  • August 04, 2025, 04:45:39 AM
Author Topic: Soldering Iron  (Read 2961 times)
Soldering Iron
« on: May 24, 2015, 08:00:51 PM »
I had to fix a locations of the uniflow line in my Ringmaster. I had picked up a large tip solder iron a Weller SP-80 from a sale table at the local hobby store for $5. This is a great soldering iron heats up fast. Lots of heat and big tip. Easily heated the tube solder and finished the job. Good little tool.
Best,   DennisT
Re: Soldering Iron
« Reply #1 on: May 25, 2015, 02:43:36 PM »
For tanks, I now use a small butane soldering iron.  Remove the copper tip and you have a nice little butane torch!
Re: Soldering Iron
« Reply #2 on: May 25, 2015, 03:08:57 PM »
I am like Floyd, I use a mini torch I got from Radio Shack to remove the end cap, and either my big Weller or my big Craftsman soldering gun to reassemble.  I also use rosin core solder.  Almost all the fluxes are corrosive and they are a pain to neutralize!
Thanks for the tip on the iron, my good one disappeared, I guess it grew legs and walked off.  I had it since 1972.
Re: Soldering Iron
« Reply #3 on: May 26, 2015, 03:58:38 PM »
If you ask for "rosin core" solder, you might get blank looks.  Instead, go for "Radio Solder".  I use the Radio Shack kind.  Totally non-corrosive, and I seldom bother to wash my soldering work after finishing.
Offline Bill Johnson
Re: Soldering Iron
« Reply #4 on: May 26, 2015, 08:53:13 PM »
I have the same torch and just used it last week to solder some pushrod ends on. Not having soldered anything in years, I think I applied way too much heat a couple times but eased up and got some good solder joints.
Due to a recent inadvertent high speed contact with the pavement, I have a slightly crushed tank that my friend declared as "trashed". I was doing some research here on soldering tanks and was thinking of buying a 80 watt soldering iron but think I'll try repairing the tank using the torch.
Thanks for the post, Floyd.
Best Regards,
AMA 350715
Re: Soldering Iron
« Reply #5 on: May 27, 2015, 08:36:37 AM »
I tackled a tank once.  n~
It wasn't as easy as I expected. True learning experience.  HB~>
Now if I had the tank before I drilled the engine mounting holes and before I put in the blind nuts?
I didn't want to plug and redrill the mounting holes. A price to pay for lazyness.  n1
Here's the link.
Did get it done though.
"Eventually."
A line from the movie Seabiscuit.
http://stunthanger.com/smf/index.php/topic,35403.0.html
Re: Soldering Iron
« Reply #6 on: May 27, 2015, 09:14:22 AM »
Um Bill,"your friend" has many more tanks to replace that one, for free. Hint. Unless, of course, you want an exercise in frustration. like the rest of this wacko hobby.  H^^ LL~ LL~
No, I have enough frustrations as it is.  n~ Just looking to save some money.
Best Regards,
AMA 350715
Re: Soldering Iron
« Reply #7 on: May 27, 2015, 10:10:43 AM »
Tinplate is so very easy to solder that you can use just about anything that'll melt solder.  I'm surprized that the butane torch works: I'd expect it to get things too hot.  But hey -- if it works, it works.
Tags: tools  solder
