  • June 13, 2025, 07:53:19 PM
Author Topic: Silkspan and Hinges  (Read 2117 times)
Offline t michael jennings
  • AMA 83322
Silkspan and Hinges
« on: June 22, 2009, 12:37:27 PM »
Gentlemen,
Just completed the horizontal stabilizer and elevator.  Plan to use polyester hinges for the two surfaces.
Do you put Silkspan on the surfaces before installing the hinges?
Thanks.
t michael jennings           D>K
Knoxville, TN
Re: Silkspan and Hinges
« Reply #1 on: June 22, 2009, 12:56:59 PM »
I use these all the time. I put the hinges on before covering the surface with silkspan.
Don
Online John Miller
« Reply #2 on: June 22, 2009, 01:06:21 PM »
I believe the best way to install cloth type hinges is to first cover the edge, the part facing the stab or elevator, first with whatever you are covering with. (This also works for MonoKote hinges)
Next, install the hinges.
Finally instal the covering over the hinge material to the edge.
Your hinge material is covered over with a solid covering, which helps grrip them better, and softens the outline, making them blend a little better.  H^^
Offline James C. Johnson
« Reply #3 on: June 24, 2009, 11:35:48 AM »
Here are my taffeta hinges on my Oriental.. I use masking tape to get them even, on the top only. I doped these on, but have thought about using spray glue or Balsarite.. This is the neatest and quickest hinging method I have ever used... plus it "turns out perfect" for deflection.. I put three coats of clear on and then use a mix of 80% thinner and 20% clear to adhere them.. I do one side at a time. Be sure to snug the surfaces up tight or you end up with a loose hinge.. the beauty of these hinges is 2 fold.. a square yard of taffeta is $3.00, enough to do 50 planes.. and they are forgiving, if you make a mistake .. just paint some lacquer on them and start over.. be careful not to sand through them.. extra clear won't hurt a bit.. I use Nitrate but you can use low shrink or regular dope.. No Nitrate over regular dope... but you can paint regular dope over Nitrate..
The hinges on the elevator are 1" in width and 2 1/4" long
The flaps are 1 1/2" wide and 2 1/4" long ..
I would only use iron on plastic hinges on .049 -.10 sized planes. I have seen it on some larger planes but that is just what I would do... there could be a whole article done on just hinges..
Jim
The Elevator
The Flap
Offline afml
« Reply #4 on: June 24, 2009, 12:31:52 PM »
Hmmm......
Blood stains.........
NOT A GOOD SIGN!    LL~
B CAREFUL WITH TOOLS!  y1 #^
Thanks Jim for the pics!
I do like the full length hinges.
"Tight Lines!"
Wes
Wes Eakin
« Reply #5 on: June 24, 2009, 03:24:08 PM »
I also prefer the polyester hinges, no oil leaks into the wing and hinge line is sealed. This is my method. I put about 4 or 5 coats of nitrate dope on the edges and about 1/2 inch back from the hinge line. Cut a bunch of hinges, about .8 wide by about 2-2.5 long. If you have a problem with the poly fraying as you cut it, you can give it a real thin coat of clear dope. I put all the hinges, alternating top and bottom on one side of the joint first. Lay one in place and hit it with a brush wet with acetone, instant stick! add the rest the same way. Now bring in the other part and clamp in proper alignment and just go down the line and stick these, checking each one to be sure it is smooth and not puckered. If not right, hit it with the juice and redo it. When all finished, take a six inch steel rule and lay it on the hinges with one edge a half inch from the hinge line. Take a fresh #11 Exacto blade, pretend you are a surgeon and just cut thru the polyester and lift the tag ends off. If they stick a bit hit them with the magic juice and they will come right up. Don't fret about slight cuts in the wood, it's going to get filled with dope and then covered with silkspan anyway. This will work really good on a Skyraider.
Offline afml
« Reply #6 on: June 24, 2009, 05:09:46 PM »
"This will work really good on a Skyraider."
I heard that!!!  y1
 #^ H^^
"Tight Lines!"
Wes
Wes Eakin
« Reply #7 on: June 25, 2009, 05:41:20 PM »
It's getting close. Should be done next week and you will get the first copy pronto!
Don
Offline Balsa Butcher
  • High Desert Flier
« Reply #8 on: June 26, 2009, 09:35:15 AM »
A trick I use is to lay a piece of masking tape about 1/2" or so along the surface that you are going to attach the "cloth" hinges to. Then glue the hinges to the surface, they will overlap the masking tape. When dry, use a sharp blade and cut along the edge of the tape. Lift off the tape and the cut ends of the hinges will come with it. The hinges that remain will be even and have a sharp, non-frayed edge. Not my idea, read it somwhere, it works!  8)
Pete Cunha
Sacramento CA.
AMA 57499
Offline Ralph Wenzel (d)
« Reply #9 on: June 26, 2009, 11:09:27 AM »
A long time ago (late '60s) Lew MacFarland taught me to use un-inked typewriter ribbon for hinges. It comes on 1000' rolls. It's nylon, about .004 thick, woven to eliminate unraveling and very smooth. It's so thin that it practically vanishes under 4 coats of Nitrate clear, and is completely invisible after covering/painting. The only disadvantage is that it's aabout 5/8" wide, so it takes a lot of hinges. I've been looking for a new source, as the old one (IBM) quit making ribbons a bunch of years ago, and I have only about 1/3 of a roll left.
Ralph Wenzel
AMA 495785 League City, TX
« Reply #10 on: June 27, 2009, 09:06:54 AM »
I just had to look and found this on a google search. Is this the stuff? I see there is silk or it was made also at one time..
Huzhou Fulihua Copying Ribbon Co., Ltd.
NYLON66 Ribbon
http://www.madeinchina.com/72872/P5287381/ribbon.shtmlI
Jim
« Reply #11 on: June 28, 2009, 10:31:00 AM »
Good find, Jim! What I use is closer in appearance to the stuff in the inset photo, without the lines. I'd like to see the specs on this stuff (thickness), and see if it's were possible to order a roll (not a case). Ah well, the 300 - 400 feet I still have may prove to be a "lifetime supply" . . .
Ralph Wenzel
