  • August 02, 2025, 07:03:34 PM
Author Topic: Sheeting foam wings  (Read 6026 times)
Offline James Mills
Sheeting foam wings
« on: November 15, 2006, 09:22:41 PM »
What's the best way of sheeting a foam wing?  In the past I've used contact cement (came out heavy), 3M 77 spray, and epoxy.  I have some West Systems epoxy but have never used it for sheeting.
James
Thanks for all the help.
James
« Last Edit: November 16, 2006, 09:47:52 PM by James Mills »
AMA 491167
Re: Sheeting foam wings
« Reply #1 on: November 15, 2006, 09:41:15 PM »
James
I have done   1000s  of foam wings. I have tried  all  ways.
Best I have ever found is  to  paint the inside  wood  with  full thick dope, sand it with  400 paper  then  use  thin  epoxy.
Lightest  best method I have seen.
It also gives you time  to  keep the wings  perfectly  straight, and  recheck them
« Last Edit: December 08, 2006, 01:56:39 PM by RandySmith »
Offline Airacobra
« Reply #2 on: November 15, 2006, 10:52:27 PM »
What type of Epoxy are you using Randy?
Keith Bryant
« Reply #3 on: November 15, 2006, 11:30:50 PM »
I use several types, The one I am using now, is hard to buy, however, you can use  Smooth N easy  ,  or  most any  Finish resin. these  are  very  thin  epoxys  and  spread out  very  well.
Zap makes one  also,  as  well  as  BOB Smith.  which  most Hobby shops  carry.
I have used all of these  with excellent  results
The epoxy you want is  thin,  do not  use  any  acetone  or  alcohol  to thinn  thicker  slow cure  epoxies.
Most all finishing  resins  are pretty thin out of the bottle
If you can't  find  any I do sell thin finishing resin,  just ask
Offline Ron King
« Reply #4 on: November 16, 2006, 06:17:46 AM »
James,
A couple of us also answered your question over on the SSW board.
I agree with Randy: I have used a lot of methods to bond the skins (Sorgum, contact cement, etc.) and epoxy is the best method.
I have used Hobby Poxy 2 (no longer made) and Enviro Tex, but now I use the thin 20-minute Finishing Epoxy from Bob Smith Industries. It's sold at your LHS (usually with their label) and works fine. CAVEAT: It says 20 minutes, but I've never had any set that fast. It really takes a few hours for the stuff to cure. I vacuum bag my wing panels and let them cure overnight.
Take care,
Ron
Ron King
AMA AVP District 4
Wannabe Stunt Pilot since 1963
 Amateurs practice until they get it right; Pros practice until they cannot get it wrong.
Offline Mike Spiess
  • bikemike
  • AMA #4060
« Reply #5 on: November 16, 2006, 07:57:05 AM »
I've used West System with great success.
You don't stop flying cause your get OLD
You get OLD cause you stopped flying
St Peter MN
Present Master of the Figure 9
Offline Jim Morris
« Reply #6 on: November 16, 2006, 10:14:57 AM »
Hello James, dont know if your going to sheet the whole wing. If you are you might consider doing the Tom Dixon method which only sheets the leading and trailing edges then puting strips where the ribs would be. Works very well and is much lighter. I like the 3M spray glue. Hope this helps.        Regards, Jim
Offline Mike Spiess
  • bikemike
  • AMA #4060
« Reply #7 on: November 16, 2006, 10:45:29 AM »
When I was into RC gliders we did wings like Dixon but the used a hot wire an cut out the foam bettween the "rib caps" looked like a built up but lighter than a foam. Used it on many hand lanched gliders.
St Peter MN
Offline Jim Morris
« Reply #8 on: November 16, 2006, 12:12:40 PM »
Thats a good idea also, but you have to leave enough foam to keep its integrity.
« Reply #9 on: November 16, 2006, 10:10:25 PM »
James,
(snip)
Take care,
Ron
Geez, Louise!!!!!  Vacuum bagging!  Doesn't that get a lot of dust, and dog or cat hairs, on them?? Or do you use a new bag??  We have a Rainbow Vacuum, it doesn't have a bag..........
 **) **) **) n~ n~
« Reply #10 on: November 16, 2006, 10:13:11 PM »
Todd Lee used that system on his Opus III which was a Sig Magnum built to look like a "B" Model P-51.  After several years, and countless flights, the area between the "spar" and the trailing edge began to collapse.  It really took on a "Pollywog" rib shape!  (but it still flew mighty darn good!)
Offline Ron King
« Reply #11 on: November 17, 2006, 06:01:25 AM »
Hook it up to a Hefty bag.   **) **)
How about I do a USA-1 with a foam wing? Would that give you a heart attack or what?  f~
Ron
Ron King
AMA AVP District 4
Offline Mike Spiess
  • bikemike
  • AMA #4060
« Reply #12 on: November 17, 2006, 07:23:57 AM »
Mike Stott and his dad did something like that but replaced the "ribs" in the cut out area with balsa ribs cut using the cut  out part as a templet. Similar to lost foam.(wished I payed more attention in typing class back in highschool **) **))
St Peter MN
« Reply #13 on: November 17, 2006, 04:15:38 PM »
"How about I do a USA-1 with a foam wing? Would that give you a heart attack or what?"  f~
Ron
You wouldn't DARE commit such blasphemy!!!!!!!!!  Them's serious fightin' words!!!!!
Offline frank carlisle
« Reply #14 on: November 21, 2006, 04:37:10 PM »
does this look like the right stuff to stick the skins on the wing?
Frank Carlisle
Offline Leester
« Reply #15 on: November 21, 2006, 05:01:20 PM »
Frank: It says on the can do not use on polystyrene foam. What kind of foam are the wings ?
Leester
ama 830538
« Reply #16 on: November 21, 2006, 05:46:47 PM »
DOH!! HB~>
Frank Carlisle
Offline Jim Oliver
« Reply #17 on: November 21, 2006, 07:12:22 PM »
Lost foam wings!!
Jim Oliver
AMA 18475
« Reply #18 on: November 21, 2006, 07:15:28 PM »
Frank Carlisle
« Reply #19 on: November 27, 2006, 05:44:08 PM »
Hey all, the last four stunters I have built were using the tom Dixon "kept foam" method and I tried taking the foam out between the ribs, weighed that foam and found I'd eliminated a whole one quarter of an ounce!  Not worth the effort OR the bit of structural integrity loss involved.  My shipd were all of the tTivial Pursuit design as far as aerodynamics and weighed in at a very consistant 61 to 64 ounces with PA65's aboard.  They all flew GREAT!  I still have the last two, sold the other and mean old mister gravity got one.  I will campaign the last one again next year as my main stunt, it's fourth year.
Blessings,
Will :## y1
« Reply #20 on: November 27, 2006, 08:50:01 PM »
Just to set the record straight on the sheet/capstrip foam wing.  My buddy Dave Noel built the first one of these about 1978, long before anyone else tried it.  He campaigned several different planes over the next 10 years using this construction method before it caught on with anyone else.  He really showed that it was simple and quick, and could support a very nice finish.
« Reply #21 on: December 08, 2006, 01:30:03 PM »
Oh,, oh,, you sayin' somebody else did it?
« Reply #22 on: December 08, 2006, 02:00:18 PM »
It really  goes  back even farther  than that, around  1972 or 3  was the first one I saw  with cap strips
Be careful  not to use  3M  spray.  I have personally seen  many of these  pop loose  and  even come  loose  a  year or  so later.  3M spray  hates  high heat..as in sunshine.
and  some of the 3M  spray  will attack  foam
Offline Tom Niebuhr
« Reply #23 on: December 10, 2006, 07:08:14 AM »
Randy, Phil, etc.,
There is more history to that method....
The first GSCB OTS meet was October 1970, I was one of the entrants..   ( 1st.. Bob Hunt, Veco Mustang; 2nd John D'Ottavio, All American Sr; 3rd yours truly, Barnstormer) That is one of the few trophies that I have kept over the years.
 I CD'd the second OTS contest in the country the summer of 1971 at Buder Park, St, Louis.
****John Davis quick built an All American Sr for the St. Louis contest and took 1st.
His All American Sr had a foam wing with the "kept foam" method that was "created" many years later! ****
I am sure that only two of us saw that airplane before it was covered. At that time, any entry for the brand new event was most welcome, as long as dimensions were true.
I would not be surprised to hear that somepne might have even done it before then.
AMA 7544
