CLICK HERE--><--CLICK HERE
Rudder Questions
Started by DJohnson, October 25, 2026, 12:11:32 PM
Previous topic - Next topic
0 Members and 1 Guest are viewing this topic.
DJohnson
Regarding an adjustable rudder on a 60 size stunt ship:
1. Is it important to make the rudder removable, and;
2. Do you seal the hinge line with tape?
I have a decent size ~1/8 inch gap in the hinge line.  This is there to expose the hinge barrels for the wire.  If I were to make them non- removable, I could burry the hinges and eliminate the gap.
What do you recommend?
Thanks,  David
Ken Culbertson
I rarely have to use rudder offset but when I do I use hinges made of 12 gauge copper wire with no gap.  I use three wires.  They are easy to tweak and don't move once set.
Like Like x 1 View List
Howard Rush
1.  Rudder need not be removable unless you need to remove it for access to something or to fit the airplane into a box or a car.
2. Taping may not matter, but wouldn't hurt. I used to make Impact rudders adjustable, but I never adjust them, so my current dog has no rudder.
Dave Hull
If you don't need a removable rudder, you can close up the gap using mylar/CyA type hinges. Still adjustable, just not constantly moving like an elevator. Then rig a rudder horn and clevis for micro adjustments. Very solid, and not prone to ruining your trim if it gets bumped. Here is my latest example on a 60+ sized ship:
DJohnson
Thanks everybody, I appreciate it.  I have decided to leave it as removable and see how it does.  The photo shows it installed although hinges are not glued in.
The airframe is substantially complete.  Moving on to sanding phase.
David
Motorman
You don't box your trailing edge?
DJohnson
Quote from: Motorman on October 26, 2026, 12:32:07 PMYou don't box your trailing edge?
Hey Motor
Do you mean recessing the trailing edge by laminating?  I did on the wing for the flaps but not the horizontal stab.
David
DJohnson
Quote from: DJohnson on October 26, 2026, 01:11:44 PMHey Motor
David
You may also mean cutting  a notch for the hinge.  I did not do that because my thinking was that It would make the hinge wire hard to install.  Perhaps I'm wrong about that though.
Ken Culbertson
Quote from: DJohnson on October 26, 2026, 01:17:30 PMYou may also mean cutting  a notch for the hinge.  I did not do that because my thinking was that It would make the hinge wire hard to install.  Perhaps I'm wrong about that though.
It actually makes it easier.  The trick is to mount the hinges with the wire installed using a thicker wire.  I am guessing .028.  Then when it is all finished you replace it with .025.  .025 is flexible enough that you can thread it through each hinge one at a time instead of having to do the entire wing in one shot.
DJohnson
Quote from: Ken Culbertson on October 26, 2026, 03:21:04 PMIt actually makes it easier.  The trick is to mount the hinges with the wire installed using a thicker wire.  I am guessing .028.  Then when it is all finished you replace it with .025.  .025 is flexible enough that you can thread it through each hinge one at a time instead of having to do the entire wing in one shot.
Thanks Ken
Motorman
If you're familiar with D tube construction where you have a sheeted LE then glue shear webs to the spars, you can do the same to the TE. Just glue a rectangular piece of 1/16" balsa between each rib and size it so it fits just inside the TE sheets.
MM :)
Like Like x 2 View List
Ken Culbertson
Quote from: Motorman on October 27, 2026, 11:30:31 AMIf you're familiar with D tube construction where you have a sheeted LE then glue shear webs to the spars, you can do the same to the TE. Just glue a rectangular piece of 1/16" balsa between each rib and size it so it fits just inside the TE sheets.
MM :)
The strength comes from shortening the gap between spar supports reducing flex.  100% as with shear webs is IMHO overkill=extra weight. Hard straight grained(7-8lb.) 1/16" strips will achieve the same thing for our purposes and are considerably lighter. Two between ribs UNDER, not glued to the face of the spars and the same under the TE sheeting.  Actually, the TE is probably more important to reduce flap flexing.  Same can be done after you have cleared any obstructions to the leadouts.  Put the 1/16" posts under the cap strips just outside of the leadouts at maximum settings.
Howard Rush
Yep.
DJohnson
MM :)
Thanks Motorman.  I did it.
Motorman
That's a nice wing. Warren truss is not easy to do but worth it. How did you get the ribs? Did you use the lost foam system, a computer program or something else?
MM :)
Steve Helmick
Quote from: Ken Culbertson on October 27, 2026, 12:18:34 PMThe strength comes from shortening the gap between spar supports reducing flex.  100% as with shear webs is IMHO overkill=extra weight. Hard straight grained(7-8lb.) 1/16" strips will achieve the same thing for our purposes and are considerably lighter. Two between ribs UNDER, not glued to the face of the spars and the same under the TE sheeting.  Actually, the TE is probably more important to reduce flap flexing.  Same can be done after you have cleared any obstructions to the leadouts.  Put the 1/16" posts under the cap strips just outside of the leadouts at maximum settings.
I'd strongly disagree, Ken. Sheer webs make the LE or TE into a tube. Twisting a tube is WAY more difficult, right? Same for a fuselage. Impact magazine plans show phantom lines, but no explaination, so I asked PW. Cross grain 1/16" to make a box (i.e., tube) to prevent fuselage twist, both during construction and in flight. Some of the various Impact kit plans don't show that. At least, the UHP kit didn't.  Steve
DJohnson
Quote from: Motorman on October 29, 2026, 09:15:11 AMThat's a nice wing. Warren truss is not easy to do but worth it. How did you get the ribs? Did you use the lost foam system, a computer program or something else?
MM :)
I got the ribs and spars from Frank Williams.  He lazer cut them.  Everything else on the plane I cut the old fashion way by hand.  The Impact plans I am following are dated "2000".
David
