  • June 18, 2025, 11:37:12 PM
Author Topic: Control horn retainer size  (Read 2527 times)
Offline kevin king
« on: May 08, 2022, 12:12:19 PM »
What thickness of copper sheet  do i need to order for Flap & Elevator control horn retainers for  35 to 60 size airplanes? Im refering to the copper strips that are bent around the control horn and glued into the trailing edge. I can get K&S copper sheets in .016 and .025 but not sure if its the right thickness
Thanks.
Kevin
https://brodak.com/control-line-parts/control-horns/3-32.html
Offline Dwayne Donnelly
Re: Control horn retainer size
« Reply #1 on: May 08, 2022, 06:48:22 PM »
Just curious, has anyone used tin gift boxes?
Online Howard Rush
« Reply #2 on: May 08, 2022, 08:43:32 PM »
Too big. Too much drag.
« Reply #3 on: May 08, 2022, 09:15:53 PM »
The Flap & Elevator control horn retainers you can get from Brodak or Tom Morris are .010" brass.
Motorman 8)
« Reply #4 on: May 09, 2022, 12:16:04 AM »
Thanks.
Kevin
    Brass is probably more appropriate, and much more available.
   All you use it for it to hold it in place, you want to do something more rigid over the top of it, either fiberglass/epoxy, or the very clever clips that Bob Hunt showed us here:
   https://stunthanger.com/smf/open-forum/elevator-joiner-horn-bearings-critical/msg583408/#msg583408
« Reply #5 on: May 09, 2022, 05:19:15 AM »
