/8" balsa sandwiched between two pieces of 1/16" ply. The balsa plate had a groove cut in it to accept wire landing gear I had from an Ultra Hobby Gieseke Nobler kit (thanks again, dad).
All the Stuka Stunt goodies packed away for the 24-hour trip back home.
They made it! Here's all the stunt goodies I managed to pack in my luggage. Aside from a couple cracks in the fuselage that were easily fixed, no major damage to report.
The next task was the cut the wing down. The Oriental wing needed a total of 9 inches cut from it. I reused the tips, so I cut a couple bays out, sawed off the tips, then glued them to the shorter wing.
The one bit of damage from the wing was when the APC prop shot through the sheeting when the plane crashed. I cut out the damaged sheeting, reused two ribs from the sections I cut out in the previous photos, and got it back together.
Next came doping and covering. We can't get real dope in Singapore, so I use EZ Dope from Deluxe Materials. It's not quite as good, but it works well enough. It takes a whole lot longer to dry/offgas than real dope, but with the equatorial sun and 90-degree temps everyday, it worked out.
While the sun and heat are good for drying dope, it's not so great for the builder! I do most of my sanding at night when it's only 78 degrees and 85% humidity.
Our apartment complex has an "event space" for hosting dinner parties and it has a massive, perfectly flat granite island. So I decided to do my assembly there. As you can see, I already covered the fuselage. Since it's so small and the flaps (reused from the Oriental) are glued into the horn, I thought it'd be easier to dope/cover/sand before assembly.
Fuselage in place with jigs I made from hard 6mm balsa.
Wing in place. Due to some asymmetry, I had to cut more of the fuse out to get the wing to fit than I hoped.
The wing joint. I made a filet using 15-minute epoxy. Out of focus is a former to support the top block that still allows the flap horn to clear.
Stab and elevators in place. They must've been made with really old wood because they weighed nothing.
The building table after 4 hours.
We have an airframe!
Updates to come soon. Thanks for looking.
Offline Jake Moon
Re: Stuka Stunt Build
« Reply #1 on: December 27, 2024, 03:52:12 PM »
Now the real fun begins—cowl construction! I followed the construction method laid out in Don Still's Air Trails plans. I started by making the front of the cowl from 5mm balsa.
Then I tack glued it to the fuselage and made the round shaping behind the nose ring and the sides from 6mm balsa.
I made the venting from 4mm balsa. Now it looks like a Stuka cowl!
Then plenty of sanding. Especially in the rear to help with heat extraction. I used a dremel to create a hole to fit the battery. Later I soaked the edges with thin CA.
Holes drilled out—seven in total: one for the needle valve, two for the screws holding the cowl on, two for the muffler, and two on the other side to create the slot for the muffler.
A pretty decent fit around the muffler. I also soaked this opening with thin CA. I will use a tongue muffler but at the time this was all I had.
A few shots of the control system. The bellcrank (4"), flap horn, and little purshrod are all straight from the Oriental ARF. Brodak did a nice job, the controls are free and the work is all tight and crisp. I used a carbon pushrod with Titanium threaded inserts and ball links on either end.
At first I had the hardest time figuring out how to fit the controls into the tiny rear fuselage. Then I had a good look at the Stuka Stunt at the AMA museum in Muncie. The elevator horn is external—of course! So I made a (poorly measured) cut in the fuselage. The hole is so big so that I can adjust which hole the pushrod attaches to. With the pushrod in the middle hole of the elevator horn, it has a roughly 1.25:1 elevator:flap ratio.
Finishing the shaping, covering, and doping of the front half of the fuselage.
Top block attached with Titebond. You can also see the fairing I put around the pushrod exit.
Cockpit detail. It is all made from 1/32 balsa and then painted with Tamiya acrylic model paint. I made a floor mockup from paper before putting it all in the plane.
Rudder attached.
Offline Joe Bowman
« Reply #2 on: December 27, 2024, 06:27:05 PM »
Way to go Jake.  I like it a lot.
Online kenneth cook
« Reply #3 on: December 27, 2024, 09:27:23 PM »
               Jake, I think it's totally cool. I love the cockpit and I really like how it's been repurposed. It looks like it all flows. I can't wait to see the paint.
Offline Dave Moritz
« Reply #4 on: December 28, 2024, 10:36:55 AM »
Lookin’ good, my good man! It’s going to be a beauty.
Dave Mo…
Offline Kermit Payne
« Reply #5 on: December 28, 2024, 06:05:38 PM »
Jake,
First of all, Happy New Year to you and yours!  It's great to see you're making some sawdust, and I love the cockpit detail.  Keep up the good work --- I'll be watching the progress.
Kermit
Offline realSteveSmith
« Reply #6 on: December 28, 2024, 08:20:40 PM »
Great build series, Jake.  I appreciate all the detailed photos.
AMA 175438
Offline Joe Gilbert
« Reply #7 on: December 28, 2024, 09:48:44 PM »
Well done Jake, looks to me like all the building of plastic models has served you very well! Happy new year to you guys.
Joe Gilbert
Offline Jake Moon
« Reply #8 on: December 28, 2024, 10:08:46 PM »
Thanks for the nice comments, everyone!
A detail I forgot—the little fillet(?) piece that goes between the flap and the fuselage. The piece in the middle is a hollowed piece of 3/16" balsa. The flaps are 1/4". This piece is cut short to allow the horn to clear. Then it is sandwiched between pieces of 1/32 balsa. Afterwards I sanded it to match the bevel of the flaps. I doped and covered these pieces before glueing them to the fuselage.
The $17 Brodak charges for the Stuka Stunt canopy is money well spent. That saved a whole lot of work. To mask, I covered each pane with Tamiya 6mm masking tape, then cut along the framing with a new Xacto blade. With a sharp blade, it takes very little pressure to cut through Tamiya tape—significantly less than it takes to cut through the plastic. I use this technique for plastic model canopies as well. To get the effect of rivets on the interior of the canopy, I drew a bunch of dots using a Sharpie. This was a technique learned from a Windy video. When I start painting, the very first coat I'll do, even before primer, is interior green (or whatever Stukas had) over the canopy. Therefore it'll show when looking through the canopy.
I didn't have a lot of choice for glueing the canopy on. Since it just sits on the block instead of in a groove or nestled around a turtle deck, I wanted something faster than wood or white glue. But of course, CA won't work. And I couldn't find a good bottle of canopy glue either (it goes bad above 80 degrees, which it always is here). So I found some E6000 glue. The package said it sets fast and handles vibration. I discovered pretty quick that you get one chance with it. It congeals almost immediately, so you can't go back and smooth it out like you would epoxy or any other filet material. One side I messed up because I kept trying to touch it up. The other side came out very nice. The pictures I'll show you are of the good side. After I get some paint on, I might put a little putty on the crummy side if it's obvious.
The last thing I've done is make and install landing gear spats. They are made of 1mm balsa, with a 3mm core to guide the wire gear through. I made wheel pants, but I fly off of grass so I left them off. I also think I'm getting pretty tight on weight.
Here's how the plane sits now. It's all ready for paint. I think it'll be heavier than I like, but not horrible I hope. I'd love to hear what weights people have ended up when building these. All I have to go off of at the moment is from the 50's when they were 28-31 oz. using 50's wood and an unmuffled Fox .25/.29. At the moment, the airframe, including cowl, is 21.6 oz. I think the heavier weight is down to two things: a heavy wing (10.9 oz) and not letting the dope offgas enough between coats. My hardware currently weighs 10.05 oz (6.45—engine; 1.15—tank; 0.7—wheels; 0.4—prop; 0.8—spinner; 0.55—muffler). That puts everything at 31.65 oz. I'm really hoping I can end up at 40 oz. or under. I think it'll be close.
The next update should come somewhere in mid-January. I'm back in the US visiting folks and will get to painting after I return in the New Year.
Thanks for looking,
Jake
Offline Ty Marcucci
« Reply #9 on: December 29, 2024, 10:24:48 PM »
You can always spot as REAL modeler, no matter what if there is a will, there is a way.  Very nicely done.. My third stunt model was the Ambroid version,,I still have one kit. Can't wait until you fly it. H^^
« Last Edit: April 06, 2025, 04:22:21 PM by Ty Marcucci »
Ty Marcucci
« Reply #10 on: December 30, 2024, 08:04:29 AM »
Jake, you are a true artist with different materials.   I would guess Pop uses kevlar threat to hold his buttons on.   Keep up the great work.   HAVE A GREAT NEW YEAR. D>K
« Reply #11 on: December 30, 2024, 02:03:09 PM »
I built (assembled) an Ambroid Stuka at age 17.  I did a really good job on it.  But when I clear coated it the clear softened the canopy ands caused it to sag somewhat.  One final mistake on an otherwise good-looking job.
Offline Don Jenkins
« Reply #12 on: December 31, 2024, 07:05:11 AM »
Very creative Jake!  Nice work!
Don
Offline Doug Moon
« Reply #13 on: January 05, 2025, 09:51:47 AM »
I just found this thread. This is outstanding work! Very impressive!
Cant wait to see the finish.
Doug Moon
AMA 496454
Dougmoon12@yahoo.com
Offline SteveMoon
    • www.ultrahobbyproducts.com
« Reply #14 on: January 05, 2025, 07:56:06 PM »
Looks awesome Jake!
Dad
Offline Matt Colan
« Reply #15 on: January 07, 2025, 07:22:54 AM »
Keep up the good work Jake!!
Offline Jake Moon
« Reply #16 on: February 09, 2025, 09:12:27 AM »
Update: I painted the Stuka!
Dope isn't available here and since I just paint on our apartment balcony, I don't have a whole paint gun/compressor setup. So I decided to finish the plane as I would a plastic model.
Once I completed surface prep, I primed the plane with Tamiya rattlecan primer. Tamiya primer is very smooth and sands easily. It's amazing stuff.
Then I airbrushed model paint for the color. I used Mr. Color acrylic paint, thinned about 40% with Mr. Color Self-Leveling Thinner. This is exactly as I would a plastic model. The airbrush is a little different—since Singapore is on 220v, my modeling airbrush from America wouldn't work. So I bought a USB airbrush—a little rechargeable compressor the size of a Red Bull can screwed to an airbrush. It's not outstanding, but it works plenty well. This photo is of the underside (took 4 bottles), which I applied after painting and masking the insignias and yellow fuselage band.
Then came masking. I use Tamiya masking tape. Tamiya's tape provides a crisp line but leaves no residue or pull ups. I used an entire roll for this plane. Thankfully I can get this stuff when I visit my mom in Japan, where it costs about $1. I took the annoying step of taping off every hingeline to make sure I didn't get blow through with the paint.
Then after I had all the edges and hinge lines taped, I masked with brown paper.
Then came color. I am doing a Hungarian tricolor livery. First color was green.
Next came brown. I freehanded the camouflage edging.
And finally, grey.
I waited about 20 minutes before taking the masking tape off—I was just too excited! Overall I was thrilled with how well everything came out.
Offline Jake Moon
« Reply #17 on: February 09, 2025, 09:19:48 AM »
After color, I did panel lines. As per Al Rabe's method, I used a Sharpie Ultra Fine marker (surprisingly find to hard here!) and plastic sheets for guides. After that, I did weathering with a whole lot of post-it notes and rulers with masking tape. My mixture for the weathering was 10% brown, 15% black, and 75% thinner. Then I just layer it on in quick passes. You can see the USB airbrush I used on the table.
Then clear. I found some rattlecan, 2-part 2K automotive clear at a body shop. This is the real deal, it smells just like the auto clear we shoot through the gun (horrible!). The finish, from primer to color to clear, weighed less than 3 oz.
And after that, I called it done. All in it's 35 ounces, which I'm happy with. I wet sanded and polished the clear, but I was a bit lazy and didn't do enough sanding or polishing. Eventually I'll do a proper buffing.
Thanks for looking!
- Jake
Offline Crist Rigotti
« Reply #18 on: February 09, 2025, 01:31:59 PM »
Nice work!
« Reply #19 on: February 09, 2025, 03:01:33 PM »
One of my favorite designs of all time yet I have never built one.  Saw Don fly his back in 64.  Amazing flier and plane.  Hope it flies as well as you built and finished it.  Good work
« Reply #20 on: February 09, 2025, 03:09:23 PM »
You do nice work, Jake.  Hope to see it fly one day!
Kermit
Offline Matt Colan
« Reply #21 on: February 09, 2025, 09:00:27 PM »
Great work Jake!! Enjoyed watching it come together!
Offline kevin king
« Reply #22 on: April 06, 2025, 01:05:40 AM »
Very impressive. When is the flying video coming out? I've never seen one fly
« Reply #23 on: April 06, 2025, 04:17:01 PM »
Looks like you have a winner if it flies as good as it looks. D>K
