  • July 17, 2025, 05:16:19 PM
Author Topic: Progress on UltraLite Ringmaster  (Read 2437 times)
Offline Mike Griffin
« on: August 29, 2017, 03:53:23 PM »
At the point, the model weighs 9 1/2 ounces
Re: Progress on UltraLite Ringmaster
« Reply #1 on: August 29, 2017, 03:54:29 PM »
This is the core of the fuselage
Offline rich gorrill
« Reply #2 on: August 30, 2017, 05:20:19 AM »
Just started putting mine together Mike. I'm a little confused, was there supposed to be 1/8 ply doublers for glow power included in the kit? All I got were 1/32 for electric.  Do I have to make my own? The 1/32 are no good for mounting an engine.
Rich
« Reply #3 on: August 30, 2017, 08:21:19 AM »
Rich
77
Hi Rich.  There should be two sets of doublers in the kit and they are both 1/32, one is marked for glow engine.  There are no 1/8th doublers in the kit.  I have used the 1/32 for glow engines in the past with no problems.  Eric Rule at RSM designed the UltraLite and did not feel it was necessary to use 1/8th inch ply for the doublers and to keep the model light.  You could contact Eric if you wish if you feel like you need the 1/8th inch ply and he would probably cut you a set.
Offline Dane Martin
  • heli pilot BHOR
« Reply #4 on: August 30, 2017, 10:22:41 AM »
I'm currently building the same ringmaster. I have had very good luck using only 1/32 ply for glo engines on ringmasters.  On this ULRM I'll be using an os 20fp. I'd like a veco 19, but I I'd have to buy one. I add the little plastic mount pads under the engine, then I run 4-40 bolts through a T-nut on the other side. Then use a ny-loc nut as a jam nut and cut the bolts off flush. I have lots of ringmasters, several are made with the 1/32 ply doubler's and I've had no issues with stuff coming loose.
« Reply #5 on: August 30, 2017, 01:53:09 PM »
Thanks for the replies mike and dane. I'll be sure to use a pad under the motor. I'm also going to use an FP20, should be fine. I guess when I looked at the plan and it showed the 1/8 doubler being used ithought it was included.
Rich
Offline Dane Martin
  • heli pilot BHOR
« Reply #6 on: August 30, 2017, 08:20:22 PM »
Here's a little comparison. This scale is not modeling accurate. It's at best to the nearest 1/4 oz.
The first pic is the new ULRM. It's 3.75 no sanding and the engine mounts still too long.
The second pic is an original sterling kit. It is 3.75 also. It is finish sanded and there's no canopy. It's not getting any lighter. I think I can trim an ounce off the new ULRM pretty easy.
