  • July 15, 2025, 08:26:25 PM
Author Topic: Parchment paper or Baking paper  (Read 6185 times)
Offline Ty Marcucci
« on: July 07, 2013, 02:17:41 PM »
I use this stuff when I don't want anything to stick to it. You can see through it, but not as well as wax paper.
« Last Edit: July 12, 2017, 10:17:14 AM by Ty Marcucci »
Ty Marcucci
Re: Parchment paper or Baking paper
« Reply #1 on: July 07, 2013, 03:01:23 PM »
I just use waxed paper.  It works great, and unless you let the CA just drool on it, things don't stick.
Offline Phil Krankowski
« Reply #2 on: July 09, 2013, 07:53:05 AM »
Try Glad Press-n-seal.  CA doesn't stick to it.  Celluloid doesn't stick to it.  Epoxy doesn't stick to it.  Wood glue and PVA doesn't stick to it.
The film is slightly adhesive and sticks to paper, but will peel off the paper easily too. (I haven't tried after several months though)
Phil
« Reply #3 on: July 09, 2013, 08:14:05 AM »
If you use press&seal on your plans and leave it for several months, do not, I say do not try to remove it.  It becomes part of the plans.  I use it for masking details on my planes thou.
Offline Curare
« Reply #4 on: July 09, 2013, 10:56:26 PM »
I recently build a peanut scale tiger moth using CA, and used baking paper for that, once the pins were removed the whole airframe (only 10" long just slid off the plan.
Here in Australia we have stuff called Glad Bake, it's not cheap but it does work!
Greg Kowalski
AUS 36694
Offline Tom Niebuhr
« Reply #5 on: July 10, 2013, 09:24:53 AM »
Ty,
I use parchment paper all the time. Nothing sticks to it.
You can get it in all super markets. It will be in the section with wax paper. This was an Al Rabe tip.
AMA 7544
