  • June 15, 2025, 07:51:03 PM
Author Topic: pathfinder LE building  (Read 55671 times)
Offline fred cesquim
    • Fred Cesquim Aeromodelos
« on: March 21, 2022, 04:25:20 AM »
i was gifted this great RSM kit from a friend, and started yesterday, so far so good
will be e-powered
one balsa rib sheet was missing and a surplus ply reinforcement rib sheet came as a surplus, i bet someoneīs have the inverted situation
fortunately i had one of each missing ribs to make a copy
Online Motorman
Re: pathfinder LE building
« Reply #1 on: March 21, 2022, 09:34:13 AM »
Nice gift!
Offline Jim Hoffman
« Reply #2 on: March 23, 2022, 02:20:00 PM »
I had missing parts (entire wood set for Stab and elevator) in a Brodak kit about two years ago.  I called the factory and they made it right by sending me the pasts needed
« Reply #3 on: March 24, 2022, 04:46:44 AM »
i am pretty sure RSM would do the same, but as i live in Brazil i opted to cut the missing ribs myself and save them the trouble
had to stop the building for a while, doing a cockpit for a 1/4 scale focke wulf that took most of my workshop space
« Reply #4 on: April 18, 2022, 01:37:16 PM »
finally made some progress
tail needs airfoil shape sanding
have changed nose design for e-power. cowl is not needed anymore, and iīll insert engine form the nose, and battery via a side window. I ended up with a "curare" (70īs famous F3A plane) nose profile.
also shortened the fuse widht about 1/2 all the way as no pipe will be used.
« Reply #5 on: April 18, 2022, 01:44:35 PM »
wing was built within 6 hours tahnks to the clever jig design.
i was skeptical with the 1/4 x 1/8 balsa longerons, but after adding the short ribs everything is safe and strong. my admiration for Gordonīs design, really light and clever
only deviation from the kit: they send balsa to make a molded C full leading edge sheeting (just like the thundergazer). i really have my doubts if thatīs good and that glue will properly reach every spot. instead of doing that ( wich is a lot of extra work too) i have cut a new LE spar 3/32 wider and had a 1/16 extra lip on the ribs LE. this lip sits on my alluminium JIG. then i glue the sheeting on the lip with CA ( sheet 90 degrees to the spar). moisten the shee with windex, apply titebond to the ribs and run CA to the central longeron, folds the (now pliable) sheeting over and attach to the spars. no need to clamp or pin, and you finish within minuts. this way the glue reaches every point of contact of wood and you ended up with a warp free wing.
Online Motorman
« Reply #6 on: April 18, 2022, 04:19:58 PM »
You would have to make a foam leading edge buck to mold a full clam shell for the leading edge. The (rsm) kit kind'a leaves you hanging in that respect. I've seen other (rsm) builds on here for Thundergazer ect and the builder always engineers a way around that problem. Glad you worked it out. My solution was to sell the kit.
Motorman 8)
« Reply #7 on: April 18, 2022, 05:50:24 PM »
Motorman 8)
the kit comes with LE templates and instructions to do that, i just donīt think itīs a good method at all, same with thundergazer. i came with this solution while building the Tgazer and since then all of my planes uses the same technique for sheeting LE. with this method you donīt need to shape LE anymore ( a thing that i hate and know itīs paramount for good tracking)
wingīs almost done now
regards bro brazil
« Reply #8 on: April 18, 2022, 05:53:32 PM »
hope pictures show how it works
« Reply #9 on: April 29, 2022, 02:51:33 PM »
wing is ready
fuselage is next
« Reply #10 on: April 30, 2022, 07:48:18 AM »
fuselage stuffing
Online Brent Williams
« Reply #11 on: April 30, 2022, 10:48:13 PM »
What size motor and battery do you plan to run?
« Reply #12 on: May 01, 2022, 08:13:10 AM »
wing is ready fuselage is next
Nice weight.  What kind of scale are you using,  I need one that gives me lighter wings! LL~
ken
« Reply #13 on: May 02, 2022, 04:00:31 AM »
ken
golden trick to do is: block up wing tips with foam pads while using the scale   ;D ;D
« Reply #14 on: May 02, 2022, 04:04:12 AM »
tempest 3515 740 KV , fiorotti timer and 6S battery (but i will test a 5s) .
« Reply #15 on: May 03, 2022, 07:26:58 AM »
fuselage is halfway through
easy and fast to build
Online Motorman
« Reply #16 on: May 03, 2022, 02:30:31 PM »
Have you calculated a path for the cooling air?
« Reply #17 on: May 03, 2022, 04:40:03 PM »
guesswork will start after shaping the nose. ;D
my previous 3 planes had similar nose, so probably will follow the same route
any advice on that? i plan to do something like the starduster
« Reply #18 on: May 09, 2022, 11:00:45 AM »
nose done
« Reply #19 on: May 12, 2022, 05:31:35 PM »
just need to open ventilation holes and add a wing to the fuselage
Offline Crist Rigotti
« Reply #20 on: May 12, 2022, 08:54:24 PM »
Sweet!
« Reply #21 on: May 13, 2022, 05:04:50 AM »
Sweet!
thanks Chris, canīt wait to add wing/tail and see how she looks
regards from brazil
John A Miller
« Reply #22 on: May 15, 2022, 07:55:49 PM »
Nice job. I think it'll be a looker when you finish it and start flying it. You might be surprised how n ice i flies.
Here're a few pics of mine at Brodaks'.
« Reply #23 on: May 16, 2022, 04:17:10 AM »
thank you
lovely plane of yours!
really liked the tainted cockpit!
« Reply #24 on: June 04, 2022, 06:38:21 AM »
now itīs progressing fast
next is turtledeck and tail fit
« Reply #25 on: June 07, 2022, 05:04:12 AM »
she looks good!
« Reply #26 on: June 20, 2022, 04:05:35 AM »
bare bones with wheels weight, ready to star finishing process
« Reply #27 on: June 20, 2022, 04:07:09 AM »
made a fiberglass canopy ( will be painted) and saved some 10 grams
just need flap/fuse fairings and will start dope/carbon veil on fuse and monokote wing/stab
« Reply #28 on: June 21, 2022, 03:58:18 PM »
brodak superfill time
« Reply #29 on: June 21, 2022, 09:35:19 PM »
 Fillets before covering?
« Reply #30 on: June 22, 2022, 04:52:26 AM »
yes, monokote will stop before the blue tape and fuse will be painted. so paint will cover the fillets and 1" of wing with a 1/4 overlap over monokote
« Reply #31 on: August 05, 2022, 03:56:08 AM »
after some hiatus, finally monokoting
i had monokoted the wings before, bit the product was strange, not performing like used to, and had some color flaws....i gave up, stripped everything and bought a new fresh roll. worked perfectly.
looks like someone put a prank on me and sold me chinakote instead before...or just a bad batch of product
next is carbon veil on fuselage, but vacations is near, iīll be back next month
« Reply #32 on: January 11, 2023, 04:08:20 PM »
after some rainy days, primer was shot
« Reply #33 on: February 23, 2023, 07:04:18 AM »
double sanding day
dope on the hellcat and primer on the pathfinder LE
looks like iīll have 2 new planes by july, hopefully!
finally rain gave a break here
Offline John Miller
« Reply #34 on: February 23, 2023, 03:56:21 PM »
They're both coming along really well. Looking good. H^^
« Reply #35 on: February 24, 2023, 04:11:58 AM »
thank you John!
i am anxious waiting better weather to star painting them!
letīs see what March brings ( althoug here in Brazil march is the month with most rain)
regards
« Reply #36 on: February 24, 2023, 08:32:24 AM »
Nice work!
Offline Chuck Matheny
« Reply #37 on: March 05, 2023, 12:40:54 PM »
Fred..thanks for the inside look at this great looking plane...!
I really like your leading edge jig..and the leading edge architecture too.
« Reply #38 on: March 07, 2023, 10:02:24 AM »
thaks indeed!
this type of LE is my standard for a long time now, the easyest to sand and round perfectly
after sheeting you just trim and sand slightly and done!
« Reply #39 on: March 15, 2023, 01:09:44 PM »
since i had to clean the spray gun....primed both models
« Reply #40 on: March 30, 2023, 03:53:02 AM »
sheīs ready for color dressing
now the fun begins
Offline Gary Dowler
« Reply #41 on: April 01, 2023, 10:03:17 PM »
Extremely well done on covering the wingtips!
Gary
« Reply #42 on: April 03, 2023, 07:22:58 AM »
Gary
thank you Gary, i really love monokoting! had done 100+s of r/c models monokote coverings ( worked as a builder for 30 years) so i developed some skills. unfortunatley monokote is off production righ now..oracover delaminate with age....not sure what to do next
« Reply #43 on: September 28, 2023, 02:07:53 PM »
after some issues and a house renewall i am back to work
swithced the white monokote to red! (donīt ask!)  ~^
« Reply #44 on: October 06, 2023, 05:34:32 AM »
getting closer, miss canopy, blue on rudder, checkers, ink lines and clear coat
« Reply #45 on: October 06, 2023, 09:45:51 AM »
That looks awesome as it sits.  I await the finished product. D>K
« Reply #46 on: October 13, 2023, 02:39:36 PM »
thanks Bob and John!
painting is done! now comes the ink lines, so far so good!
have a nice weekend guys
regards from brazil
Offline Mike Quinn
« Reply #47 on: October 14, 2023, 03:15:29 PM »
Hello
Very nice.
Can you describe your inking process?  Tools, templates, inks etc.
That woukd be really useful.
Cheers
« Reply #48 on: October 18, 2023, 01:39:11 PM »
Hello
Very nice.
Cheers
i May do a step by step dedicated thread sometime soon! just about to leave on vacation and had no time to photograph the work this time
model is clear coated, upon my return will polish and fly her
Offline Mike Morrow
« Reply #49 on: October 18, 2023, 04:01:53 PM »
Never seen a 20 point finish up close and personal but that is mind blowing.
