  • July 04, 2025, 06:39:40 PM
Author Topic: Plastic Covering Question  (Read 1492 times)
Offline Dick Pacini
« on: June 16, 2012, 10:11:44 PM »
First of all, I know very little about plastic coverings, although I bought an iron and sock and a heat gun in anticipation of future needs.
A while back, I bought a Brodak P40 ARF and have had it up a couple of times.  Last time out, I ran out of fuel in the clover and ended up slack lines into the ground , hitting on the outer wingtip.  It was obvious that internal damage occurred because the covering was wrinkled.  I went home and opened it up.  There was a broken rib and a cracked wingtip.  I had previously obtained a few feet of Brodak covering in gray, camo green and black in anticipation of repairs.
I got the tip rebuilt and made my first attempt at plastic covering.  I cut a piece of the gray to fit, but it wouldn't stick.  All it did was shrink.  At this point, I thought I got bad covering or I was missing something.  I looked at the roll of camo green and the roll of black and discovered a transparent backing that could easily be separated from the face sheet.  Both the camo green and the black had one edge that showed the transparent backing.  However, the gray roll didn't have that edge leader that made it possible to pull apart.
So, my question is how to separate the backing from the color side when there isn't anything to grip?  I spent quite a while trying to find a way to remove the backing and finally achieved results with the help of an Exacto knife.   There must be a better way!  At any rate, I recovered the repaired wingtip with success.  At this point, I have a better understanding of the process of covering, but still need to know how to separate the backing sheet.
AMA 62221
Re: Plastic Covering Question
« Reply #1 on: June 16, 2012, 10:22:47 PM »
Ultracoat has a backing that isn't stuck to the film.  Brodak's film does it the way Monocoat does.
You want to cut the pieces oversized where they extend past the wing tips anyway, as this aids in getting them stuck down.  What I do when I cut a piece of covering from the middle of a roll of monocoat is stick a corner with a pin or an X-Acto knife, then pull the sheet out sideways to the blade.  This rips both the covering and the protective film, and (usually) gives you something that you can start teasing the sheets apart.
I don't know if there's a better way.
Offline nathan Metzner
« Reply #2 on: June 16, 2012, 11:16:25 PM »
Dick, try putting two pieces of scotch tape, one on each side and rubbing it in and then pull the pieces apart.
Nathan, New guy, Newbie, Youngster, Pleeb, So on and so on
« Reply #3 on: June 17, 2012, 07:58:22 AM »
Most times tape(masking or Scotch) placed on both sides will help seperate the backing and the covering.   I use the tip of my X-Acto knife to start the seperation of the two peices. H^^
Offline Dick Pacini
« Reply #4 on: June 17, 2012, 09:56:33 PM »
Well, once I got the covering free of the carrier sheet, I repaired the wingtip with satisfactory results.  The patches were about 4X6 and extended from the last wing rib to the tip.  The broken rib was the tip rib.  I used the iron to seal the edges and then shrunk the center areas.  I was satisfied with the results, since I had never used plastic covering before.  After it was all sealed and shrunk taut, I painted on a layer of epoxy around all the edges, to prevent exhaust leakage and to be sure it wouldn't come loose.  I am intrigued enough to try to cover a plane.  I have a Walter Umland Coyote almost finished and am toying with the idea of orange Ultracote with black trim.  I scratch built the Coyote in 1968 when it first was published and painted it orange and black.  I think I need to get this out of my system to decide if I like it or want to go back to silkspan and dope, which I haven't done since 1975.
AMA 62221
« Reply #5 on: June 18, 2012, 09:52:55 AM »
Sometimes covering the whole plane in plastic is more tedious for me than doing the wings in plasic and the rest in dope.   Dope will stick to plastic if it is scuffed a little with a scouring pad.  Yes, I have done complete plastic covering on a couple of planes.  Cover the joints(fuse to wing and fuse to stab)  with strips of the plastic.   Then cover the main portions.  It takes practice and patience.   H^^
Found a couple of pictures of plane done completely with Monokote.  Including the graphics. jeh
« Reply #6 on: June 18, 2012, 05:04:44 PM »
Dick, I hope that tape method worked for ya. John that plane looks awesome. I really like designs that are not the norm.
Offline Dick Pacini
« Reply #7 on: June 18, 2012, 11:36:36 PM »
That worked!  Thanks!
AMA 62221
