  • June 18, 2025, 07:06:11 PM
Author Topic: I want to paint my Dreadnought -  (Read 1584 times)
« on: November 19, 2007, 12:23:54 PM »
but it has a foam wing -
What it the best stuff to cover this with for painting given that dope and tissue disolves the foam......
looking for ideas here.
TIA
W
Re: I want to paint my Dreadnought -
« Reply #1 on: November 19, 2007, 06:40:25 PM »
TIA
W
Did you sheet the wing with balsa?
If so, start building up the finish with a couple coats of straight unthinned nitrate. Unless you pour thinner on the wing it won't ever effect the foam.
Chris...
« Reply #2 on: November 19, 2007, 08:06:21 PM »
To clarify - it is not fully sheeted - only LE TE ar sheeted - along with the centre section where the fuse joins.......
So where to from here?
I was thinking may SIG Koverall???
Offline peabody
« Reply #3 on: November 19, 2007, 08:10:53 PM »
Wynn...
Did you also apply "cap strip" looking pieces, ala Tom Dixon's "kept Foam" technique? If so, silkspan will work fine. Or moneycoat....
If you want to paint a wing that is raw foam, I suggest silkspan held down with waterproof polyurethane....and coated several times (gonna be heavy!)...
Let us know?
« Reply #4 on: November 19, 2007, 09:28:09 PM »
has cap strips - just didnt think I could dope over the silkspan.....
Offline ash
« Reply #5 on: November 20, 2007, 04:28:36 AM »
Wynn is worried about dope dripping through the silkspan onto the foam inthe open bays and eating it up. The two easy ways are to apply SLC film over the open bays before silkspanning the lot, or to do the first few coats of dope on the open bays from underneath so that the drips form on the outside, keeping the foam safe. Film has puncture resistace advantages and SLC film+tissue, the best of both worlds.
Offline ray copeland
« Reply #6 on: November 20, 2007, 03:24:38 PM »
Latex paint works directly on foam.
« Reply #7 on: November 20, 2007, 08:54:49 PM »
How about Polyspan, applied around the perimiters, with Nitrate. Then heat shrink, and spray on a few dry coats of Nitrate, more Nitrate, then more. I was also thinking about PolyCrylic over the bare Polyspan. Randy P. might nix that idea.  H^^ Steve
Offline Mike Spiess
  • bikemike
  • AMA #4060
« Reply #8 on: November 21, 2007, 09:11:21 AM »
Check out Polyacrilc it wont hurt the foam and really hardens the balsa and I found everything is compatable over it.
You don't stop flying cause your get OLD
You get OLD cause you stopped flying
St Peter MN
Present Master of the Figure 9
