  • June 19, 2025, 04:11:01 PM
Author Topic: Soldering Techniques  (Read 1223 times)
Offline Douglas Ames
« on: September 13, 2009, 09:24:13 PM »
When soldering music wire, etc., do you guys use acid core or rosin core?
Silver solder and MAP gas? Or is that too much heat?
AMA 656546
Offline Bootlegger
Re: Soldering Techniques
« Reply #1 on: September 14, 2009, 05:36:54 AM »
  I use rosin core solder that I pick up at electronics stores, acid core will cause rust and binding..
 As for what to use when soldering the wire I use a Weller 140-100 watt soldering gun that I picked up at Home Depot or Lowe.s.
  I have used Mapp gas when using silver solder, but for most soldering I just use the soldering gun.
  Of course the wire has to be clean, and I use sand paper to get it "shiney" clean.
  Also if splicing the wire, I clean both pieces and wrap with fine copper wire then solder...
 I hope that this answers your questions and if I can help again just say so..... D>K
8th Air Force Veteran
Gil Causey
AMA# 6964
« Reply #2 on: September 14, 2009, 09:46:03 AM »
WEll, it depends on the job. For things like building fuel tanks or soldering landing gear tabs or similar projects, I use a thin, 60/40 solid core solder with an electronics flux (rosin based, I think, but I'd have to look). I have a big Weller gun that I've had forever and also a regular iron that I use when I need to get more heated surface area on a project. If I'm doing something that needs more strength (like when making control horns or something like that), then I use a torch. Either Map/Oxy or just Map gas and 60% silver solder. That takes a lot more heat.
You have to match the tools to the project.
Offline Hoss Cain
« Reply #3 on: September 14, 2009, 01:36:18 PM »
There is a very good silver solder called Stay-Brite. It is available in a number of Hardware stores and most good hobby shops. I do not know if such continues but a few years ago , Geat "Pains" sold it in their own package labeled "Silver Solder" GPMR8070.
Stay Brite is very strong. It can be easily done with a decent size soldering gun. Those 15-40 watt electric irons will not do well with landing gear etc. Fine for electric stuff, but not hardware.
A little trick, contrary to all the politically-correct methods of soldering,  n1  is that I apply the liquid flux, sparingly, heat the job a bit, melt some stay-brite, then a few drops more flux and things began to run very well.
There is another good one, usually found in the RC Car departments called Dean's Racing Solder with about the same silver content of Stay-Brite. It works well, but I definitely prefer Stay Brite.
Horrace Cain
AMA L-93 CD and Leader
Offline tom hampshire
« Reply #4 on: September 14, 2009, 01:44:57 PM »
     I gave up on Weller guns a few years ago, now use a selection of four old irons, varying from a pinpoint tip to 3/4 wide.  Use a Mapp gas torch to bring them up to temp quickly.  Tried a bunch of tricks to keep the Weller guns from losing contact where the tip meets the threaded collar.  Probably thermal expansion due to resistivity, I was forever tightening those sleeve nuts to get contact.  Does anybody know how to get that assembly to function right?  Tom H.
« Reply #5 on: September 16, 2009, 11:21:40 AM »
Tom,
Hmmm, mine's a fairly old one. Has big bolts. I bend the right angle in legs of the copper tip after putting the nuts on the legs, then just maneuver them into the holes in the side of the contacts then thread the nuts in. The clamp to the right angle bent legs of the copper tip pretty tightly.
