  • July 12, 2025, 12:27:59 PM
Author Topic: Source for small copper or brass tube  (Read 2592 times)
« on: May 09, 2013, 02:45:50 PM »
I see folks making control systems using lead-out wire run through small copper or brass tubing -- like, OD less than 1/16" (and ID obviously more than .027" cable).
Where would I look for such stuff?  I suppose I'd rather have copper than brass; either way I want soft.
Offline John Cralley
John Cralley
AMA 52183
Central Illinois
Offline Balsa Butcher
  • High Desert Flier
Re: Source for small copper or brass tube
« Reply #2 on: May 09, 2013, 04:19:24 PM »
K&S tubing displays can be found at hobby shops. Hobby Lobby craft shops carry it as well as many ACE or OSH hardware stores. The trick is to anneal (I think that is what it is called) the tubing. Heat it using a propane torch and then quench it in some water. It will now be soft and can be bent into tight loops for leadouts or line ends. Done carefully it will not crush or pinch the cable. 8)
Pete Cunha
Sacramento CA.
AMA 57499
« Reply #3 on: May 09, 2013, 04:24:19 PM »
K&S only goes down to 3/32.  I was hoping for smaller.
« Reply #4 on: May 09, 2013, 04:30:03 PM »
Gee, I have bought K&S tubing that is 1/16" OD with an ID of 1/32".  I am even holding a piece in my castor oil stained fingers here very close to the monitor.
KT
Offline Geoff Goodworth
« Reply #5 on: May 09, 2013, 09:17:20 PM »
I'm like Keith. Tower lists 1/16" OD, $2.09 for a packet of 3 pieces 12" long.
« Reply #6 on: May 09, 2013, 09:29:38 PM »
Augh!  I had just looked on Tower and didn't find that.  Do you have the number, or a page URL?
« Reply #7 on: May 09, 2013, 10:44:19 PM »
dude,, go to Ace hardware, or Micheals, or hobby lobby,,
save shipping, + instant gratification
Online RC Storick
« Reply #8 on: May 09, 2013, 11:02:20 PM »
http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXCGCK&P=7
« Reply #9 on: May 09, 2013, 11:04:50 PM »
« Reply #10 on: May 09, 2013, 11:46:27 PM »
« Reply #11 on: May 10, 2013, 09:15:48 PM »
Tim,
I'm surprised your not digging up the copper and casting it yourself.   ;D
« Reply #12 on: May 10, 2013, 09:19:11 PM »
Tim,
oh Randy, that is kinda harsh,,
funny,,
but harsh,,
Tim,, heres to you bud,, now they dont pick on me quite as much,, LOL
« Reply #13 on: May 10, 2013, 11:13:30 PM »
Tim,
No copper ore on the property.
But, come to think of it, I do have some spare romex.  Hmm.
« Reply #14 on: May 11, 2013, 02:30:25 AM »
If you get that straight enough, you might be able to drill it.
Amazon Supply (formerly Small Parts), the link John posted above, has lots of cool tubing, including tiny stainless hypodermic needle tubing.
Offline Jim Thomerson
« Reply #15 on: May 12, 2013, 10:55:14 AM »
If your are using a plastic bellcrank, the Teflon tubing, like used with CA glue, works fine at the bellcrank end of the leadouts.
