  • June 18, 2025, 06:38:19 AM
Author Topic: Need suggestions  (Read 2218 times)
Offline Chuck Schultz
Need suggestions
« on: November 09, 2015, 06:14:46 AM »
What do you use as a spacer between the Horiz. stab. and the elevat. when glueing cloth hinges to them?
 VD~
« Last Edit: November 09, 2015, 07:30:36 AM by Chuck Schultz »
Offline Dane Martin
  • heli pilot BHOR
Re: Need suggestions
« Reply #1 on: November 09, 2015, 06:35:36 AM »
Nothing, they should be touching. That way there's no gap
« Reply #2 on: November 10, 2015, 06:59:42 AM »
I've heard about using tape for this hinge but I thought it was a special type of tape. Who would have thought plain old Scotch tape would work. Thanks.
Offline George Mitchell
« Reply #3 on: November 10, 2015, 07:19:42 AM »
I think this is from Windy: Fold 2 pieces of 320 sandpaper double
and put at each end of the stab and gently push together. For flaps
4 pieces doubled. I just saw the request was for cloth hinges. This
is for nylon barrel hinges.
« Last Edit: November 10, 2015, 03:34:40 PM by George Mitchell »
« Reply #4 on: November 10, 2015, 02:41:41 PM »
 VD~
The cloth hinges are the spacer.  As hard as I try, I still have little play between the surfaces.
