  • July 11, 2025, 03:53:15 PM
Author Topic: So, new toy underway  (Read 20086 times)
Re: So, new toy underway
« Reply #50 on: January 05, 2021, 07:48:01 PM »
 Yeah, I hear ya. Seems every build has it's own learning experiences, especially when scratch-building. I don't think I've ever built a plane where I wouldn't do a few things differently if I was to do the same one again.
« Reply #51 on: January 06, 2021, 09:51:48 AM »
The method I used has the benefit that it is lighter than the two previous iterations, but is a lot more work intensive.
Oh well, keep on keeping on.
« Reply #52 on: January 08, 2021, 09:09:24 AM »
This side is done. Just have to mount the gear. And I had to break the mold to get this gear leg out. Oh well, it was about done anyway.
« Reply #53 on: January 08, 2021, 11:34:51 AM »
Love the louvers!
« Reply #54 on: January 11, 2021, 12:08:23 PM »
So, the gear is mounted. Took a lot longer than I thought it would. I'll sand and polish the gear legs eventually.
I think I'm going to relocate the battery plug site. Looks kinda bad where it's at.
Offline Page Peterson
« Reply #55 on: January 11, 2021, 01:18:04 PM »
Randy, could you share how you are doing the tip weight tube?
« Reply #56 on: January 11, 2021, 01:18:46 PM »
I had a similar issue a while back.  What I rationalized is that nobody would see it in the air so I used a flush mounted female Deans.  With it out, like it is when anybody is looking at it, there were just two little slits.
Just a thought - Ken
PS: that is a really sharp profile front end.
« Reply #57 on: January 11, 2021, 01:40:14 PM »
Page, It's a piece of Carbon Fiber tube with a piece of aluminum on the end to reinforce it. I tap the end and use a hex head insert bolt to close. The other end is plugged. I cut some 1/4" steel rod to various lengths and machine the end with a little loop (I'll try to remember to take a picture) and use a weights. Take out the screw, fish out the current weight and put in another one. The fit pretty tight so they don't tend to move around. Look back on this thread, there's a close up picture of how the tube is mounted.
Ken,  Yea, the idea was better in my head than what came out. I'll probably relocate it to below the battery box. Sigh...
« Reply #58 on: January 11, 2021, 06:52:28 PM »
 Good call. Can it go down in front of the gear?
« Reply #59 on: January 12, 2021, 10:14:03 AM »
Here's where it went.  Due to where I mounted stuff inside, this was about the only option. The other one could have been below the box and forward, but I went with this. Also, a couple of pics for Page.
« Reply #60 on: January 12, 2021, 11:03:38 AM »
Thanks for the pictures and details of weight tube!
Offline TCL
« Reply #61 on: January 12, 2021, 11:40:30 AM »
Sheesh, if one is feeling insecure about his building skills, this is not the place to come!  LL~   Terrific work! Thanks for sharing.
« Reply #62 on: January 12, 2021, 01:44:45 PM »
 ;D
« Reply #63 on: January 14, 2021, 04:13:14 PM »
So, here it is in mostly one piece. Need to build flaps and shape the elevator. Then final sand and begin finishing. Funny how one minute you have a stack of parts and the next, gee look, an airplane is suddenly on the bench.
« Reply #64 on: January 14, 2021, 07:57:51 PM »
 Cool.  y1
« Reply #65 on: January 21, 2021, 11:41:31 PM »
Randy, what's the stuff covering the rear of the fuselage sides? It looks like balsa, but maybe 1/64" plywood? I remember Mark's Profile Impact being covered with balsa and light fiberglass (or CF?) and how it was proven to flex with Howard's mini-camera dingus. In that case, I suspect that having the pushrod & horns enclosed and on the fuselage centerline would have reduced the problem, but not totally eliminated it.
I used 1/64" plywood on one, and it made it stiff as a pine plank. Haven't heard anything from Mark lately...I hope he's ok.  y1 Steve
ah yes the Impact profile you love to hate LOL,, yes the fuse was the wiggly sort, which I remidied with Flap strakes,, really really long flap strakes,,
Steve, Im still kicking, assuming contests are held, I will be there, I am finally getting caught up financially and physically after all the doctors are done doing their ,, well they are done, so, on we go..
« Reply #66 on: January 22, 2021, 06:29:47 PM »
 Nice to see ya back here Mark!  y1
« Reply #67 on: January 25, 2021, 01:16:41 PM »
Hey Mark. Glad to hear from you.
« Reply #68 on: January 26, 2021, 02:27:35 PM »
OK, last pics until it's done.
« Reply #69 on: January 26, 2021, 09:06:01 PM »
 Looks awesome Randy, anxious to see what's up your sleeve for the paintwork.
« Reply #70 on: January 28, 2021, 01:35:34 PM »
OK, two more. Then that's it.
« Reply #71 on: January 29, 2021, 11:39:18 AM »
Too bad you have to cover all that great work with a simple paint scheme. LL~ LL~ LL~
Offline Bruce Shipp
« Reply #72 on: January 29, 2021, 11:39:46 AM »
How about some more pics of that hinge slotting jig and the adjustment mechanism (I assume it is adjustable for slot heights)?That looks pretty slick.
Bruce
« Reply #73 on: February 01, 2021, 10:29:38 AM »
It's a Slot Machine with a base and adjustable plastic screws on the bottom for height and angle. In this case, I made two cuts then inserted hinge pockets made from plywood. I'll take a close up pic and details.
« Reply #74 on: February 01, 2021, 11:34:02 AM »
What is the payout percentage? LL~
Offline Bruce Shipp
« Reply #75 on: February 01, 2021, 12:47:10 PM »
Thank you, Randy.
« Reply #76 on: February 04, 2021, 09:31:43 AM »
Bruce, hopefully this makes it clear.
Offline Bruce Shipp
« Reply #77 on: February 04, 2021, 03:28:38 PM »
Yes Randy, thank you.  I had assumed the slotting tool was attached to the wood jig.  I see now it rests in the three  nylon bolt heads.  Very simple.
Do you anchor the control surface and move the tool to cut the slot or do you anchor the tool and move the control surface surface?  Or is it a combination of the two. It sure looks like an easy way to make consistent, repeatable hinge slots.
Offline Jack Pitcher
« Reply #78 on: February 04, 2021, 03:58:13 PM »
Derek Moran's original how-to article for his slot machine fixture is in the June 2006 issue of Model Aviation magazine. That issue is available in the MA archives on AMA's web site.
Jack
Jack Pitcher
Vortex Stunt Team
AMA 65309
« Reply #79 on: February 05, 2021, 09:22:49 AM »
Jack, buddy! Haven't heard from you in a long while. Nice to see you here.
As Jack noted, It's a Derek Moran fixture. Modified somewhat by me. I usually clamp the tool in the jig and move the control surface.
Offline Bruce Shipp
« Reply #80 on: February 06, 2021, 09:29:01 AM »
Perfect. Thanks.
« Reply #81 on: February 06, 2021, 11:26:07 AM »
  The Slot Machine works OK, I just wish it mad a wider slot. I tried gluing sand paper to the sides but that doesn't last very long. Next time I use it I'll see if it's possible to stack up blades for a wider slot, or has somebody figured out something else?
« Reply #82 on: February 23, 2021, 08:10:57 PM »
Offline Crist Rigotti
« Reply #83 on: February 23, 2021, 10:02:44 PM »
Posts #62 and 63.  You get the idea.
https://stunthanger.com/smf/gettin-all-amp'ed-up!/2016-electric-stunter-build-log/msg431948/#msg431948
« Reply #84 on: March 02, 2021, 07:39:02 PM »
 How's it going out there?
« Reply #85 on: March 15, 2021, 07:13:00 PM »
 Any progress Randy?
Online Brent Williams
« Reply #86 on: March 16, 2021, 09:45:52 PM »
Any progress Randy?
You'll have to go to facebook to see Randy's progress.  It's looking great!
« Reply #87 on: March 17, 2021, 09:08:22 PM »
 That sucks, I don't do facebook, and won't.  :(
« Last Edit: March 17, 2021, 09:30:53 PM by wwwarbird »
« Reply #88 on: March 17, 2021, 11:55:04 PM »
y1 y1
« Reply #89 on: March 19, 2021, 09:05:33 AM »
Here is a progress picture of Randy's Ringmaster Deluxe.
« Reply #90 on: March 19, 2021, 10:15:08 AM »
Work of art.  I love the faring over the controls and the large fillets for the flaps.  That adds so much strength to the fuselage and not many people do it.
« Reply #91 on: March 19, 2021, 06:48:31 PM »
 Thanks for the photo Brent, it's looking good.
 Did Randy ditch the forum?  ???
Offline Larry Renger
« Reply #92 on: March 20, 2021, 05:17:11 PM »
Also note the sophisticated dust cover for the bandsaw! 🥸
« Reply #93 on: March 21, 2021, 10:00:32 PM »
Here's the latest.  Ultracote transparent orange.
« Reply #94 on: March 22, 2021, 09:00:21 PM »
 I'm generally not a fan of Monokote birds but that does look pretty cool, really shows off Randy's gazillion piece wing structure. Thanks for the update!
« Reply #95 on: April 06, 2021, 06:48:01 PM »
 So...where'd Randy go?  ???
Offline Joseph Patterson
  • AMA member- Supporter
« Reply #96 on: April 22, 2021, 05:47:46 AM »
U R RIGHT ABOUT THAT TCL!!!
         DOUG
« Reply #97 on: April 22, 2021, 09:19:28 PM »
 Is anyone going to fill us in on where Randy went?  ???
 MAJOR loss to the forum if he's abandoned SH.
« Reply #98 on: April 23, 2021, 09:40:31 AM »
Randy decided to take a break from Stunthanger (and politics. )
He is posting progress pictures regularly on the various facebook control line pages.  Here's the latest update.
« Reply #99 on: April 23, 2021, 03:20:05 PM »
Thanks for the update, I miss Randy's postings and I don't do facebook for exactly the same reason!
