Link 1
Stunt Hangar YouTube
P.A.M.P.A.
AMA
Balsa Density Calculator
This topic
This board
Entire forum
Google
Home
Help
Tags
Advertise
Login
Register
June 19, 2025, 07:54:18 AM
1 Hour
1 Day
1 Week
1 Month
Forever
stunthanger.com
Building Tips and technical articles.
Building techniques
(Moderator:
RandySmith
Using Nitrate
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: Using Nitrate (Read 1085 times)
James Mills
AMA Member and supporter
Trade Count:
0
Admiral
Welcome to the Stunt Hanger.
Using Nitrate
on:
December 01, 2007, 09:01:01 PM »
I'm thinking about using Nitrate for the base on my next plane. It's going to be a built up wing, at what point do you switch to butyrate? I've read one or two articles where they said they used the nitrate to shrink the silkspan.
James
Logged
AMA 491167
Clint Ormosen
2019 supporter
Trade Count:
0
Admiral
Re: Using Nitrate
Reply #1 on:
December 02, 2007, 01:56:45 AM »
I use 2-3 coats of nitrate on the wood before silkspan, then for the first 3 coats over the paper. Sticky stuff. Makes a good base for whatever you want to put over it.
Logged
Bill Little
2017
Trade Count:
0
Admiral
Second in COMMAND
Re: Using Nitrate
Reply #2 on:
December 02, 2007, 10:21:47 AM »
I apply nitrate to everything except the open bays. I use nitrate as the entire substrate and for attaching the covering. I also use the nitrate to begin the filling process on the solid wood areas. I use Sig Supercoat (high shrink) clear to shrink the open bays, then go to Sig Lite Coat (low shrink) all over for the rest of the clear.
Logged
Big Bear
AMA 95351 (got one of my old numbers back!
Print
Pages: [
1
Go Up
« previous
next »
stunthanger.com
Building techniques
(Moderator:
RandySmith
Using Nitrate
