  • August 01, 2025, 09:57:17 PM
Author Topic: Sheeting a built up wing  (Read 2052 times)
Offline Leester
« on: October 23, 2006, 11:43:29 AM »
One of my future projects calls for the built up wing to be sheeted in 1/16 balsa. What precautions should I take in doing this ? Should I buy wing skins, or 3 or 4" and join them myself ? Is ambroid or sigment prefered or Sig bond glues ? Do you join the panels on the center line of the wing or angled ? I just want to obtain all the info I can before I get into this, so all help is appreciated.  Thanks
Leester
ama 830538
Re: Sheeting a built up wing
« Reply #1 on: October 23, 2006, 09:28:08 PM »
I do them just like a foam wing.  Make up the skins, then orientate the grain to the sweep of the LE.  I user combinations of 3" and 4", usually, and glue them together with CA from "the inside" while they are taped together and on waxed paper.  Then I throughly sand them on both sides.
Bill <><
Offline wmiii
« Reply #2 on: October 25, 2006, 11:28:15 PM »
 I do the same thing, except I do not use ca, I use sigment, Pica glue it,
or any sandable glue.
 Walter
walter menges
Offline Ron King
« Reply #3 on: October 26, 2006, 07:25:17 AM »
I am lazy and simply call Lone Star for the wide wing skins.  **)
The edge gluing is done and they are sanded and ready to go. Orient them with the LE sweep and trim at the TE.
Ron
Ron King
AMA AVP District 4
Wannabe Stunt Pilot since 1963
 Amateurs practice until they get it right; Pros practice until they cannot get it wrong.
« Reply #4 on: October 26, 2006, 05:20:04 PM »
Now for getting the skins to attach to the ribs.  I mark the rib location on the inside of the wing skin.  Then I put a thin layer of Elmers White Glue over the pencil markings of the skins and a layer on each of the ribs.  Then take your trusty household iron and iron the skins down.  Should attach itself the first try.  If not your in trouble.  Anyway this is how I do leading edge sheeting.  Later,  DOC Holliday
Offline L0U CRANE
« Reply #5 on: October 28, 2006, 12:25:20 PM »
Doc,
I do a variant on your technique. I use Elmer's Yellow Carpenters' instead. It's an aliphatic resin glue.
That type of glue cures over several days to waterproof final strength, or as soon as you hear the sizzle from pressing heat through the sheeting with a MonoKote iron.
Also, I run a thin line of the glue on the structure to be sheeted, wipe off most of it, align the sheeting on the wetted pieces and press just enough to mark the glue side where the structure is.
The another thin line of aliphatic on the sheeting, mostly wiped off, to fill any voids or gaps where it was marked. Let dry to the touch before ironing over it. You can still move it around a bit until you apply heat, then it goes off like a contact cement. Contact cements don't allow movement when they touch; aliphatic resin glues do, until heat cures the two preglued pieces together.
I like it for the strength, speed and light weight - you wipe off almost all the glue, except what soaked into the balsa, before you join the pieces.
\BEST\LOU
« Reply #6 on: October 29, 2006, 08:06:28 AM »
Hi Lou,
That's an outstanding method and explanation of it!   y1
BTW: that old Fox 35 is still humming along like a sewing machine!  **)
Bill <><
Offline Leester
« Reply #7 on: October 29, 2006, 09:10:03 AM »
Thanks to everyone I'm picking up a lot of great info keep it up.
Leester
ama 830538
