  • July 30, 2025, 03:41:47 PM
Author Topic: Sig Mustang Stunt  (Read 10372 times)
Offline Tom Dugan
Sig Mustang Stunt
« on: March 06, 2006, 06:48:33 PM »
Came upon to good a deal for a Sig Mustang Stunt...couldn't pass it up.  I have read some threads on construction of the Sig Magnum but couldn't find anything on the Mustang.
Does anyone know of any information/threads about construction of the Mustang Stunt?
Thanks...Thomas
Offline Ironbomb
Re: Sig Mustang Stunt
« Reply #1 on: March 07, 2006, 07:12:46 AM »
I have one myself, and will be building it after the online build project. I have been told that it flys pretty good if you replace the plastic pieces with wood. Replace the heavy wood. And core the wings. I am sure there are other improvements that can be made.
I was also going to sheet my wing with 1/20th instead of the 1/16th, and not use the blue contact cement that was recommended in the instructions.
hope this helps, happy building
Greg
Beating the crap out of the ground, one airplane at a time
Greg Bossio
AMA 834382
« Reply #2 on: March 07, 2006, 11:05:52 AM »
Hi Thomas,
About 10 years ago, we scratch built one of the Mustangs using Jim Lee's modifications.  It is a good flying plane.
« Reply #3 on: March 07, 2006, 07:24:49 PM »
The Mustang stunter is a cool plane, but somewhat dated and the kit builds extremely heavy.  The small wing + excessive weight = undesirable.   If you replace most all the kit wood, substitute wood for the plastic, core the wings, stretch the tail and stretch the stab/elev and it'll fly well.
We built two, the first came out extremely heavy and does basic maneuves (wingovers and loops) but anything more serious (overheads) isn't possible.  The second has all the usual modifications and then some and it's never been finished.  With a 35-40FP it's overpowered, and its really too heavy for a Fox 35.
It's a neat kit, but I've seen a bunch of them built that didn't amount to anything.
« Reply #4 on: March 08, 2006, 07:26:24 AM »
I had two of the Mustang Stunters.  The first one was lost because i mounted bellcrank according to instructions.  The second one was built using modified bellcrank mount.   The bellcrank was centered on a bolt more than long enough to go thru the wing and plywood pads.  The pads were on the top and bottom surface of the wing.  The first one was 41 ounces, the second was close to 45 with heavier finish.  Did not core either one and they were more than capable of doing the pattern.  Power of course was the old standby Fox 35 Stunt.   Later, DOC Holliday
« Reply #5 on: March 08, 2006, 11:13:31 AM »
I'd second Andrew on this one.  A pretty looking design, but usually way too heavy for pleasant flying.  If you can build it down around 40 oz. it should do well, even without any aerodynamic mods.
Offline Jerry Bohn
  • ACE
« Reply #6 on: March 08, 2006, 11:32:35 AM »
Is the Sig Mustang kit still avaliable? I could not find it on the Sig web site.
Jerry
Jerry Bohn
Offline Leester
« Reply #7 on: March 08, 2006, 12:28:25 PM »
Nope
Leester
ama 830538
Offline Ironbomb
« Reply #8 on: March 08, 2006, 12:39:02 PM »
The kit is out of production, but they do pop up on ebay from time to time. I have seen them go for anywhere from $200, I was in on that bid, and escaped) to as little as $60.
good luck in your hunt
Greg
Greg Bossio
AMA 834382
Offline 50+AirYears
« Reply #9 on: March 09, 2006, 11:08:02 PM »
Great to read about weight problems, now that I finished the partly built one somebody gave me.  Guess I'll have to weigh mine now.  It actually has a Super Tigre 35S in it.  I'll be curious to see how it flies.  The comment about the bellcrank mounting has me worried, though.
Tony
« Reply #10 on: March 10, 2006, 08:48:23 AM »
FWIW I never had a problem with the bellcrank mount, built according to the plan it has stood up just fine.  I probably wouldn't do another that way, but it never failed.
