  • July 08, 2025, 06:38:18 AM
Author Topic: Splicing CF Pushrods  (Read 3535 times)
Offline Roger Vizioli
  • CLiner
« on: November 16, 2015, 08:40:45 PM »
Has anyone successfully spliced CF pushrods?  If so, please state what you did.
Flapless plane will need 27" P'rod, all my stash is 17" or less.
Will buy longer stock unless I hear something good, that has worked !
thanks,
Roger V.
Roger Vizioli
AMA L-2408
Florida/Space Coast
Re: Splicing CF Pushrods
« Reply #1 on: November 16, 2015, 08:56:25 PM »
I've done it once, for a quick build of a test plane -- I had two rods of two different diameters.  One fit inside the other so I just telescoped them.  It's worked great so far.
« Reply #2 on: November 16, 2015, 09:21:41 PM »
Tom Morris sells a CF pushrod  "connector" just for that purpose. And it's adjustable.
They can also be joined with the typical ball link ends, or threaded rod.
Keeping the same size CF pushrod.
Charles
« Reply #3 on: November 16, 2015, 10:41:39 PM »
 I did one just recently. I use the smaller diameter carbon pushrods, not the big arrow shaft type.
 First, I cut a 3" section of thinwall aluminum tubing for over the outside of the carbon pushrod joint, with the I.D. of the aluminum being just slightly larger than the carbon pushrod O.D to allow for some adhesive later during the assembly process. Then, I cut a 3" section of threaded 4-40 rod for the inside of the pushrod joint. Clean, sand and/or scuff all parts prior to assembly.
 Use JB Weld for all assembly and "work" all parts of the assembly as you go to make sure that the JB Weld is spreading well everywhere for thorough adhesion.
 First, glue the 3" 4-40 rod into one half of the carbon tube, leaving 1-1/2" of it exposed, align and allow to cure thoroughly. Next, slip the aluminum tube over the carbon tube and slide it away from where the two pushrod halves are to be joined. Then join the other half of the carbon pushrod over the exposed 4-40 rod, butting the pushrod halves together and aligning for straightness, and let cure thoroughly. Once cured, sand the outside of the pushrod joint if necessary, down to the original O.D. of the carbon tube. Using more JB Weld, coat the carbon pushrod over the joined section and slide the aluminum tube into place over the outside, centering it over the joint. Don't forget to work and twist the aluminum tube back an forth a few times to make sure you'll get a good adhesive bond internally.
 This process takes a little time and patience, but you'll end up with a very sturdy connection once finished.  y1
  • CLiner
« Reply #4 on: November 17, 2015, 07:28:45 AM »
Tim, Charles and Wayne,
thx. will make up some test pieces.
Roger
Roger Vizioli
AMA L-2408
Florida/Space Coast
« Reply #5 on: November 17, 2015, 07:37:22 AM »
Roger
Roger,
Wayne's suggestion about the aluminum tubing slid over the CF pushrod is a really good one. Allows for a straight rod.
I'll do the task that way the next time I connect a couple of CF pushrods.
Charles
« Reply #6 on: November 17, 2015, 08:19:53 AM »
It also keeps the carbon from splitting.
  • CLiner
« Reply #7 on: November 18, 2015, 07:02:23 AM »
agree, thx "Doc"
Roger
Roger Vizioli
AMA L-2408
Florida/Space Coast
Offline Curare
« Reply #8 on: November 23, 2015, 08:22:56 PM »
So does binding the ends with a few wraps of thread and a drop or two of CA.
Cheaper and lighter too
Greg Kowalski
AUS 36694
