  • July 12, 2025, 08:49:40 PM
Author Topic: Getting the stab in line with the wing using these "jigs".  (Read 3508 times)
Offline Ty Marcucci
« on: October 31, 2012, 02:40:54 PM »
 HB~>
« Last Edit: July 11, 2017, 03:58:05 PM by Ty Marcucci »
Ty Marcucci
Offline RC Storick
Re: Getting the stab in line with the wing using these "jigs".
« Reply #1 on: October 31, 2012, 05:01:22 PM »
Here is a photo of the jig I use. Seems to work fairly well.. LL~ Sorry I couldn't resist!
Offline MarcusCordeiro
« Reply #2 on: October 31, 2012, 05:21:01 PM »
Now, that was mean... LL~
Great stuff Ty, simple but great
Marcus
Live to fly, fly to live
Aces High!
Here comes Marcus, man..."
Offline Crist Rigotti
« Reply #3 on: October 31, 2012, 09:08:55 PM »
That's funny!  LL~
Offline Gene O'Keefe
« Reply #4 on: November 01, 2012, 08:17:57 AM »
Sparky...I cracked up on that one !! LL~ LL~ LL~ LL~
Gene O'Keefe
AMA 28386
Offline Chuck_Smith
« Reply #5 on: November 01, 2012, 11:10:41 AM »
I have an old Robart incidence meter, works decent for setting the thrust line.
I generally,
1) Mount the motor,
2) check the thrust line to wing incidence, adjust as needed
3) set the horizontal tail to the wing
4) check the tail to the thrust line as a check
5) use a string to check the centerlines - I switched to SpiderWire because it has no stretch and I had some.
But I still rely on my eyeballs and design my fuselages with the stab, motor mounts and wing related to a machined edge ( the top ). Put a  hollowed to .125" carved block top on and you should be good.
I'd bet the majority of guys build that way.
AMA 76478
Offline RC Storick
« Reply #6 on: November 01, 2012, 06:09:02 PM »
Don't take it personal TY may answer was just funny to me
« Reply #7 on: November 01, 2012, 06:30:05 PM »
 Same here, eyeball and tape measure. :)
Online Dick Pacini
« Reply #8 on: November 02, 2012, 02:34:32 PM »
No pix came though on my end. HB~>
AHA!  I found them lurking at the bottom.
Great idea.  I will use that on my next batch of bones.
AMA 62221
« Reply #9 on: November 02, 2012, 11:49:11 PM »
I used the tape measure technique only to find that if not very careful and I bumped the stab, it got out of alignment. With the two rods, it stays in one place, aligned, as it dries. H^^
 That's the "trick" Ty, once you get things set you have to leave out the step where you bump it. :##
Offline John KruziK
« Reply #10 on: November 29, 2012, 04:14:53 PM »
Some times simple is best!
AMA 874027
Offline Larry Wong
« Reply #11 on: November 29, 2012, 05:06:56 PM »
WHO's Simple ?     LL~ LL~ >:D
Larry
Offline Dan Bregar
  • Field Marshall
« Reply #12 on: November 29, 2012, 06:13:27 PM »
Ty
I thought your tools were cool.  And I'm in the process of gluing up a wing & stab to a profile fuselage this week end, and I think I'll use your system.  Thanks for sharing !
AMA 33676
