  • July 11, 2025, 01:23:33 PM
Author Topic: Shop Tip from the Jive Combat Team  (Read 5712 times)
« on: November 28, 2013, 02:31:33 AM »
The Micro-Kerf 40 table saw blade, http://www.rockler.com/how-to/total-solutions-micro-kerf-40-blade-thinnest-carbide-blade-efficient-cutting-power/  , is a wonderful tool for cutting balsa.  It makes convenient 1/16"-wide slots and doesn't waste much material.  When you pass your thumb through the blade as I did this evening, it tears much less meat out than does the usual blade and the wound doesn't bleed as much.  The thumb has been reassembled and will be back in service in two weeks.
Offline dave siegler
  • sport flier
    • Circlemasters Flying club
Re: Shop Tip from the Jive Combat Team
« Reply #1 on: November 28, 2013, 08:14:29 AM »
heal up, ouch
the things that are good at removing wood or metal, remove other stuff as well.
Dave Siegler
NE9N extra class
AMA 720731
« Reply #2 on: November 28, 2013, 09:47:12 AM »
Howard, I thought you knew better.  But, I guess accident do happen.   Some time ago there was a video going around about a safety saw.   Supposedly it would stop when flesh touché the blade.   I never even thought of getting it as I know how videos can be manipulated.
Offline BillLee
« Reply #3 on: November 28, 2013, 10:48:13 AM »
John, this is one time when your pessimism is unfounded. That system does work and almost all table saws are no being offered with it.
Bill Lee
AMA 20018
« Reply #4 on: November 28, 2013, 02:00:52 PM »
Ouch!!! Heal well my friend.
« Reply #5 on: November 28, 2013, 06:02:05 PM »
 Thank you for this excellent tip Howard, and for your personal "testing" of the product, it's always nice to learn of a new and more efficient tool.
 Hopefully, with the better quality of the cut, your digit will heal quicker than normal. :)
« Last Edit: November 28, 2013, 09:10:42 PM by wwwarbird »
« Reply #6 on: November 28, 2013, 08:08:50 PM »
Howard,, the good news is that you are not ready to paint yet,, so you dont have to worry about getting thinner in the cuts,,  ???
take care of them fingers,, you need to be in good flying form this upcoming year!
« Reply #7 on: November 28, 2013, 08:17:58 PM »
Yes, I am a pessimist,  I still can't see how the saw blade can tell when it hits flesh.  Even watched the video several times.
Offline Duke.Johnson
« Reply #8 on: November 28, 2013, 09:00:12 PM »
Sorry to hear this Howard.  Hope it heals soon.
Offline KenP51
  • K Pitts
« Reply #9 on: November 29, 2013, 08:15:20 AM »
There is an electronic sensor sorta of like the that in a GFI (ground fault interrupter). So flesh contact is detected in a very small fraction of a second. That then causes a  part to launch itself into the blade teeth jamming the blade and thus an instant stop. This all happens so darn fast you wont even get a scratch. But you will have to buy a new blade as the original is destroyed to save you injury. I don't know if the violent blade stop causes any damage to the rest of the saw.
A new blade is a very worthwhile sacrifice versus what could happen.
I found out how fast a GFI is a couple of times. A old metal cased hand tool had a direct short from hot side to case. I never felt the slightest tingle, just heard the GFI pop and lost bench power. I am a little slow at times. I reset the GFI and reached for the tool a second time. Then went duh, I think something is wrong here.
But as for me and my house, we will serve the Lord
Offline 55chevr
« Reply #10 on: November 29, 2013, 08:23:42 AM »
There no safety braking system on older saws.  This is relatively new feature.  The safety system that is on new saws will not save you from stitches.  It is supposed to save you from amputation.  USE A PUSH STICK.
Joe
Joe Daly
Offline Allan Perret
  • Proverbs
« Reply #11 on: November 29, 2013, 08:24:30 AM »
Check out the Saw Stop.  They do work, I saw the live demo they do with a hot dog at a woodworking show several years ago.  Barely a knick on the skin of the dog before the blade brake fires to stop the blade and retract it below the table top.   Ever since been keeping an eye out for a used one and finally scored a low mileage one this past summer.
http://www.sawstop.com/why-sawstop/the-technology?gclid=CMaZyM2lirsCFQbl7AodHBMA6w
Allan Perret
AMA 302406
Slidell, Louisiana
« Reply #12 on: November 29, 2013, 09:23:07 AM »
HOWARD!!!!!!! Stop that!!
Offline Jason Greer
« Reply #13 on: November 29, 2013, 05:32:35 PM »
Ouch Howard!! Hope it heals quickly.
El Dorado, AR
AMA 518858
Offline bill bischoff
« Reply #14 on: November 29, 2013, 08:48:05 PM »
An injury like this
is no reason to chortle,
but the Jive Combat Team
has been proven mortal!
Heal quickly, and thanks for making us all think about safety a bit more.
Bill Bischoff
DMAA
« Reply #15 on: November 30, 2013, 08:03:46 AM »
But, you never see them use their actual fingers to stop the blade. S?P
« Reply #16 on: November 30, 2013, 12:11:41 PM »
Don't try actual fingers with a plain saw.
  • Proverbs
« Reply #17 on: November 30, 2013, 12:14:53 PM »
Actually, they did exactly that. Check this link.
Allan Perret
AMA 302406
Slidell, Louisiana
« Reply #18 on: November 30, 2013, 12:42:14 PM »
Could be another use for the Whizzinator.
« Reply #19 on: December 03, 2013, 03:47:59 PM »
You definitely want to keep your Whizzinator away from the saw!
Offline KenP51
  • K Pitts
« Reply #20 on: December 03, 2013, 04:10:53 PM »
And electric fences. Don't ask me how I know that.
« Reply #21 on: December 03, 2013, 04:25:51 PM »
 LL~ LL~ LL~
« Reply #22 on: December 03, 2013, 04:43:41 PM »
Um, I should explain that the Whizzinator is a realistic-looking artificial device used to produce untainted urine samples to pass drug tests.
« Reply #23 on: December 12, 2013, 09:53:41 PM »
Sounds like you're well along in planning for the 2014 WC, Howard.
Missed you at the club meeting. Our waitress asked if you were alright. Mike told her that the stitches had been removed.  LL~ Steve
Offline Dick Pacini
« Reply #24 on: December 12, 2013, 10:20:12 PM »
So, some modeling guru should come up with a similar method to stop a prop from eating your hand.  I'd bet Al Rabe could do it! y1
AMA 62221
