  • August 01, 2025, 09:02:05 AM
Author Topic: Wing fusalage cut out (profile) is sloppy  (Read 1705 times)
Offline Leester
« on: October 02, 2006, 05:40:36 PM »
My wing cut out in the profile fusalage which I did is not the best. Lineing the wing up in the cut out so that center lines match up leaves the top fitting good but the bottum has about 1/8" space TE to LE. I was thinking of tack glueing with c/a and filling the gap with scrap epoxyed in. Once covered I'll use epoxylite for fillets. Will this be ok???
Leester
ama 830538
Online RC Storick
Re: Wing fuselage cut out (profile) is sloppy
« Reply #1 on: October 02, 2006, 05:45:32 PM »
Fill the gap with wood and it will be fine. Just don't take the short way around and try to fill with glue. You must fill the gap with wood and then the fillets will cover it. It will be strong just not as light as a tight fit.
Offline Leester
Re: Wing fusalage cut out (profile) is sloppy
« Reply #2 on: October 02, 2006, 07:23:16 PM »
Thanks Robert. There will be no short way around things either. My next one will be a better fit.
Leester
ama 830538
Offline Dennis Moritz
« Reply #3 on: October 04, 2006, 06:31:11 PM »
I've stuck the balsa in when needed. Soft balsa works. I've got some crushable 1/16" that usually fits, along with wider stock, now and then. Jammed in, then I then run in thin CA, building up the space. Finish is 30 minute epoxy spread throughout the outside of the joint, when hit with a heat gun it runs in and fill all gaps. Careful not to put the heat too close to the wood. It'll bubble dope and silkspan. Do one side at a time to keep track of the runs. Have isopropyl alcohol and paper towels ready. Wipe off all excess epoxy. The final joint usually looks almost perfect. Trick is to not damage surrounding dope (I finish my fuses pretty much before sliding in the wing) and wipe off before the epoxy hardens. The heat gun will speed the epoxy cure.
« Last Edit: October 06, 2006, 05:29:20 AM by Dennis Moritz »
