  • July 08, 2025, 06:52:40 AM
Author Topic: Sig Mustang  (Read 2855 times)
Offline Bill Smith
Sig Mustang
« on: September 30, 2007, 04:55:03 PM »
I've got a Sig Mustang kit. any advice on building it?
It looks like I could do some stuff to lighten up the wing.
steven yampolsky
Re: Sig Mustang
« Reply #1 on: September 30, 2007, 07:09:50 PM »
1) mold as many parts as you can. Avoide using plastic parts at ALL costs
2) sheet the wings with 1/20 balsa and send them to get cored afterwards
3) carve wingtips out of balsa
4) Get Constrol system from Tom Morris
General idea is to keep the weight down. replace all plastic and keep an eye on balsa kit parts. Replace any wood that's over 8 pounds.
Offline wmiii
Re: Sig Mustang
« Reply #2 on: September 30, 2007, 08:33:41 PM »
  What he said. If you don't mold the parts. then use the best balsa you can find, carve & hollow the blocks.
 Walter
walter menges
Re: Sig Mustang
« Reply #3 on: September 30, 2007, 09:19:32 PM »
What these guys said.
Two more things from Jim Lee, copied by Dan McEntee and Mark Hughes in their very good flying Mustangs;
increase the stab/elevator span 3 inches (draw a new one with the root and tip chord the same, just 1 1/2 inches longer each side and;
increase the tail moment 1 inch.
These changes will carry the mufflers and a little heavier engine very well.
Chris...
Re: Sig Mustang
« Reply #4 on: September 30, 2007, 10:00:12 PM »
Also, redesign the nose section for a crutch and slide in tank.
I streched the tail moment 1" on mine. I decided to not enlarge the stab/elev span because it made the model look stupid.
......and use a 3.5" suspended bellcrank.
« Last Edit: September 30, 2007, 10:30:44 PM by Clint Ormosen »
Re: Sig Mustang
« Reply #5 on: October 01, 2007, 09:53:52 AM »
The stock Sig Mustange uses a bellcrank mount glued to the foam, without any structure tying it to the sheeting.  Don't do it.  Use ply pads on top of the sheeting and run the bellcrank on a through shaft(be sure and lock the through shaft in place so it can't work its way out.)  Saw a plane crash a couple months ago when the through shaft bored a hole through a 1/8 in. 5 ply cap and let the bellcrank slip down and lock up.
Offline Bill Smith
Re: Sig Mustang
« Reply #6 on: October 01, 2007, 06:15:36 PM »
Lots of good ideas thank you all.
I'm cleaning my shop out now then I have to spread this out and compare ideas with kit.
Hope I don't screw this up.
Offline Leester
Re: Sig Mustang
« Reply #7 on: October 01, 2007, 07:00:22 PM »
Bill: I think your on the right track to NOT screwing it up by asking here. Any problems or more questions ask first.
Leester
ama 830538
Re: Sig Mustang
« Reply #8 on: October 02, 2007, 12:56:16 AM »
Here's my Sig 'Stang getting ready for paint.
Re: Sig Mustang
« Reply #9 on: October 02, 2007, 12:59:59 AM »
The bottom. ;D
Alan Hahn
Re: Sig Mustang
« Reply #10 on: October 02, 2007, 01:23:21 PM »
Bill,
Ask Fred K. at the Treetown meeting tomorrow. His Mustang was derived from Jim Lee's numbers on the Sig Mustang.
I won't be there tomorrow. I am typing this from Geneva----Switzerland, not Illinois  #^ .
Alan
Offline Bill Smith
Re: Sig Mustang
« Reply #11 on: October 02, 2007, 04:43:26 PM »
nice job Clint
any idea what the weight might end up at?
Alan I remember Freds Plane but didn't he do a built up wing??
Re: Sig Mustang
« Reply #12 on: October 02, 2007, 06:30:37 PM »
Right now it's on track to be 43-44 oz. with a Brodak 40 in it. That's if the finish doesn't get too heavy.
Alan Hahn
Re: Sig Mustang
« Reply #13 on: October 03, 2007, 01:20:45 PM »
Yes he did build up the wing. I am not sure how much weight that saved him, but I thought it was nominally the same airfoil as the foam wing. But he'll tell you.
Alan
Offline Mike Spiess
  • bikemike
  • AMA #4060
Re: Sig Mustang
« Reply #14 on: October 08, 2007, 11:21:12 AM »
Mike Stotts he built for the catalog photos.
You don't stop flying cause your get OLD
You get OLD cause you stopped flying
St Peter MN
Present Master of the Figure 9
Re: Sig Mustang
« Reply #15 on: October 08, 2007, 12:53:45 PM »
UMM ARENT THOSE PICTURES OF THE CHIPMUNK?
Offline Bill Smith
Re: Sig Mustang
« Reply #16 on: October 18, 2007, 06:17:23 PM »
Sorry for the time lag in responding to all the comments and emails. I want to thank all of you who took the time to respond. I have a good idea of what needs to be done now, and have it all written down. Now all I have to do is find time this winter to do it.
Re: Sig Mustang
« Reply #17 on: October 18, 2007, 09:19:53 PM »
Bill, be sure to post your progress. Building pictures are great.
