  • July 13, 2025, 05:32:45 AM
Author Topic: Ringmaster Bipe - 1099 sq inches  (Read 5638 times)
larry borden
« on: July 06, 2012, 02:23:21 PM »
I'm building a prototype Ringmaster Bipe that has a 63" wingspan and 1099 sq inches. Here are some pictures of the beginning of the build.
First picture is the two packages of wood that came from Pat.
Second picture is what was left after all parts had be seperated from their sheets. Enough to build a regular Ringmaster.
Third pix is one of the spars being glued together.
Fourth is the ribs being placed on the spar and trailing edge.
larry borden
Re: Ringmaster Bipe - 1099 sq inches
« Reply #1 on: July 06, 2012, 02:35:59 PM »
Top wing all framed up.
Fuselage pieces laid out and ready for construction.
Engine for this beast is a K&B 61 set up and muffler built by Scott Riese.
Tail feathers framed up and the next pix they are finished and ready to be hinged.
« Reply #2 on: July 06, 2012, 02:56:26 PM »
Hi Brother Larry!
The Bipe is looking good.  Should be a very good flying Ringmaster!  I have fixed up my old Pontiac van so that if I want to build a giant sized Ringmaster I will have a way to haul it.
BIG Bear
RNMM/AMM
« Reply #3 on: July 06, 2012, 03:28:46 PM »
Larry,
Nice build!
This giant Ringmaster? Has it been done before or did you have it scaled up that large?
Nice tongue muffler, polished by you? Custom muffler made by who?
I need a custom made tongue muffler, I have no idea who makes them?
I think I have the Ringmaster lettering and logo in vinyl? I may have made one some years back, I'll check my art file.
If I find the art, would you be interested in a vinyl or mask? No charge!
Charles
« Reply #4 on: July 06, 2012, 03:47:31 PM »
Larry,
Nice build!
Charles
Hi Charles,
As Brother Larry stated, Scott Riese made the muffler.  Scoot is a member here and a search of the members will give you his contact info.  He is very reasonable as to the cost of his work and he usually has a quick turn around.
BIG Bear
RNMM/AMM
Offline John Cralley
« Reply #5 on: July 06, 2012, 04:04:11 PM »
Looking Good Larry!!!!
You will be flying it along with your Ringmaster 1000 for the Ringmaster Fly_A_Thon next October 6 and 7th - right??  y1 #^
John Cralley
AMA 52183
Central Illinois
« Reply #6 on: July 06, 2012, 04:06:58 PM »
Oh, yeah, Brother Larry, I am not sure I can budget out enough money to "BUILD" one of the huge Ringmasters! LL~ LL~  It looks like it takes a small balsa forest to just frame one up! LL~ LL~
BIG Bear
RNMM/AMM
« Reply #7 on: July 06, 2012, 04:37:57 PM »
Bill,
Thanks for the info.
Ringmaster construction question?
I see the center spar is notched up/down for every other rib. One rib slides in from one side then another rib slides in from the other side.
Seeing all the ribs and spar gets glued, would it make a difference if only one side of the spar was notched for ribs, sliding in from one side only?
Charles
Offline dennis lipsett
« Reply #8 on: July 06, 2012, 06:16:07 PM »
BIG Bear
RNMM/AMM
[/quote
Bill,
you could always build one of these. 61.5 in W/S with 895 sq in wing area. Consider it a change from a ringmaster. Designed also by Pat King with the same construction techniques.
Dennis
larry borden
« Reply #9 on: July 06, 2012, 06:23:03 PM »
Roger that!
larry borden
« Reply #10 on: July 06, 2012, 06:26:30 PM »
Bill,
Charles
I don't think it would be as strong and it didn't take long to get the ribs onto the spar.
larry borden
« Reply #11 on: July 06, 2012, 06:31:38 PM »
Fuselage pictures. I also made pads from 1/8" aluminum for extra strength on the motor mount. Picture of the fuselage and bottom wing dummied in.
« Reply #12 on: July 06, 2012, 06:45:24 PM »
Larry,
Nice work and great photos.
That fuselage looks like my International fuselage the way it's hollowed out.
Could have been a built up fuse?
No rudder off set? Interesting.
Nice work, great photos!
Color scheme yet?
Charles
« Reply #13 on: July 06, 2012, 06:50:27 PM »
Larry,
Color scheme yet?
Charles
HI Charles,
The "modern" thought is to not use any rudder offset.  We do not want the model to be yawed out since it helps kill off too much speed in maneuvers.  The overhead "8" will really be hammered if too much offset is used.  We try to get the model to fly as tangent to the circle as possible.  If any offset is used it is a tiny amount to insure no "inset".
BIG Bear
RNMM/AMM
larry borden
« Reply #14 on: July 06, 2012, 08:55:55 PM »
LE stock before shaping.
Weight box installed on the bottom wing. I installed it on top because this thing would a bear to turn over to add or subtract weight.
Wing and fuselage epoxied together.
« Last Edit: July 07, 2012, 09:37:17 AM by larry borden »
« Reply #15 on: July 07, 2012, 09:01:45 AM »
This is awesome.    H^^
« Reply #16 on: July 07, 2012, 09:13:48 AM »
John,
He'll have to buy silk off the bolt by the yard!
Charles
larry borden
« Reply #17 on: July 07, 2012, 09:38:30 AM »
Bought a half bolt from Oriental Trading Co.
« Reply #18 on: July 07, 2012, 12:18:56 PM »
Larry,
Smart man. Kudos!
Paint scheme? Ringmaster art?
Is this your largest CL model?
Charles
larry borden
« Reply #19 on: July 07, 2012, 01:36:30 PM »
The Ringmaster 1000 takes up more space, but square inch wise this is the largest. No color scheme yet, haven't even decided on one for the SWIFT.
« Reply #20 on: July 07, 2012, 01:55:25 PM »
Best wishes with this "BEAST", Brother Larry!  Back to back flights with this one and the RM 1000 would be an awesome experience and sight!  (maybe G-Man and you will get together and he will have his SDR!)
BIG Bear
RNMM/AMM
larry borden
« Reply #21 on: July 07, 2012, 05:47:41 PM »
After the SWIFT and the bipe are finished, here is a picture of my next project, that I have already started.
Offline Brad Smith
« Reply #22 on: July 07, 2012, 07:58:10 PM »
Brother larry i have been following your thread on the ring for this plane, i have the same  kit  got it last month plan to build it this winter keep up the good work. i have never built a bi plane thinking of building the 38 spacial first. then the Ringmaster Bipe. I realy like your next project it looks wicked what motor is it the 327?
Brad smith AMA780054
larry borden
« Reply #23 on: July 08, 2012, 05:22:48 AM »
Shooting to get the 56 finished by June. Hot Rod Power Tour leaves from Arlington TX next year and I'm planning on doing it. 350 4 bolt, backed by a Muncie 4 speed.
« Reply #24 on: July 09, 2012, 07:39:59 AM »
Larry, that little truck will make some plane hauing vehicle.   Don't forget the finished pictures. H^^
larry borden
« Reply #25 on: July 09, 2012, 03:04:43 PM »
Just for fun I placed the top wing on, just to see what it looks like. Trust me, it's big!
« Reply #26 on: July 10, 2012, 01:48:16 PM »
Larry,
Looking good!
What's the distance between the two wings?
Charles
« Reply #27 on: July 10, 2012, 03:40:56 PM »
Larry,
I don't know about others but the top wing looks to high for aesthetic appearance and maybe good flying. Could be an optical illusion from the camera angle.
I sure am enjoying you build thread keep at it October is not that far away!!  y1
John Cralley
AMA 52183
Central Illinois
larry borden
« Reply #28 on: August 15, 2012, 02:43:50 PM »
Finally getting back on the bipe. Finished sanding, filling and primering getting ready to cover the bottom wing silk.
Finished covering today and will be putting the first clear on the silk to tightening it up. Will start finishing up the top wing as I'm at a stopping point on the fuselage. I'm waiting for the Tom Morris controls from CLC so I can install the horizontal stab.
larry borden
« Reply #29 on: September 03, 2012, 02:33:40 PM »
Tom Morris controls were received and have been put in, or at least the mount has been installed and the stab epoxied in place. Next two pictures are showing the complete assembly dummied up to see what she will look like. Still have top wing to cover.
Offline Brad Smith
« Reply #30 on: September 03, 2012, 06:25:07 PM »
what did you cover the wings with i have the same kit but i have never built a biplane befor so i think im going to build a Brodaks 38pecial first. the covering looks nice.
larry borden
« Reply #31 on: September 04, 2012, 07:29:06 AM »
Thanks Brad. Wings are covered with silk and other parts are silkspan, old skool. Actually this was my first bipe too. Great kit, all balsa is excellent. I've told Pat King that I have ham hands and spent a lot of time repairing parts that I broke while building. Still used to the old Sterling die crunched kits.
Offline Brad Smith
« Reply #32 on: September 04, 2012, 11:30:55 AM »
I know what you mean i cant build a plane with out busting something what motor are you useing in the plane?
larry borden
« Reply #33 on: September 04, 2012, 09:31:07 PM »
K&B 61 with tongue muffler from Scott Riese. What was funny, we all thought the 1000 with the same engine combo would pull your arm off. But it was no worse than a 40 size stunt ship. Joe Gilbert was the test pilot last year at the roundup.
« Reply #34 on: September 08, 2012, 03:59:46 PM »
Bill,
Charles
Looks like the ribs have cutouts for spars top and bottom, so the sheet spar just becomes the back of the D-tube.  An easy way to do it, heck of a lot easier than fitting 25-50 webs in each wing.
larry borden
« Reply #35 on: September 10, 2012, 06:40:30 AM »
I've talked to Pat about the spar. Would be easier if the spar was notched the same, this is the first one being built.
