  • July 11, 2025, 06:04:16 AM
Author Topic: Remove Oil from Old Airframe  (Read 1885 times)
Offline Gary Anderson
« on: October 16, 2007, 10:44:39 AM »
Hi guys, I don't remember which product to use to remove oil from old plane I'm trying to refinish. Can anyone remind me which product there is to remove oil from wood. It came in a spray can, used to work on air conditioners. O'well, Help<HELP HELP. Thank you, Gary
Gary Anderson
Offline Bootlegger
Re: Remove Oil from Old Airframe
« Reply #1 on: October 16, 2007, 01:09:39 PM »
 #^  Would you be thinkin' about K 2R spot remover ???  Texise or Texize is the mfg. of it... D>K
8th Air Force Veteran
Gil Causey
AMA# 6964
« Reply #2 on: October 16, 2007, 02:15:40 PM »
K2R is what I have always been told.  I use some homemade stuff at times. ;D
Offline Jim Oliver
« Reply #3 on: October 16, 2007, 02:28:59 PM »
I just used 2 cans of K2R on a profile with oil soaked wood along the T.E. of the outboard wing--ran out of K2R and am trying talc mixed with alcohol (rubbing kind---not the other stuff!)  Painting it on with tooth brush and brushing off when dry.  Seems to be helping a little---but gonna take a while.
Jim
Jim Oliver
AMA 18475
Offline Kim Mortimore
« Reply #4 on: October 17, 2007, 02:09:10 PM »
Expert finisher Larry Fernandez told me he uses cornstarch and rubbing alcohol.  I will have a chance to try it in the near future.    %&*@#$%  Monokote!
Kim Mortimore
Kim Mortimore
Santa Clara, CA
« Reply #5 on: October 17, 2007, 02:21:23 PM »
Talc or cornstarch in isopropyl alcohol will work.  I make it up in a heavy sluury and brush it on.  Let it dry and then brush it off.  Repeat as necessary. ;D
« Reply #6 on: October 18, 2007, 05:39:43 PM »
Thank you, I'll give that a try. Thanks for all your help, Gary
Gary Anderson
Offline Phil Spillman
« Reply #7 on: October 24, 2007, 06:10:40 PM »
I have used both K-2R and the alcohol Talc methods with equal success! In addition I apply a paper towell with my plastic iron on film iron to reduce extra oil out of the wood. The paper absorbs what the heat pulls to the surface! Phil Spillman
Phil Spillman
« Reply #8 on: October 24, 2007, 07:34:30 PM »
Tip: While the K2R, talc or cornstarch is still on the wood, heat it with a heat lamp and the oil will rise to the surface and get absorbed by the powder, you will remove more oil faster this way.
« Reply #9 on: October 25, 2007, 03:56:59 PM »
Hi Brother Randy,
Heat and water (steam) is also a great way to remove some pretty decent dents in wood.  I have taken a $cote iron and a damp shop rag and removed some pretty good dents. :D
Bill <><
« Reply #10 on: October 30, 2007, 12:53:11 AM »
Hi Brother Randy,
Bill <><
Hi Bill, thanks for the tips. I've been using my monokote heat gun to draw out the oil. Laughing as I heat her up, trying to remember at what temp. wood will ignite? The wood seems strong but she sure has a lot of oil in her. Poor baby is quite old but I'm trying to make her look new again. Mainly trying out a different color scheme for my bigger babies, Just having fun. Plan on flying tomorrow with my good old arf/barf. Installed mark 4 merco in her, just for practice. Watched the big guns fly in Gilroy yesterday, I believe they have moved four foot level to one foot level. Most of them still fly around five second laps. All the flyer's put on a nice show, it was a lot of fun. Thanks again for all your help, Gary
Gary Anderson
