  • June 16, 2025, 09:10:11 AM
Author Topic: Primary force Wing  (Read 2083 times)
Offline Mike Griffin
Primary force Wing
« on: August 10, 2022, 03:27:03 PM »
The plans I had for the Primary Force were sent to me years ago by Mikey Pratt.  They did not show leading edge sheeting.  I think this is about the 8th or 9th PF I have built (did I mention I really like this model?) I just love the way it looks for a profile and it flies even better than it looks.  Hopefully this 2" wide sheeting will give it more strength.  Lots of sanding to do now.  Excuse the mess on the bakers rack in the background.
I still have to glue on the wing tips.
Offline Dwayne Donnelly
Re: Primary force Wing
« Reply #1 on: August 10, 2022, 06:56:30 PM »
Hi Mike, looking good, did you say a while ago that you were having problems with balsa dust? How's that going? I'm using a respirator now.
« Reply #2 on: August 10, 2022, 07:48:21 PM »
Hi Dwayne.  When I do a lot of sanding, I wear a N95 mask and it works against the dust.  Hope you are doing well.  I have not built anything in a while.
