  • June 19, 2025, 11:28:35 AM
Author Topic: ployspan adhesive?  (Read 1601 times)
Offline Alan Buck
ployspan adhesive?
« on: February 17, 2010, 11:13:10 AM »
Which better or preferred way to put on ployspan. nitrate or butyrate dope. I also have some SIG stix-it to. The wing to be covered is a Stiletto 660
ALAN E BUCK
Re: ployspan adhesive?
« Reply #1 on: February 17, 2010, 09:12:06 PM »
Yup, just like Ty said. The nitrate seems so be just a little "stickier" for attaching covering. I usually give it another coat of thinned nitrate around the edges, again rubbed in with fingers, before hitting it with the heat gun. Should work out good.
Offline Roger Vizioli
  • CLiner
« Reply #2 on: February 17, 2010, 10:03:53 PM »
HI Alan. I use both. It's and either or situation. I like Nitrate as it appears to fill the wood quicker and is generally thicker.  I apply 4 or 5 sanded coats to the wood, until it is sort of shiny, then use thinner to dissolve the dope through the covering.  I rub it in with my finger tips. Then once it, the dope is dry, I use the heat gun. Very carefully. My first time I melted runs in one wing.  Keep the shiny side of the polyspan up. But then you knew that.    H^^
Ty,
Have you used it on a "Polywog" type airfoil and if so, did it hold?
Roger V.
Roger Vizioli
AMA L-2408
Florida/Space Coast
  • CLiner
« Reply #3 on: February 18, 2010, 08:16:30 AM »
Thanks Ty!
Roger
Roger Vizioli
AMA L-2408
Florida/Space Coast
« Reply #4 on: February 19, 2010, 08:57:30 PM »
If you have a really serious problem with polywog or undercambered airfoils, you might take a look at "Fabric Cement" at your light plane supply store of choice. As I understand it, it's used for the pinked tape over the ribs and such on fabric covered planes. It can be used much as Duco or Ambroid, and I suspect it's very close to Duco (or "Tarzan's Grip") household glue.  D>K Steve
  • CLiner
« Reply #5 on: February 19, 2010, 09:30:00 PM »
Thanks Steve.
Will try it on a test piece.
Roger V.
Roger Vizioli
AMA L-2408
Florida/Space Coast
« Reply #6 on: February 21, 2010, 11:09:45 PM »
Hi Alan,
I really like NITRATE for my substrates and to attach covering.  Bob Hunt turned me on to it many years ago.  I usually use Sig, since I can get it when I do make it to the Hobby shop.  But I prefer to use Randolph's Non-Tautening Tinted Nitrate.  It is my favorite. ;D
Big Bear
