  • June 19, 2025, 09:15:36 AM
Author Topic: Cutting Lightening Holes  (Read 6096 times)
Offline Brian_Carroll
« on: September 05, 2014, 06:58:28 PM »
I need advice or sources for tools for cutting lightening holes in balsa sheet parts.
Re: Cutting Lightening Holes
« Reply #1 on: September 05, 2014, 07:24:19 PM »
Hi Brian and welcome to Stunthangar!
As Ty said, brass tubing is about as good a anything.  If larger holes like 1", then aluminum tubing can be used.  Use a soft metal and an X-Acto blade will sharpen the tube.  All the metal removal comes from "slicing" the edge on the inside of the tube.
BIG Bear
RNMM/AMM
Offline Jim Thomerson
« Reply #2 on: September 05, 2014, 08:21:03 PM »
http://www.amazon.com/Cork-Borer-Nickel-Plated-Brass/dp/B006QNX890
If you want to go upscale get a set of cork borers.
« Reply #3 on: September 12, 2014, 08:51:39 PM »
Thanks guys.  3/4 aluminum tube sharpened with x-acto doing the trick.
BC
Offline Andrew Tinsley
« Reply #4 on: October 01, 2014, 02:29:38 AM »
For what weight I saved (surprisingly little), the hassle of hole cutting was hardly worth the trouble. Better by far to get good lightweight balsa in the first place would be my 2 cents worth.
Andrew
BMFA Number 64862
Offline John Jordan
  • Balsadust
« Reply #5 on: October 01, 2014, 04:08:19 AM »
      Try and find glass shop tools they have brass hole saws in all different sizes. Summer mecca catalog I think. Might be others though. Thanks John Jordan
John Jordan    ama # 5939
Offline Chris Wilson
« Reply #6 on: October 01, 2014, 05:57:23 AM »
I believe that an old steel and chrome telescopic car aerial can be dismantled and the tubes sharpened and used in a wonderful series of near sizes.
Sharpen the inside of the lower ends and the chrome will hold the edge nicely.
And best of all its just about free.
MAAA AUS 73427
« Reply #7 on: October 02, 2014, 07:42:08 AM »
Andrew
Andrew,
I can honesty tell you that the removal of "material" does remove weight.  Especially if you start out with balsa wood that should be tossed.
When I came back to CL, for my first CL builds, I used my "old stash" of wood that I had for building R/C models.
Wood that was just purchased from the large balsa supply houses. Probably extra heavy to say the least.
You say, " Better by far to get good lightweight balsa in the first place."
I believe you are absolutely correct on this issue and your opinion is valued at much more than two cents.
Here I am wasting time trying to do my best to lighten a model, when a more realistic "choice of wood" is the better approach.
Now I have a few models, even with my efforts to trim weight, that are still a bit heavy.
Live and learn. And in my case, generally the hard way.
I look back in hindsight and now it's understandable why I took critism from many of the experienced modelers.
Laying out a game plan to design and build a CL model, you cannot rule out the "importance" of using contest grade wood and as you said, lightweight balsa wood in the first place.
Proof of the pudding can be seen in Robert's videos.
I bit the bullet and reciently purchased contest grade balsa. $161.00 worth.
It's a start.
Offline Jonathan Chivers
« Reply #8 on: October 09, 2014, 04:38:38 PM »
Hi,
my local model shop (Avicraft here in the UK) offers a laser cutting service. So I make my plans in 2D CAD with  Draftsight (a free package) and take the file along to the shop  and they cut it. Any shape you want cut perfectly every time no mater how tricky the shape.
I am now experimenting with two programs called devFus and devWing. While these are paid packages, they are fairly cheap and they walk you through the design of fuselages and wings, including cutting lightening holes and automatically  creating building jigs. The files produced will still need finishing in Draftsight, but a lot of the hard work is done for you by the software. With both devFus and devWing you can download and install the software and look at their samples and experience with the end to end design process using only the demo key. Only sending money if you want to make full use.
With these products, you can start to think about how little material you actually need when you do not have to think about how the hell you are going to cut out the pieces!
Offline Curare
« Reply #9 on: October 09, 2014, 07:16:39 PM »
Lightening holes are all well and good, but there's a couple of things you should consider before tearing into your stock of lumber:
1. original stock weight, this has already been said before, if you're buying heavy wood, stop doing it!
2. reduction in structural integrity. If you put holes everywhere you may end up with a part that has the same overall shape, but has all the structural integrity of cheese, and swiss cheese at that. A little bit of extra trime spent utilising built up balsa structures will produce a better, lighter and stiffer product than a sheet part with holes in it. (Incidentally, if you have 8-9lb stock, stripping it down into sticks to do a built up tail is not a bad way to go.
3. finish. If you're doing something vintage or OTS having it full of holes is going to look wrong, or if you're going for a nice finish the holes can be a royal PITA. better to do a thinner built up structure and sheet it, and go about finishing it in your nomal fashion.
I used to put lightening holes in everything until I started to evaulate what I was doing, nowawadays if I need to lighten something I'll try to make more of a geodesic cutout rather than a pile of holes as loads are transferred better, and I can save more wieght removing material where it can be removed and leaving where it needs to be left.
Greg Kowalski
AUS 36694
« Reply #10 on: October 10, 2014, 03:06:54 PM »
No one has mentioned the problem of cutting holes in plywood.  You can put a bunch of holes in 1/16 ply and it will still be strong.
For small holes, I use brass tubing in a drill press when possible.
For larger, I have a set of Forstner bits, which cut cleanly without tearing.
« Reply #11 on: October 10, 2014, 08:08:13 PM »
I like Forstner bits, but they don't work really great on balsa.  They tend to load up with shavings, and the back side of the hole gets blown out.  Even when I try to bore a hole through a paper template stuck to the wood, the bits like to cut off a nice sharp disc of paper which blocks the cutter and keeps it from shaving away the wood.  It sort of works if you back the bit up and brush it off, and blow out hte hole before drilling a bit further and repeating.
Recently I needed to punch a hole in a rib in a built wing so I could visually inspect the bellcrank.  There wasn't room to get at it with a brass or copper tube like I'd usually use since i had maybe 2" before the next rib.  I looked around the bench for a second and found a tray of spent shell casings I picked up on my last trip to the shooting range.  Since steel cases generally aren't reloadable and have little scrap value, they are frequently left to rust away by the shooter.  I happened to pick up a few for hobby purposes.  I found that a .45acp case of Russian origin (soft steel) sharpened as nicely as brass tubing with a sharp X-acto blade.  I was able to bore a .45" hole in the 4# 3/32" balsa rib in about 3 turns.  Just with the trash cases in that tray, I can make short hole cutters for balsa from under 1/4" up to 3/4", assuming I can remove the plastic hull from spent shotgun shell cases without trashing the brass.  I might even glue some fine grit sandpaper around the base of the cases so they're easier to turn with fingertips.
Offline RogerGreene
« Reply #12 on: October 24, 2014, 06:31:25 PM »
Way back when lipstick caps were metal, brass, I made a hole cutter out of one. Also made some hole cutters out of brass tubing. I put a 3/32" wire through them for easier twisting. I generally make the lighting holes in a pattern that does not get any closer than 1/4" to the edge of the rib. I drill a 3/32" hole on the top of the lipstick so I can punch out the balsa "rounds" inside the lipstick cap. This wire can also push the "rounds" from the tubing cutters as will. I used a small round file to sharpen the hole cutters. Now I will use a #11 x-acto blade to sharpen. Good idea.
Hope this helps.
Roger
Fly Stunt <><
AMA 435R
USAF Veteran 1962-66 SAC
Life is 10% what happens to you and 90% of how you react to it. FAA #FA3RFLPAN7
