  • June 18, 2025, 12:53:02 PM
Author Topic: Molding Balsa  (Read 1698 times)
Offline Leester
Molding Balsa
« on: May 14, 2008, 01:05:32 PM »
All the previous times I molded balsa I soaked the wood in plain water. Today I used Ammonia and water mixed HO-CHI-MAMA that stuff stinks and burns the eyes. Good thing I'm single or ... well you know. mw~ mw~ mw~ mw~    LL~ LL~ LL~
« Last Edit: May 14, 2008, 02:54:29 PM by Leester »
Leester
ama 830538
Online Will Hinton
Re: Molding Balsa
« Reply #1 on: May 14, 2008, 02:19:41 PM »
A very loooooooooooooong time ago I used to always use the ammonia because those who wrote about molding balsa said to.  No more, I've not used it for the last 15 or more years and have molded balsa on every stunter I've built except for the profiles.  It just ain't needed!
I have also found that soaking the balsa for no more than a half hour is sufficient.
Blessin's,
Will
Re: Molding Balsa
« Reply #2 on: May 14, 2008, 04:31:15 PM »
IMHExperience, I have just ran hot water from the tap over my balsa, typically on the side that will become the outside. Granted I havent done complex shappes but its working so far
Offline Jim Thomerson
Re: Molding Balsa
« Reply #3 on: May 14, 2008, 04:43:09 PM »
Ammonia softens lignin and subrin, which balsa has little or none of.  The problem is getting the balsa whetted.  A tiny bit of simple green or similar will help in the process.
Offline steve pagano
Re: Molding Balsa
« Reply #4 on: May 14, 2008, 07:35:25 PM »
Hello guys
Not to redirect the thread But for those of you who mold, How would one go about molding a top block of an aircraft in which the plans do not show top block formers, In other words when the plans say carve. How does one make a mold buck of the top block shape with out having formers on the plans to show you the exact shape of what the mold should be?
                                                          T.I.A.
Success isn't a destination.It's a journey!!!!!
A.M.A. 820-823
Offline Leester
Re: Molding Balsa
« Reply #5 on: May 14, 2008, 07:50:38 PM »
Steve: The best way is to get Windy's DVD's on molding Balsa. He shows how you carve the top block then mold balsa around it.
Leester
ama 830538
Offline RC Storick
Re: Molding Balsa
« Reply #6 on: May 14, 2008, 08:10:54 PM »
Or Robins view from Bob Hunt. Thats how I leared. Great stuff!
Re: Molding Balsa
« Reply #7 on: May 14, 2008, 08:24:59 PM »
That's what i got. But in the video the plans have have formers for molding the top and bottom blocks.
A.M.A. 820-823
Offline RC Storick
Re: Molding Balsa
« Reply #8 on: May 14, 2008, 08:40:42 PM »
If you have the video for advanced molding techniques you can see how to loft out formers. If not start at the front and make a former to fit. The go the back and make another one. String a piece of wood across the two and measure where the other ones go (lofting). Do a search for my Tbolt molding and see the buck.
Offline L0U CRANE
Re: Molding Balsa
« Reply #9 on: May 15, 2008, 12:10:38 PM »
Agreed. Lofting is the best method, whether by the old historic methods, modern CAD methods, or whatever... (As I learned it about 50 years ago, the term 'lofting' was related to laying out - full-size - the curves of boat and ship hulls. BIG pieces: needed to work in a big open space, like a loft? Also used later for early aircraft full-size layouts...)
To Reply#4, Steve - a 'practical' way might be to build the forming buck with the intended formers in place at the desired positions (if the plans don't locate them for you.) You could tack-glue the formers with a dot of, say, SIG Cement, which acetone or dope thinner softens to let you separate them from the blocks. Or, you could 'build' the buck onto a keel, with the separate short blocks between the bulkheads securely mounted to the keel. Then carve away, just as you would have from solid block in the first place.
Remember to make the buck width and height undersize by the thickness of the wood to be formed... of course.
\BEST\LOU
Offline Kim Mortimore
Re: Molding Balsa
« Reply #10 on: May 16, 2008, 01:08:11 PM »
I read the search instructions, then tried searching:  storick thunderbolt molding.  Both basic and advanced search.  No matches, but a suggestion for struck rather than storick.  Tried without the name.  No cigar.  Anyone know what I am doing wrong?   n~
Thanks!
Kim Mortimore
Kim Mortimore
Santa Clara, CA
