Building Tips and technical articles. => Building techniques => Topic started by: Greg L Bahrman on July 17, 2009, 08:09:22 PM
Title: SOMETHING NEW (PICS ADDED)
Post by: Greg L Bahrman on July 17, 2009, 08:09:22 PM
Well I looked all over for something to make a buck out of so I could mold the top deck of my new ship. I love I.B.C. Rootbeer and they happened to be just the right size. Plus they don't have the normal lip at the top and bottom of the can. PERFECT.....I used 2 sheets of 1/16. I will glue them together now that they are the right shape. They will go back on my hi tech mold until dry. I marked them so they wouldn't get mixed up.....Grins
Title: Re: SOMETHING NEW (continued)
Post by: Randy Powell on July 18, 2009, 09:46:01 PM
Well, that is one way to do it.
Post by: L0U CRANE on July 19, 2009, 03:31:35 PM
Guys,
Way back in the dark and misty ages, I picked up some 2 1/4" banister rail...
It even has a flat on one side - I guess to attach it to the stairwell posts or whatever.
I suppose I could pick up on a soft or semi-hard beverage that comes in the flangeless can, but, then what would I do with those banister pieces? (Rhetorical question - I know what kind of suggestions I could expect... ::) )
Post by: Randy Powell on July 19, 2009, 09:40:04 PM
I make mine out of structural foam.
Post by: Eric Viglione on July 20, 2009, 07:29:40 PM
I have an assortment of aluminum baseball bats and axe handles that have never met a turtle deck they couldn't match. Just find the right section of taper, make the molded section a little oversize and trim to fit. We don't need no stinkin' foam bucks!  LL~ LL~ LL~ LL~ LL~ (patience was never my strong suit)
EricV
Post by: Randy Powell on July 21, 2009, 11:26:00 AM
Eric,
Well, at this point I have quite a selection. Probably 10 or 12 bucks made from various materials. Some are foam, some are balsa and other stuff. One is made from plaster of Paris.
Post by: Bill Little on July 21, 2009, 12:35:38 PM
If you have ever had a lost foam fixture, or similar, you can often use the LE bucks for molding turtle decks.  Even a foam wing core.
I will mention that you can (or at least I have with success) substitute 3/32nd for 1/8th since it is *molded*, without any apparent structural strength loss.
Mongo
Post by: john e. holliday on July 22, 2009, 08:10:30 AM
If you really want strength, do as Windy did on one of his tapes.  Two layers of 1/32 balsa.  DOC Holliday
Post by: Bootlegger on July 22, 2009, 09:26:45 AM
Guy's when you are forming a top block and you are laminating two pieces of wood, what do you use as adhesive, and do you use carbon mat between the pieces of wood? Also when you are using the mat what weight do you use, and how do you spred the adhesive with out "smearing" the mat around??
  Another question, do you put formers under the molded piece??
Post by: FLOYD CARTER on July 22, 2009, 10:21:53 AM
I have several bucks made of pine and varnished.  I can  usually find one with taper and shape close to what I need.  I always use two pieces of 1/32" balsa with a layer of silkspan between.  Best adhesive is Titebond thinned with some water.
Post by: Greg L Bahrman on July 22, 2009, 05:34:07 PM
<Guy's when you are forming a top block and you are laminating two pieces of wood, what do you use as adhesive, and do you use carbon mat between the pieces of wood? Also when you are using the mat what weight do you use, and how do you spred the adhesive with out "smearing" the mat around??
  Another question, do you put formers under the molded piece??>
Hi Gil,
I used two 1/16 thick pieces of balsa. I used tightbond water base glue. I thinned it out with a few drops of water and painted it on with a brush, making sure it was spread evenly, yeah you could use a card. I then put the 2 pieces together and put it back on the mold to dry. Yes, I put formers in my molded shell they are located directly above the formers in the fuse so they will be bonded together when the shell goes on. I also put a piece of stock the full length of the part like a backbone. It's located in the center of the crown.
Post by: Tom Niebuhr on July 22, 2009, 09:22:26 PM
Greg,
"Root Beer"???? You could have done better than that!
Title: Re: SOMETHING NEW (PICS ADDED)
Post by: Greg L Bahrman on July 24, 2009, 07:18:29 PM
Hi Guys,
Check it out my Rootbeer molded deck came out sweet.
Post by: john e. holliday on July 25, 2009, 08:34:20 AM
That looks great and wasn't as hard as you thought.  Sure looks a lot better than the blocks I try to carve.  DOC Holliday
Post by: Claudio Chacon on July 25, 2009, 09:50:48 AM
Perfect Greg.
Keep the photos coming! #^
Post by: Greg L Bahrman on July 25, 2009, 11:50:51 AM
Thanks everyone.....Well......This is all I have to show for now. Stuck together. Carbon veil added to cowl.........#^ ~> #^
Title: Re: SOMETHING NEW (PICS ADDED) PROGRESS
Post by: Greg L Bahrman on August 02, 2009, 07:32:53 PM
Hi Ty,
Pecan stain would of been nice, but I made the decision to go over to the dark side. I can't do the turtle deck until the wing and the tail feathers are in and the controls hooked up. I fiberglassed the little section with the slots for air exit for a little extra strength before I did the carbon fiber thing. I ran out of Carbon Veil so I had to use the several pieces I had left over form the last build. It took a little extra sanding to feather all the edges and get  it all flat. You won't be able to see it when painted. I used 3 coats of Nitrate Dope on the wood. When dry, a light sand and then applied the Veil with nitrate and a little Zinc Stearate to help fill the weave. I sanded about 50% of the dope off....OH and the little putty (SHHHH).....I was a little agressive and dug a groove with my thumb nail.
Post by: Steve Helmick on August 02, 2009, 09:14:30 PM
Hey, it really is just a big Nobler! Or twin fins could make it a big Oly? Will it be ready for GSSC? H^^  Steve
