  • July 16, 2025, 11:50:53 AM
Author Topic: So, new toy underway  (Read 20555 times)
« on: November 30, 2020, 01:15:15 PM »
Started an electric version for the RMD. Should be fun.
Re: So, new toy underway
« Reply #1 on: November 30, 2020, 09:19:40 PM »
 Cool!  o2oP
Offline Larry Wong
« Reply #2 on: December 01, 2020, 09:25:19 AM »
Randy better watch out this might be the best flying plane EVER...........................
 y1 y1 y1
Larry
Online Crist Rigotti
« Reply #3 on: December 01, 2020, 10:20:01 AM »
What's RMD?
Online Brent Williams
« Reply #4 on: December 01, 2020, 12:17:07 PM »
What's RMD?
Randy Powell's Ringmaster Deluxe.
« Last Edit: December 01, 2020, 08:36:22 PM by Brent Williams »
« Reply #5 on: December 01, 2020, 09:22:58 PM »
Offline fred cesquim
    • Fred Cesquim Aeromodelos
« Reply #6 on: December 02, 2020, 05:47:58 AM »
Randy, this is one of the coolest airplanes ever! will start mine next year, i plan to do a full body, electric ship
what have you used as a landing gear?
cool design man, will follow here!
regards from Brazil
« Reply #7 on: December 02, 2020, 09:12:49 AM »
Fred,
I designed and built a carbon fiber gear. Unfortunately, the mold was made from a prototyping material and I was able to pull about 5 legs from it  before it sort of crumbled. I still have the plug and am planning to make a new mold. I'll post a picture later.
Never thought about doing a full fuselage version. Maybe I'll draw up a Super Ringmaster version. Hmmm....
Last one looked like this. OS .40VF and pipe. This is the canted engine mount setup.
Offline Larry Wong
« Reply #8 on: December 02, 2020, 10:40:02 PM »
Randy I did it to the 526 RM  made it a Super
Larry
« Reply #9 on: December 03, 2020, 10:12:39 PM »
 Thanks Randy, really looking forward to watching this one, a great way to start forgetting 2020.
« Reply #10 on: December 07, 2020, 04:45:13 PM »
I'm still having fun. Fuse is about 75% done. Tail plane is cut out and ribbed, the hinge pockets installed but not shaped. Built the rudder and ribbed it. Also not shaped. Next up is to start the wing. I usually do that first but for some reason, I did the other stuff this time.
Edit: the battery box in the one picture was just sitting in there to set spacing correctly. It will be in line with the motor.
« Last Edit: December 08, 2020, 11:56:06 AM by Randy Powell »
« Reply #11 on: December 07, 2020, 07:16:47 PM »
Hope this one has all the problems solved you had with past planes. D>K
« Reply #12 on: December 07, 2020, 07:34:23 PM »
 Looking good! What's the framed up bird hanging above the Cobra?
« Reply #13 on: December 08, 2020, 08:29:28 AM »
Curious about the motor mount.  Are you using a shaft extension?
« Reply #14 on: December 08, 2020, 11:54:35 AM »
Doc, no more problems than anyone else. This plane is being built from the original templates. There is no plan, per se. Pat Johnston drew up plans that are very similar, but not the same. Close though.
Motorman, It's about 630 square inches and Pat Johnston has plans. patsplans@yahoo.com
WWWarbird, That is another plane awaiting me getting around to it. It was the Slider V.3. Due to an argument with a bat, the finish, ah, had problems and the plane came out way, way too heavy. mostly due to paint. It was stripped and the nose and some other areas reworked. I'll finish it at some point.
Ken, It's front mount electric this time. I'm sort of freelancing the nose construction.
« Reply #15 on: December 08, 2020, 12:49:35 PM »
I thought I was the only bat victim. In my 20's I lived in an old "plantation" house with a belfry.  We had bats.  My shop was in the basement next to the old coal furnace that no longer had a door.  They would get into the chimney and pop out into my shop.  Tissue and silkspan had no chance, I feel your pain.
This ship is looking great.
« Reply #16 on: December 08, 2020, 01:57:27 PM »
I had just shot catalyzed polyurethane and it was curing in the shop. It was late summer and the shop door was left open. Apparently the bat flew in, was overcome by the fumes, fell out of the air and rolled down the top of the plane. I found him dead on the floor of the shop a couple of hours later and the entire top of the plane had little holes and smudges and crap. Had to be sanded, repaired and reshot with clear. That's why the finish was way overweight. Next plan I built had bat wings on it was was called, privately, the Batplane.
« Reply #17 on: December 08, 2020, 07:37:00 PM »
 Looks cool, another one to keep an eye out for here, thanks for the scoop!
« Reply #18 on: December 09, 2020, 10:56:38 AM »
A note on the RMD. Not sure if I made this clear. Pat Johnston has a set of plans for it and they are very close to the original bird. I never really did plans for the plane. I drew up enough so that I could build it, I know what I was thinking when I drew it, then cut up that "plan" into templates. I sent the original templates to Pat and he drew it up. That plan is very close but there are a couple of differences. Nothing that really changes the look or how it flies. I endorse Pat's plan. Besides, he can laser cut it into a kit.
I'm really freelancing with this new RMD. It's going to be electric and I'm sort of making it up as I go along. I've already had to back track a couple of times, had a couple of "well, that's not going to work" moments, but that's all part of the fun.
Hope that's clear.
« Last Edit: December 10, 2020, 08:51:41 AM by Randy Powell »
« Reply #19 on: December 09, 2020, 06:11:50 PM »
Hope that's clear.
 Yep, seems normal to me.  :)
Offline Mike Griffin
« Reply #20 on: December 12, 2020, 07:37:06 PM »
Randy, before Allan Perret passed away, i got with him and thought the one he built was beautiful and flew excellent.  I got the plans from him and built one.  A member in my club made me an offer that I could not refuse and I never got to fly it.  If I ever decide to build and fly again, the RMD would be the one i would build but I doubt that day will ever come. It is a wonderful design Randy.
« Reply #21 on: December 14, 2020, 09:06:38 AM »
So, a bit more progress. Still figuring some stuff out. I should have just ordered Pat's electric front end.
« Reply #22 on: December 14, 2020, 08:49:25 PM »
 It's an I-beamer? The original design is for a sheeted L/E or "D-tube", right?
 I love the I-beam look but I've never had the guts to do one. Also, I thought you had to start with the main spar and then build around that. Hmm.
« Reply #23 on: December 14, 2020, 09:19:53 PM »
If still available get Billy's video on building I beam wing plane.  If I remember right it starts with the fuselage, then spar, leading edge and trailing edge.  Much easier to do than it looks. D>K
« Reply #24 on: December 15, 2020, 09:41:44 AM »
Not an I-Beam. Based (loosely) on the Millennium wing design. Drop rib strips on one side, Flip it over, drop the top of the spar on, do the rib strips, flip it back over, drop the other spar top on then put in the truss between the spar tops. Put in the control system, then put sheeting and cap strips on.
The first RMD was done this way. The second one was done with laser cut ribs from Pat Johnston. I like this better.
« Reply #25 on: December 15, 2020, 08:16:56 PM »
 Wow. I recall hearing of the Millennium wing design now but don't recall ever knowing or seeing a step by step, please keep us updated with some pics as you progress.
« Reply #26 on: December 16, 2020, 09:25:37 AM »
Tom Morris designed the system. He uses a solid plank spar in the middle. They way I do the spar is simpler and works pretty well.
He's a pic that may make it clearer. This is as far as I've gotten.
« Reply #27 on: December 18, 2020, 09:47:35 AM »
Coming along.
« Reply #28 on: December 18, 2020, 07:25:58 PM »
 This is pretty cool, looks really fragile to me though unless shear webs are in the plan? You must have removed it from the jig to flip it over?
« Reply #29 on: December 21, 2020, 09:59:05 AM »
I used magic to flip the wing.  ;D
Here's the answer to that other thing.
Online Steve Helmick
« Reply #30 on: December 22, 2020, 01:40:25 PM »
So, "RMD" does NOT stand for "Ringmaster (of) Mass Destruction"?   @@^ Steve
« Reply #31 on: December 22, 2020, 01:54:07 PM »
Steve,
Not yet. Maybe later considering my luck.
« Reply #32 on: December 22, 2020, 02:00:47 PM »
Here's how far I got last night.
« Reply #33 on: December 22, 2020, 02:26:10 PM »
Randy, what's the stuff covering the rear of the fuselage sides? It looks like balsa, but maybe 1/64" plywood? I remember Mark's Profile Impact being covered with balsa and light fiberglass (or CF?) and how it was proven to flex with Howard's mini-camera dingus. In that case, I suspect that having the pushrod & horns enclosed and on the fuselage centerline would have reduced the problem, but not totally eliminated it.
I used 1/64" plywood on one, and it made it stiff as a pine plank. Haven't heard anything from Mark lately...I hope he's ok.  y1 Steve
« Reply #34 on: December 22, 2020, 02:39:22 PM »
in the previous pics, you'll see the internal structure that includes carbon fiber bracing. That's 1/8" balsa mounted diagonally and reversed on each side in opposition to prop rotation.  We'll see what happens. It's how the first RMD was built.
« Reply #35 on: December 22, 2020, 09:04:42 PM »
 Making sense now, looks great. I see too now that it gets sheeted like a "normal" wing.
 Not saying you should have but just curious, do you think the design would be strong enough to skip the sheeting and go right to covering, to have it end up looking like a regular I-Beamer?
Offline Angelo Smyth
« Reply #36 on: December 23, 2020, 05:38:09 AM »
Hi Randy,
Quick question here - I like the jigs you're using......where can I get those slotted, aluminum angles that are in the pictures? Those look like the ticket!
-A.
« Reply #37 on: December 23, 2020, 08:45:40 AM »
Wayne,  I've built this same wing without sheeting or with much less sheeting. Works fine. I would probably run carbon fiber down the spar caps if I didn't use sheeting.
Angelo, Well, I made them. I picked up some aluminum angle stock, cut 1" pieces. I have a benchtop mill and cut the slots myself. I have a bunch of different cleats that I use depending on the sort of leading and trailing edges the wing has.  The base is a piece of melamine I got from Lowe's Home Center and used a router to cut the slots. It's a simple but effective system.
« Reply #38 on: December 23, 2020, 09:45:07 AM »
Thanks Randy. Guess it's time to get a benchtop mill and router!
-A.
« Reply #39 on: December 23, 2020, 10:19:00 AM »
Angelo,  I use the mill all the time to make various parts. If you see the bellcrank, I machined that from a chunk of aluminum. Once you get used to using the thing, there are all kinds of stuff you can make.
And now, I get to make the landing gear. That will be fun.
« Reply #40 on: December 23, 2020, 10:39:45 AM »
What kind of mill do you have?  I was a machinist in my youth but most of my experience is with lathes and screw machines.  Limited millwork but I have done some.  If you have a decadent mill do you need a router?
I am about to embark on making some logarithmic horns just using a Dremel and some files.  I love to tinker.
« Reply #41 on: December 23, 2020, 11:52:31 AM »
Mine is a Taig mill with Morse taper head, though I have a standard chuck for it. I've had it for a very long time. I've accumulated a lot of tooling over time. That helps a lot. I've got a lot of tooling from Sherline.
The router was for cutting slots in the melamine board for the base.
« Reply #42 on: December 23, 2020, 06:57:40 PM »
 Cool, I suppose that trussed spar ends up being pretty sturdy.
« Reply #43 on: December 28, 2020, 12:28:42 PM »
So, here we are. The nose is rough as I left a lot of meat on so I can block it down with his assembled.
« Reply #44 on: December 28, 2020, 12:29:33 PM »
Here's the tail with machined aluminum horn.
« Reply #45 on: December 28, 2020, 03:18:05 PM »
More pictures of the original
« Reply #46 on: December 28, 2020, 03:34:53 PM »
Yep, the original edition.  ;D
« Reply #47 on: January 04, 2021, 10:55:43 AM »
For anyone interested, couple more pics.
« Reply #48 on: January 04, 2021, 07:43:14 PM »
 Not true to design I know, but the more I watch here it looks like building a full-fuse would have been easier.
« Reply #49 on: January 05, 2021, 10:17:58 AM »
Yea, wish I'd done the nose differently. But hey, we'll see how it comes out.
