  • July 13, 2025, 02:04:14 PM
Author Topic: Profile Pathfinder  (Read 1394 times)
Offline Jack Mulinix
  • AMA 917877
Profile Pathfinder
« on: October 31, 2010, 12:11:34 PM »
Hello All, so the p-40 went to the back burner and have been working on a pathfinder. Couple questions, first, shear web,  yea or nea? And the adjustable leadout has a nylon slide, should it be bushed with metal leadout guides or is the nylon ok? Thanks, Jack
Offline John Miller
Re: Profile Pathfinder
« Reply #1 on: October 31, 2010, 03:21:21 PM »
Jack, I usually use a truss style of shear webbing to the bay past the gear mounts. I'll often laminate a 1/4" strip of .007 CF between the top of the spar, and the sheeting. sandwiching it in betgween these two structural members really increases the stregnth without a huge weight penalty.
I tend to use the nylon alone, and have never wore out a leadout assy. Your choice, as bushing can help keep the leadouts from rubbing on the leadout slot.
Cheers  H^^
« Reply #2 on: October 31, 2010, 06:52:37 PM »
Jack,
my two cents worth, Nylon is actually superior to any metal in the leadout guide. I doubt that you will ever wear that guide out , unless something is really amiss.
As for shear webs,, I vote yes, you will add a fraction of an ounce, and a ton of rigidity to the wing.
Why did you bail on the P-40?
  • AMA 917877
« Reply #3 on: October 31, 2010, 08:02:58 PM »
Thanks for your input. John, not following the 1/4" carbon fiber. Do you you run the lenght of spar? And Mark, haven't bailed, just being cautious. Was trying to figure the best way to Build Up the fuse and how to remove that material. Router? #11 exacto? It's in the living room, so I can't ignore it. It's just sitting there, snarling at me. Jack
Offline John Miller
« Reply #4 on: October 31, 2010, 08:12:36 PM »
The CF is pretty easy. I start with a 1/2" wide strip of .007 CF from Dave Brown. I pick it up at the hobby shop.
I strip it in half, which gives me 2, 1/4" strips. By laminating these strips between the spar, and the leading edge sheeting, on top of the spar, for the entire legnth of the spar, places the CF where it can really strengthen the wing.
  • AMA 917877
« Reply #5 on: October 31, 2010, 08:22:01 PM »
John, thanks, do you use epoxy or ? And might you have had a little something to do with this plane?  Thanks Jack
Offline John Miller
« Reply #6 on: November 01, 2010, 07:58:21 AM »
I was tempted to use epoxy, but I wound up using thick Ca. it just goes faster, and holds very well, while allowing me time to adjust the placement of the sheeting.
Yes, I worked with Gordan on the design. My contribution was mainly doing the cad work for the drawings. There's a history on the Pathfinders on my web site. www.cadclassics.net
Cheers H^^
  • AMA 917877
« Reply #7 on: November 03, 2010, 08:28:22 AM »
Thanks John for info and history. Very cool. Jack
