  • June 27, 2025, 05:40:00 PM
Author Topic: Riley Wooten’s Sneeker build  (Read 15867 times)
Offline Tim Chenevert
« on: February 21, 2018, 05:29:39 AM »
I bought an original Sneeker kit from Fred, many thanks Fred, and decided to use the parts as templets to build the plane. All parts have been cut out and the assembly begins today. TE ‘s completed from Fig 2 on the plans. Tim
« Last Edit: February 21, 2018, 06:06:38 AM by Tim Chenevert »
Baton Rouge Bi-Liners
AMA 179681
Offline jim ballard
Re: Riley Wooten’s Sneeker build
« Reply #1 on: February 21, 2018, 07:38:20 AM »
I always thought the Sneeker was a cool combat plane and have seen a few fly although I never had one. Looking forward to following your build Tim.
Tempting fate and gravity one more time....
Jim Ballard
Blackwell, TX
AMA 62811
« Reply #2 on: February 21, 2018, 09:44:26 AM »
Thanks, Jim!
AMA 179681
« Reply #3 on: February 21, 2018, 06:22:09 PM »
Motor mount glued together. Fig 3 on the plans.
AMA 179681
Offline Dane Martin
  • heli pilot BHOR
« Reply #4 on: February 21, 2018, 07:03:50 PM »
Your rolling now! This should be really neat.
« Reply #5 on: February 21, 2018, 07:08:23 PM »
Thanks Dane. I am having a lot of fun with this build. Tim
AMA 179681
« Reply #6 on: February 21, 2018, 08:40:49 PM »
On a build like that, I like to drill the holes first and use the engine as an alignment fixture.
I put quite a few Sneakers together after stepping up from a dozen each VooDoos and Combat Cats.
Offline jim ballard
« Reply #7 on: February 21, 2018, 09:08:46 PM »
You got 'er goin' your way now Tim! Keep the pics coming as you progress....
Jim Ballard
Blackwell, TX
AMA 62811
« Reply #8 on: February 22, 2018, 03:38:41 AM »
That is a great idea but how do you know exactly where the engine will go? Spacing from the wings LE and also balance? I plan to put the engine as close to th LE as I can.
Will do and Thanks Jim!
Tim
AMA 179681
Offline Dane Martin
  • heli pilot BHOR
« Reply #9 on: February 22, 2018, 06:52:24 AM »
Riley is a fox man. He set these up around a fox. So anywhere from the leading edge forward is fine. Any heavier of an engine will just need a little tail weight, if that's your flying style, but would be fine.
« Reply #10 on: February 22, 2018, 08:54:31 AM »
These kind of planes are ALWAYS nose heavy.  So always put the engine all the way back to minimize the tail weight.
Also, if you wait until last the drill the holes, you will have a hard (impossible?) time drilling straight.
I guess Riley Wooten may have also been a Fox man, but he was best known for winning with Johnson engines.
« Reply #11 on: February 22, 2018, 09:24:17 AM »
On the subject of engine mounts, I have never believed that I, or anybody else, could drill proper mounting holes after the plane is assembled.
My style is to drill the holes one at a time on a drill press, before assembly. Drill the first hole, bolt to the engine and then drill the second hole.
Then, with the engine bolted to the hardwoods, fit the hardwoods to the center block.  An accepted combat technique is to add a vertical 6/32 bolt through the hardwoods and the center block.  This will give you both correct holes and the ability to position the engine where you want it.
« Reply #12 on: February 22, 2018, 11:39:44 AM »
Very good ideas on the engine mounts! At this point I will try to place the engine as far back as I can and drill the holes on my Father in laws drill press. Tim
AMA 179681
« Reply #13 on: February 22, 2018, 07:23:40 PM »
So I have another question; with the bottom trailing edge glued down, how do you glue the top TE down? It is a very tight space. I have used CA up to this point. I thought about using the original Titebond and pinning it in place and let it set for a day. I have also heard about a small tip that you can use with CA glue to get glue into tight spaces. Any suggestions will be appreciated. Thanks, Tim
AMA 179681
Offline Dane Martin
  • heli pilot BHOR
« Reply #14 on: February 22, 2018, 07:31:47 PM »
IF! the build is fixed to the table pretty good there (which it should be), you can take gel CA and apply it to the top of the ribs and GENTLY roll the sheeting into place.
You could also use wood glue and do a similar thing but you'll have to pin it or ace bandage it to hold it while it dries.
I do the gel CA thing pretty much every time.
Offline Dane Martin
  • heli pilot BHOR
« Reply #15 on: February 22, 2018, 07:32:53 PM »
Just do it gently so you don't inadvertently install a warp. Lol.
« Reply #16 on: February 23, 2018, 03:54:17 PM »
Thanks Dane for the help! Wing and wing tips starting to take shape!
AMA 179681
« Reply #17 on: February 24, 2018, 04:21:19 PM »
I have 12 cap ribs to install. The instructions do not give any indication of where they go. I have 2 of the ones on the bottom, 2 of the middle ones and 8 of the ones on the top. Any help would be appreciated. Tim
AMA 179681
« Reply #18 on: February 25, 2018, 04:17:09 AM »
Anyone? Tim
AMA 179681
Offline George Truett
« Reply #19 on: February 25, 2018, 07:15:26 AM »
Tim,  looking at the plans your cap ribs go between the outer 4 ribs on each side, 3 on the top and 3 on the bottom each side for a total of 12.  Never having built a Sneeker I would guess 4 of the cap ribs are different for clearance.  Since the only thing they might hit are the leadouts I would again guess the 2 and 2 cap ribs that are different are to go top and bottom closest to the inboard wing tip.  I would do a dry fit with them moving the leadouts through full travel to make sure they don't rub anywhere.
« Reply #20 on: February 25, 2018, 08:59:02 AM »
Thanks George and I think that is a good explaination. I am waiting for a 3” Bellcrank to arrive in the mail and will install it and leadouts and check the cap ribs for fit. Tim
AMA 179681
« Reply #21 on: February 25, 2018, 01:23:07 PM »
Don't the plans show that?    I vaguely remember 1/2  ribs between the main ribs. D>K
« Reply #22 on: February 25, 2018, 05:03:40 PM »
It shows them in place from only a top View. Does not say which ones go where. Tim
AMA 179681
« Reply #23 on: February 25, 2018, 06:30:44 PM »
The false ribs go top & bottom, and are all identical, or at least they should be identical. If you don't have enough, use one for a template to make a few out of some scrap.
It has been about 55 years since I built my one and only Sneaker. I liked it a lot, but more for fun flying than for actual combat matches. I used ST .35C's, and still have all both of them.  :o Steve
Offline Dane Martin
  • heli pilot BHOR
« Reply #24 on: February 25, 2018, 06:46:48 PM »
I can't find my plans. Don't they get sandwiched as doublers? Like George said. On the plans, those ribs will just look fatter I believe.
Offline Fredvon4
  • Central Texas
« Reply #25 on: February 26, 2018, 10:07:28 AM »
The Sneaker Kit I sent Tim has a typical instruction sheet and NO Full sized plan... not every thing is obvious the way they drew the plane in 1/4 size
Fred von Gortler IV
« Reply #26 on: February 26, 2018, 06:56:56 PM »
Engine mount was pre drilled, blind nuts installed and was just epoxied in place. Tight fit but used a small curved cath tip syringe to get the epoxy in place. Bellcrank arrived today, thanks to Dane! Engine was placed back as suggested with enough room to route the fuel line between the cylinder and wing. I will check balance prior to covering. Tim
AMA 179681
« Reply #27 on: February 27, 2018, 06:08:10 PM »
I have two more questions about this build;
Instead of using 1/2” styrofoam wedges between the ribs on the TE, I am thing about cutting triangular wedges from 3/32” balsa and gluing them in place. Any thoughts on this?
Also, for the cloth tape to hold the 1/16” wire hinges down on the stabilator, would Original Titebond glue work? Thanks (again) Tim
AMA 179681
Offline Dane Martin
  • heli pilot BHOR
« Reply #28 on: February 27, 2018, 06:12:57 PM »
Yes on the first.
Most likely fine on the second question. What do you plan on covering the tail with? If iron on, what I do is cut two strips that can go all the way around the tube and stab. Glue the tube on, then iron on the strips like tape all the way around. Then cover the whole stab.
« Reply #29 on: February 27, 2018, 06:48:45 PM »
Thanks Dane. I was going to use Rustolem on the stab, booms and the planking on the center section. Monokote on the wings from the planking to the wing tips. Purple on the center and yellow on the wings. LSU colors....sorry! Lol Tim
AMA 179681
« Reply #30 on: February 27, 2018, 07:33:05 PM »
Great point Motorman! I like the idea on the control horn and the spar bracing! I did that on my Twister with great results. Just thinking out loud but what about replacing half ribs with whole ribs? Too much weight? Tim
AMA 179681
Offline James Holford
« Reply #31 on: March 02, 2018, 07:52:45 AM »
Im jsut now seeing this. A Sneeker?!?!?! You da man Tim.
 I have a Voodoo started but it is at a halt because I cannt figure out what tank to put in it. Im not going to try to combat it. I just wanna fly n have fun with it.
Also I know where you can get a Combat Cat lazer cut kit if you are wanting to do one of them :D
Jamie Holford
Lafayette, La
AMA #1126767
« Reply #32 on: March 04, 2018, 08:07:04 AM »
Hi James, yep a Sneeker. Fast and fun to fly. I am hoping to get it finished soon. Tim
AMA 179681
« Reply #33 on: March 04, 2018, 05:14:35 PM »
Put a tank in just as the plans show.  Needs crank case pressure for reliability. D>K
« Reply #34 on: March 04, 2018, 07:30:11 PM »
James, Gil is looking to build a VooDoo powered by an OS 25 with a hard tank too. Tim
AMA 179681
« Reply #35 on: March 04, 2018, 08:00:24 PM »
Use same tank with uni-flo plumbing.    H^^
« Reply #36 on: March 09, 2018, 09:08:11 AM »
Another question:
It is time to glue the L brackets to the stab. What glue works best to glue the L brackets in place and to glue the linen in place that hold the L brackets on?
AMA 179681
« Reply #37 on: March 09, 2018, 11:08:50 AM »
Ambroid always worked for me with the cloth material or even fibre-glas. H^^
Offline Fredvon4
  • Central Texas
« Reply #38 on: March 09, 2018, 11:37:02 AM »
Ambroid
SigMent
Full Strength Dope
Tester Wood glue
Super Phatic
Elmer's White
TiteBond II
E 6000
Z poxy
CA Medium
NOT trying to be smart.... I have done it too may ways with what ever I had on hand
Truth is these days I prefer to NOT use the cloth to hold the pins.... I use a short length of CF tubing glued to LE of the stabilator with CF veil covering the whole balsa piece
Fred von Gortler IV
Offline Larry Borden
« Reply #39 on: March 09, 2018, 06:33:07 PM »
The old Flight Line kits had a set of trailing edge jigs. I built a building board set up for Sneekers using the jigs. I started modifying the Sneekers with 4" booms, engine shoved back half way through the LE. Pacifier tanks made out of the old aluminum pudding cans.
I could never fly a Nemesis and they were about 10 bucks a kit back then. I could build three Sneekers for a little more than one Nemesis. Used STG21 35.
Pretty good flying plane.
Offline Bootlegger
« Reply #40 on: March 10, 2018, 07:36:06 AM »
  Mr Borden, how did the 4" booms work out?  I am thinking about a Voo Doo with a 25 O S engine to try for stunt, and am thinking about extended booms for it also.  Thanks for help/advice... :!
8th Air Force Veteran
Gil Causey
AMA# 6964
« Reply #41 on: March 12, 2018, 06:58:15 PM »
I actually had a little time this past weekend to sit at the table and continue the Sneeker build. I have to install the fuel pod, which I have the pieces cut and ready to install, install the stab and paint and cover it! Tim
AMA 179681
« Reply #42 on: March 17, 2018, 12:06:18 PM »
Fuel pod installed. Need to finish sand. Install engine and check CG and see if she needs wingtip weights and then finish! Definitely a learning curve for my first scratch build. Many thanks to everyone who helped me along the way. Thanks, Tim
AMA 179681
« Reply #43 on: March 19, 2018, 04:11:35 PM »
I had a chance to work on my Sneeker a little. I have the wings covered with Monokote. Where the wood is visible, I will use Brodak’s butyrate dope in Cub Yellow to finish! Starting to see the end. Tim
AMA 179681
Offline jim ballard
« Reply #44 on: March 19, 2018, 07:23:03 PM »
Lookin' great Tim!
Jim Ballard
Blackwell, TX
AMA 62811
« Reply #45 on: March 19, 2018, 08:39:06 PM »
Thanks Jim. It has taken a lot longer than I thought to build. I tried to keep as close to the original but I did add spar bracing along the entire wing and I made balsa strips in place of the styrofoam fillers called for on the plans. It will be on pacifier so I built a balsa pod in place of the metal tank. It has been very fun to build build an old school plane and look forward to its first flight! This is also my very first scratch build ever. Tim
AMA 179681
« Reply #46 on: March 20, 2018, 02:44:30 PM »
 First coat of the dope in yellow on! Tim
AMA 179681
« Reply #47 on: March 20, 2018, 06:03:46 PM »
Interestingly, when Walter Umland was kitting the repro Sneaker kits, the question was asked if he was going with the 4" tailbooms or the early 2" tailbooms. He contacted Riley Wooten, who said that he'd never kitted the Sneaker with the 4" booms. Which lead me to run down in the shop and pull out the kit I'd bought at a swap meet. I took a picture of it and sent it to Walter. The box had a sticker on it that clearly said this was the improved Sneaker with the 4" tailbooms. I guess Walter got a good giggle out of that with Riley.  LL~ Steve
Offline jim ballard
« Reply #48 on: March 23, 2018, 07:31:56 PM »
Ok Tim, hows the Sneeker coming along? Last report....it looked like it was almost there....
Jim Ballard
Blackwell, TX
AMA 62811
« Reply #49 on: March 26, 2018, 03:32:34 AM »
 Well, I went to mount the engine Friday night and had a Blind but issue on the last bolt. Long story short, ready to install blind nut and repair/ finish engine nacelle. Probably start this evening. Check balance and will be ready for maiden flight after balancing. Will post some more picks. Tim
AMA 179681
