Building Tips and technical articles. => Building techniques => Topic started by: jim gilmore on March 28, 2009, 04:47:46 PM
I have 2 quetions on the qaakromaster I'm building.
First question is that when I glued in the engine mount blocks I first glue the blocks in and leave the doublers off. I do 1 at a time.On the lower block the mount doesnt fill the space so I took heavy card stock type paper. cut it folded it and epoxied it all together. I'm guessing that filling the space is better than a void?
My second question is that I'm considering adding a smallish false cowl? like the shoestring has . would that help with strength and vbration ?
I think you were right to fill the void--but I would have stuffed in some thin slices of balsa--however yours probably will be as strong--maybe even stronger.
A cheek cowl would look nice. I'm not sure how much strengthening or vibration dampening you need with these newer 2 stroke engines (FP, LA, or Thundertiger 10-15's). They already run pretty smoothly compared to the older iron piston engines.
As far as the motor mounts, normally test fit and if any gaps fill with balsa. Gaps are usually there to fit different size engine cases.
A tripler (cheek cowl) will add strength - to add to the vibration dampening - extend the "cowl" back and fix it to the leading edge sheeting- this will help transfer any vibration back through the airframe
