  • June 18, 2025, 11:19:01 AM
Author Topic: So, this happened.  (Read 4649 times)
So, this happened.
« on: June 03, 2019, 03:43:09 PM »
Hit a hole at the school where I was flying. On the 4th flight. But I'm well on the way to repair. Shame, too. The thing flies very well. First electric plane I've built that tracked right off the bench.
Re: So, this happened.
« Reply #1 on: June 03, 2019, 05:12:45 PM »
This would not have happened if you'd had Helmick machine the wings from Tungsten.
« Reply #2 on: June 03, 2019, 05:14:23 PM »
715 ish square inches and weighs, ready to fly, 64oz. I'll stick with balsa - an not land in potholes.
« Reply #3 on: June 03, 2019, 05:29:25 PM »
No holes at Stonehedge. Come on down.
That sucks, though. That’s why I’m afraid of wing-mounted gear.
« Reply #4 on: June 03, 2019, 09:38:24 PM »
Wonder if the schools liable .  :-\ Er . Sorry to see this . Recently did the same to my P-51 .
Make sure you dont get slack & agro and leave any bits to rattle in the wing .
A piece of 1/8 , 1/4 wide & 1/2 long is just right to jam in the rib half along it ,
 and catch the bellcrank , rocking each time it comes past . Unless it jams .
Nice looking plane , theyll never see it there on the underside anyway .
Offline TDM
« Reply #5 on: June 04, 2019, 11:29:50 AM »
Can you put a picture of the gear leg wire? I suspect something.
« Reply #6 on: June 04, 2019, 11:49:41 AM »
Now you need safety cones to mark the holes.   Hate to see the damage.   D>K
« Reply #7 on: June 04, 2019, 03:08:17 PM »
TDM,
You can see the one gear leg on the wing where it didn't rib out (though it crack the gear block). The gear was set up for pavement. Not good for grass. I'll bend up another set farther forward and with bigger wheels for the grass.
« Reply #8 on: June 04, 2019, 09:42:04 PM »
thats ' Rip ' or rip the rib . >:(
Yea , big spongey wheels'd absorb a lot of the jolts . No give cracks up things . Youll have to fly at youre local bowling green . ;D
' our ' free flight Mercury Tiger Moth did a staggering flight just clearing the local bowling club rear iron fence , centuries ago .
Two fiels full . Studiously ignored when we got around the front , to find it sitting on their path with dirt on the spinner .
Always wondered ifit'd got them ducking and diving as it did its sudden appearance in their midst , changeing course at each stall / swoop .  :-\ LL~ :-X
« Reply #9 on: June 04, 2019, 09:56:13 PM »
 Man that really sucks, sorry to see it Randy.  :(
« Reply #10 on: June 05, 2019, 06:39:08 AM »
 :We wondered if it was the locality .  :( S?P
Maybe flowers r better n weeds .
« Last Edit: June 06, 2019, 09:39:53 AM by Matt Spencer »
Offline TDM
« Reply #11 on: June 05, 2019, 09:07:25 AM »
TDM,
I want to see the part that goes inside the wing.
Ok long story short if you have half inch in the wing that has a lot of leverage to tear things out like it did. Else if the part that goes in the wing was tied up to the top of the wing then it is a completely different story.
For reliability the part that goes in the wing should have a hard block at top of the wing for it to avoid thing like that. Sorry it happened. Leave and learn some say. Sometime 5-10g of extra weight really pay off dividend on the long run.
Make a video of the flight.
Online Mike Scholtes
« Reply #12 on: June 05, 2019, 07:21:45 PM »
Ouch! But I'm curious about the battery compartment. Can you comment on the scalloped rails with holes? What sort of retention system are you using?
I don't think any gear type is immune to damage. I ripped the fuse-mounted gear clean off a Vector (not an ARF-  a kit built what I thought was plenty strong) on a sprinkler head hidden in the grass.
Good to see it will be back in the air shortly.
« Reply #13 on: June 06, 2019, 04:14:32 PM »
TDM,
The part that goes in the wing crosses over to the upper spar. the leg is about 2.25" long. The retention block is attached to the opposite spar from the one the gear block is attached to.
Mike,
The battery is retained by two carbon fiber posts that cross the batter compartment. there is a floor to the compartment that is removable and the ESC is down there in the air flow. The time is under the compartment where you see the start button. Lots and lots of airflow through there while retaining torsional strength.
« Reply #14 on: June 06, 2019, 10:22:30 PM »
Thanks Randy. I know you have a lot on your plate right now but when you get a chance I bet a lot of us would like to see a picture of your battery mount and other items. Looks like you have some interesting ideas there, I have not seen anything like that before.
Offline pmackenzie
  • Pat MacKenzie
« Reply #15 on: June 07, 2019, 04:40:21 AM »
Battery mounts looks similar to Paul Walker's design.
Chris Cox had some details of it in his "building a round fuselage" article in Stunt News (2018 issue 1)
MAAC 8177
« Reply #16 on: June 07, 2019, 10:52:27 AM »
Yea, it's similar to what Paul Walker does. With some tweaks of my own. You have to adapt to each plane to figure out how to keep the heat down, the airflow up and ease of use. I'll take some pictures later.
« Reply #17 on: June 08, 2019, 06:14:01 PM »
So, it's coming along. One pic for Mike of electronics compartment. the other shows painting progress.
« Reply #18 on: June 10, 2019, 10:21:40 AM »
Still have to sand the clear and buff, but the fix is done. Looks mostly OK.
« Reply #19 on: June 10, 2019, 05:58:38 PM »
 You made that fix look easy Randy, looks great!
« Reply #20 on: June 10, 2019, 10:32:18 PM »
He makes everything look easy. Irritating, actually.
« Reply #21 on: June 12, 2019, 09:44:46 PM »
Trust me, it was a pain in the backside. But, all done now. Will test fly on Saturday.
Will stop by Griot's  garage to pick up some polishing compound tomorrow and it will be as good as new.
« Reply #22 on: June 13, 2019, 04:19:49 PM »
So, built new grass gear and took it out last night to fly. It was pretty hot but I got two flights on it. Works fine. Good flying plane.
« Last Edit: June 19, 2019, 02:59:19 PM by Randy Powell »
« Reply #23 on: June 13, 2019, 09:12:27 PM »
 Good to hear Randy, hope it turns out to be a good one!
