  • August 01, 2025, 09:10:17 AM
Author Topic: Primer question for Sparky  (Read 2639 times)
Online James Mills
« on: April 20, 2006, 07:49:28 PM »
Sparky,
Couple of questions about the spray can primer:
     1.  How long do you wait to sand off the primer?
     2.  Is humidity a factor when using this type of primer.
     3.  How many coats are you spraying?
James
AMA 491167
Online RC Storick
Re: Primer question for Sparky
« Reply #1 on: April 20, 2006, 08:10:39 PM »
Sparky,
     1.  How long do you wait to sand off the primer?  Till it flashes off
     2.  Is humidity a factor when using this type of primer. NO
     3.  How many coats are you spraying? As many as necessary. you end up sanding it all off
James
Online James Mills
« Reply #2 on: April 20, 2006, 09:25:25 PM »
Thanks Sparky.
James
AMA 491167
