  • June 19, 2025, 03:24:53 AM
Author Topic: Sterling Yak-9 kit, trouble building the wing  (Read 3810 times)
« on: June 18, 2013, 12:31:03 AM »
I'm just getting started on a Sterling Yak-9 and already have a problem with the wing. All of the old kit plywood parts have de-bonded so I'm using fresh ply to re-make them, including the rectangular braces behind the angled LE joint and the center joint of the two spar sticks. My birch ply is much stiffer than the old kit wood. The plans say nothing about the spar being angled at the center joint, but when the ribs are slid onto the spar and fitted into the slots in the LE, the spar has to be pulled tightly into a bowed shape to fit. You can see in this picture of the dry-fit parts, I used rubber bands to pull the outer ends of the spar into place so the outer ribs will reach their slots. None of them have been glued.
This is just waiting to spring loose and gut every rib the first time I bounce off its nose. I've been known to do that. The plans show the spar assembled straight. If that's right, then the spar holes in the ribs are placed incorrectly. I could cut the spar back in two and glue the center together at the correct angle. Or I could just leave it out. Or open up the holes on the ribs to let it fit straight. I know a lot of Yaks have been built here at Stunthangar, so I'm open to any thoughts on which option is best. Has anyone run into this in a Sterling Yak before? I could search out no mention of it. What do y'all think of leaving the spar out completely?
Rusty
Offline Jim Thomerson
Re: Sterling Yak-9 kit, trouble building the wing
« Reply #1 on: June 18, 2013, 08:00:54 AM »
It's been some 30 years since I built mine.  I don't recall this problem. From what you say, I think I would cut the spar in the center and brace it up.  Definitely don't leave the spar out.
Offline Paul Wood
« Reply #2 on: June 18, 2013, 08:04:29 AM »
Rusty,
I would just open up the rib holes a little and then glue a small rib doubler behind the spar to hold the spar tight in the rib.  I would not leave the spar out.  It looks like the rib holes are cut incorrectly.  Odd... I've never seen that before.
« Reply #3 on: June 18, 2013, 08:57:11 AM »
It has been many, many years since I had mine, but I don't remember having to bend the spar.  I would just open the holes in the ribs enough to get the spar straight.  Scrap pieces of balsa to fill the void.
« Reply #4 on: June 18, 2013, 09:38:16 AM »
Thanks for the replies.
I hope to make some time to spend on it this evening. If I get anything accomplished I'll post back with whatever I work out.
Offline Balsa Butcher
  • High Desert Flier
« Reply #5 on: June 18, 2013, 10:16:09 AM »
If cutting it in 1/2 at the center will give you a two piece angled but unbowed spar instead of a one piece bowed spar, do what Jim suggested. Re-join and reinforce at the center. Easier than cutting new square holes. 8)
Pete Cunha
Sacramento CA.
AMA 57499
Offline 55chevr
« Reply #6 on: June 18, 2013, 10:31:42 AM »
Rusty,
The Sterling kits that I built had the worst wood and fit of any manufacturers product I assembled.   I throw better wood away then they used.   I had to replace a lot of pieces when building their kits.  I am rebuilding a Ringmaster that my son built 25 years ago and the profile fuselage has saw marks on the sides.  The wood was never planed.  Sterling used nice designs but terrible materials.
Joe
Joe Daly
« Reply #7 on: June 18, 2013, 11:56:20 AM »
I bet it will. That's the first thing I intend to try. Not surprisingly the TE sticks were cut with the wrong angles too.::) Heck, this kit might be older than me, for all I know I have half Mustang parts.
Rusty,
Joe
I've heard about that Sterling wood. Before I start on the rest of the plane I'm going to weigh the fuse and see if I can eliminate a couple of ounces. Right now it's sitting on the table atop a pair of pencils with a mini sledge hammer head bowing it back straight.
Oh please, if the member who gave me this kit sees this thread... Cribbs, please take no offense. You know I love a challenge.
Rusty
  • High Desert Flier
« Reply #8 on: June 18, 2013, 12:04:01 PM »
Please, don't go into a "lightening hole" frenzy. It will be easier to just cut a new fuselage. If you can't find any 1/2", two 1/4" pieces can be epoxyied together to make a very strong, and straight (if done correctly) piece. 8)
Pete Cunha
Sacramento CA.
AMA 57499
« Reply #9 on: June 18, 2013, 12:08:11 PM »
No, no holes. I would worry about integrity as I'm not a structural engineer. There are several sources of balsa in town, and if not, there's always Sig.
« Reply #10 on: June 18, 2013, 06:51:08 PM »
Thanks Ty. My skills improve with every build. I'm finally at the point where I have a pretty dependable little fleet because either I fly them better or build them to fly better. Or a bit of both. At least I don't spend so much time repairing any more.
I went out to the shop this afternoon and cut the spar back in half. I'm not sure what kind of wood it is, but it's harder than balsa. Anyway, I threaded one side of the ribs back onto it and fitted them into the LE, and the TE fits right up. So since it all fits, I can sand that angle where the two spar sticks butt, glue them back together, and build it that way.
Offline Gary Mondry
« Reply #11 on: June 18, 2013, 09:18:13 PM »
I'd guess that you joined your leading edge with inadequate sweep, forcing the spar to sweep forward to accommodate.  That you think your trailing edge join angles are off reinforces that suspicion.  How confident are you of your leading edge join angle?
AMA 10663
« Reply #12 on: June 19, 2013, 10:05:49 AM »
There is a ply biscuit that presses into a slot cut in one end of each LE stick. I test fit it and walked it into place pressing with my thumbs and once it was fully seated, the butting ends were perfectly flush. Had you not asked, I would have said 100% confident, based on how smooth the transition is across the joint. There's barely a visible seam. Consider that there is about an inch of bow from the spar center to each end. That would create a helluva gap in the front of the LE if it were adjusted to follow those lines.
I tried every combination of butting the TE sticks together, and there's only one way that comes close, but it is off by a couple of degrees. You could be right though. I assembled the LE as it was cut, but maybe it was cut at the wrong angle rather than the TE.
One or the other is wrong. If I wasn't going to use the flaps, I'd just say, heck with it, let's glue. But I want to make sure the TE is no more forward swept than designed, or I'm going to have trouble with binding controls.
Here's a picture of the TE joint with the sticks roughly aligned with the rib ends. It supports your thoughts. I'm going to take a protractor and measure the angles on the tiny pictures on the instruction sheet and see which angle is off.
« Reply #13 on: June 19, 2013, 10:59:07 AM »
Now that I think of it, some of my Goldberg kits were similar to the Sterling kits as far as construction.   I guess that is why I  build in my lap on these planes.  Fit all the pieces together, held together with pins, tape and what ever until I get things matched up.  Then I use the glue.   Also I remember that the Sterling kits you had to align the leading edge over the little drawing on the plans to get it right.  I think now I remember there was always a gap in the leading edge at the front.   The spar was straight and the trailing edge was as close as you would expect.   Even my Goldberg kits had same problem.
Offline Gary Mondry
« Reply #14 on: June 19, 2013, 12:08:47 PM »
Rusty,
This evening I'll dig out my plans for the Sterling Yak-9 that I recently got from Barry Baxter and measure the sweep for you.  As I recall, it's not trivial.  I can't view your picture here at work but I will be able to from home.  I'll let you know.
« Last Edit: June 19, 2013, 01:24:28 PM by Gary Mondry »
AMA 10663
« Reply #15 on: June 19, 2013, 03:07:35 PM »
Even on the little kit plan diagrams you should be able to measure the angles of sweep on the leading and trailing edges.  I really think the Sterling Yak 9 is not a good airplane for your first flapped airplane. If I were to build another today, it, like the first, would not have working flaps.
« Reply #16 on: June 19, 2013, 04:41:23 PM »
Gary, Jim and TY,
Looks like about 5 degrees on my glued LE, and closer to 8 degrees on the picture. It fit so well, it just had to be right. I wasn't going to glue anything else. To add insult to injury, it's epoxied because my ply brace(not the biscuit) was so stiff I wanted to make sure id couldn't pop back off. I usually only use epoxy sparingly, but this was an unfortunate exception. HB~>
Not a good first flapped plane... yes I have to agree, Jim. But I'm sure I've left you shaking your head at my folly, or stubbornness, or both, so here we go again. I have to learn the hard way. Besides, maybe I'll learn how to make Lucky Boxes.
Funny, Ty, maybe a good last plane. ;D
I do, however, have a plan. :! You purists ain't gonna like it, but it'll fly just fine. I will leave the LE like it is, and make a new TE with a trapezoidal shape that returns the forward sweep to its original angle. Or maybe I'll get wild and reduce it, allowing for easier flap hinging.
I appreciate all of your help. It's going to have to wait till after my vacation now. It's time for my second hobby, surf fishing.
Rusty
Offline Gary Mondry
« Reply #17 on: June 19, 2013, 10:02:05 PM »
Rusty,
I measured my plans by placing a yardstick with the ends just touching the back side of the leading edge and the 18" mark on the centerline.  The leading edge joint was 1-7/16 forward of the edge of the yardstick.  This calculates to about 4 1/2 degrees sweepback on each side.  I also measured the trailing edge sweep the same way.  The trailing edge joint was 1-3/32 aft of the edge of yardstick.  This calculates to about 3-1/2 degrees forward sweep on each side.  The spar is straight.
AMA 10663
« Reply #18 on: June 20, 2013, 10:11:58 AM »
Rusty,
Thanks, Gary. You nailed the culprit. My Lead edge sweep is too shallow.
When it starts looking like a plane, I'll post back and show what I've got.
I appreciate you and everyone else taking the time to help me out.
Rusty
