  • July 08, 2025, 07:37:40 PM
Author Topic: side mounted engine work bench  (Read 2944 times)
« on: May 27, 2013, 03:13:02 PM »
I'm in the process of mounting the engine in the Pawnee project and it hit me that maybe there are guys who haven't thought of the barrel concept for ease of working on a side mounted engine.  a flying buddy, Larry Krauss introduced this to me over forty years ago and I've used it ever since.  The pictures are self explanatory.
You'll notice I move the plane so the screws won't fall into the barrel when (not if) I drop one!  HB~> HB~>
Re: side mounted engine work bench
« Reply #1 on: May 27, 2013, 03:51:51 PM »
That's good.  That's one of those things that's just totally obvious, but only after you've seen it.
Thanks for posting that.
« Reply #2 on: May 27, 2013, 04:12:37 PM »
"Good" Will Hinton,
It's those simple things that aren't generally thought about.
Great Idea, and there's plenty of models with side mounted engines .
Thanks for that.
Charles
« Reply #3 on: May 27, 2013, 08:18:07 PM »
Ty, your last procedure mentioned is best done in a metal barrel and with matches.  At least you get a little final closure that way, right?  LL~ LL~ LL~
I thought the same way all you fellows did when Larry showed me, it just is too simple and I felt the old "duuhh" feeling.
Online Geoff Goodworth
« Reply #4 on: May 28, 2013, 03:04:51 AM »
I use a Black & Decker Workmate for exactly the same purpose. When I drop the screws, they fall on the floor and when I need the space it usually occupies, it folds up to a package less than 8" wide.
« Reply #5 on: May 28, 2013, 07:24:13 AM »
And Geoff, I bet YOUR stand doesn't fill up so you can't use it until you empty it like MINE does. LL~ LL~ LL~
« Reply #6 on: May 28, 2013, 06:24:52 PM »
So true Will, it is, in effect, self-emptying. #^
« Reply #7 on: May 29, 2013, 07:12:35 AM »
That's a good looking airplane Will.  Like to see it fly sometime.
« Reply #8 on: May 30, 2013, 09:02:43 AM »
Thank you Dave, I'm thinking I might even get it done before summer is over!  It's been an even slower project than I thought it would be.  It's sometimes amazing how many ways life can find to get in the way.
I need only to mount the landing gear, cover and attach the flaps and elevators and I can make some noise with it.  Oh, forgot, I am still going to modify the tongue muffler to a cf tube type first.  That won't take all that long.
Offline Douglas Ames
« Reply #9 on: May 30, 2013, 10:32:11 PM »
That's exactly what I need in my small build-room! Great idea, Thanx.
AMA 656546
« Reply #10 on: May 31, 2013, 01:26:33 PM »
My workshop is fully carpeted.  Dropped parts usually disappear completely, to be found only when the shop vac goes over them.  Then, it is usually too late and too tedious to sift through the debris-bag.
F.C.
Offline Jeff Traxler
  • T-Bone
« Reply #11 on: May 31, 2013, 01:51:07 PM »
Hey Dave,It really is a nice looking ship.I'll ditto on the watching it fly.I MISS MY FLYIN' BUDDY!!!!
« Reply #12 on: June 01, 2013, 10:21:03 AM »
Won't work, Jeff, not for a while anyway.  n1  I am seeing light at the end of the cave, though.  If I can get this girl of mine healthy again, I might be able to burn a little fuel. y1
« Reply #13 on: June 01, 2013, 10:24:22 AM »
F.C.
At least you don't have to do what I just did this AM - I scrubbed the whole shop floor with Spic& Span and Comet!  I bought a new pair of winter boots last year that make black marks like I can't believe!  They're goin' bye-bye!  My checkerboard floor is too much work to scrub every single week!!! HB~> HB~>
Offline Allan Perret
  • Proverbs
« Reply #14 on: June 13, 2013, 07:18:05 AM »
I been doing this for years, but I use tall narrow cardboard boxes.  Like the ones your balsa order comes in or the box from a weed eater.  They also work good for just storing models on the floor because of the narrow footprint
Allan Perret
AMA 302406
Slidell, Louisiana
