  • July 14, 2025, 12:19:14 AM
Author Topic: Precision incidence tool.  (Read 13629 times)
Offline Perry Rose
« on: August 28, 2024, 07:35:18 AM »
I finally have something I can read. The Robart unit is stoneage compared to this.
Re: Precision incidence tool.
« Reply #1 on: August 28, 2024, 07:50:56 AM »
That's neat Perry.   Where did it come from?
Offline Perry Rose
« Reply #2 on: August 28, 2024, 09:00:48 AM »
The red mount is from www.ckaero.net the bar is what's left of a Robart incidence meter and digital angle gauge is from Amazon a Wixey digital angle gauge model No. WR300 type 2
« Reply #3 on: August 28, 2024, 03:03:43 PM »
OK I got it...Sanford and Son hardware....That is neat,   I'll probably copy you.  Thanks!
« Reply #4 on: August 28, 2024, 06:31:39 PM »
  Over the last 10 to 15 years or so , whenever I went to swap meets, I looked for Robart incidence meters, because I found that having 3 was pretty handy for setting up a an airplane and I like have spare tools of any kind. I could get them in the $5 range most of the time and don't think I spent over $1o for one if it was in really good shape. In recent years, swap meet participation has really dropped off and I haven't seen one in a long time. Does that mean all the good stuff is gone!!?? The extruded bar stock for the rail might not be hard to find or substitute something else for,  but making the pieces for the leading and trailing edges can be tricky I think and they need to be exact. I would hate to try and build an airplane with out them, one for the power plant, one for the wings, and I sometimes take the gauge off the rail to put on a flat stab or use one of those little square levels that weigh almost nothing. I just checked the Robart web site to see if they were still made since Robart announced they were eliminating some items from their catalog, and they still show it, at a $60 price tag now but is shown as Sold Out. their new Version 2 ,which is just the mounting bar with a cradle to hold a cell phone is also shown as Sold Out. I can't imagine putting a heavy cell phone on one of these at all, they need to be light, in my opinion, in order to function as well as possible. The little digital meter is nice, look way lighter than a cell phone!! If you can't get any of this stuff, it's back to drawing a straight line with a pen and then measuring with a ruler!!
Offline Jim Svitko
« Reply #5 on: September 01, 2024, 03:15:29 PM »
This was included in the Hangar 9 incidence meter.  The digital protractor weighs 1.4 ounces with the battery.
When I use the Robart tool, I rely on the bubble level that is part of the system.  I never trusted that needle and dial.
« Reply #6 on: September 01, 2024, 09:49:41 PM »
How do you know when the flaps are at zero?
« Reply #7 on: September 02, 2024, 11:28:32 AM »
That can be a tricky matter.   I’ve found the meter can fool you in this measure and it can end up off maybe a degree or less by some anomaly.   I’ve taken to making flap centering tools that are much more accurate.
Offline Jim Svitko
« Reply #8 on: September 02, 2024, 01:03:36 PM »
I have settled on building with fully sheeted foam wings but I suppose this method can be used for any other wing.  I tack glue a small block to the wing upper surface, and shim that block until a small bubble level on it reads zero when the Robart tool bubble reads zero.  I do not fully taper the flap thickness so there is enough flat surface on it for the small bubble level.  When both bubbles show zero, I am satisfied that the flaps are at zero with respect to the wing.  I have done it this way for quite some time and it works well enough for me.
« Reply #9 on: September 03, 2024, 10:15:47 AM »
Good Idea.  How far in do you slide it?
« Reply #10 on: September 03, 2024, 02:00:25 PM »
Ken about as far as I can.   Most my landing gear are wing mounted so I use a rib copy of the first rib outside the gear for a pattern.   I’ve made 6 or 7.  I find I can get away with using one of them I already have even if it’s not a perfect fit on the airfoil.
