  • June 08, 2025, 06:23:29 AM
Author Topic: painting small parts  (Read 4241 times)
Offline t michael jennings
  • AMA 83322
« on: April 02, 2007, 12:51:08 PM »
What method do you have to hold and spray paint small parts?
Items such as engine cowls, wheel pants, rudders, horizontal elevators and flaps are painted prior to assembly on the aircraft.  These parts are difficult to hold and spray paint.
Items such as the engine cowl needs spray painting on both inside and outside.  Do you paint both inside and outside at the same time or paint inside and wait until it's dry to paint the outside?
Photos are likely the best answer.  They are easier for all to understand.
t michael jennings    :-\
Re: painting small parts
« Reply #1 on: April 02, 2007, 01:04:37 PM »
Unfortunately, I'm not at home or I would post a picture, but I build holding jigs. Chunk of balsa with 1/64" plywood sticking up for the hinge slots to slide onto for control surfaces. The cowl I use a chunk of balsa with a hardwood block and blind nut for it to screw onto. I've come up with other things to hold various parts. The main airfram stays on the holder.
Offline Dick Fowler
« Reply #2 on: April 02, 2007, 01:11:51 PM »
I once painted a "smiley face"  :) on my small part!  Wife was amused!  H^^
Dick Fowler AMA 144077
Kent, OH
Offline Leester
« Reply #3 on: April 02, 2007, 02:25:45 PM »
Your Sick, Twisted and Warped !!!  All qualitys I admire in a person. LL~ LL~ LL~ LL~ LL~ LL~ LL~ LL~ LL~ LL~ LL~ LL~ LL~ LL~ LL~ LL~ LL~
Leester
ama 830538
Offline Bill Gruby
« Reply #4 on: April 02, 2007, 03:37:52 PM »
I can't LL~  LL~ do it  LL~ I can't LL~ LL~ LL~ stop laffin LL~ LL~ LL~ You are one warped animal.. I love it.
   "The G-Man"   S?P VD~ S?P
Bill Gruby
AMA 94433
MECA 5393-10
« Reply #5 on: April 02, 2007, 04:08:57 PM »
I do things a lot like Randy Powell.  I have little (no pun intended) jigs I make out of wire and such to hold flaps and elevators.
One thing I make use of is paint mixing sticks.  I tape things, like wheel pants, to them to paint.
Bill <><
(now the rest of you guys, CUT IT OUT!! ;D)
Offline Bill Gruby
« Reply #6 on: April 02, 2007, 04:22:50 PM »
                                                O  LL~ LL~ LL~ K
      "G-Man"
Bill Gruby
AMA 94433
MECA 5393-10
« Reply #7 on: April 02, 2007, 04:25:36 PM »
Bill,
Of course you do things like me. Why wouldn't you.   VD~
Offline Dick Fowler
« Reply #8 on: April 02, 2007, 04:50:27 PM »
Did I ever tell you about the time I used lacquer thinner to remove a smiley face from my small part?  ~^ Pretty impressive until the swelling went down!  Again, wife was amused. H^^
PS - Kind of looked like my avitar.
Kent, OH
« Reply #9 on: April 02, 2007, 05:39:12 PM »
QUIT IT!!!!!!!!!!!!!
(and I mean it if I ever stop laughing!)
Boy, I hope Sparky don't see this!
Offline Dick Fowler
« Reply #10 on: April 02, 2007, 05:53:02 PM »
Don't worry Bill... I'll never do that again  H^^
Kent, OH
Offline Joey Mathison 9806
« Reply #11 on: April 02, 2007, 05:55:10 PM »
                                               so that is how you got your name ;D
200 mph man ama#9806 joey mathison
Offline Bill Gruby
« Reply #12 on: April 02, 2007, 10:02:26 PM »
                                             LL~ LL~ VD~ LL~ LL~
   "G-Man"   S?P
Bill Gruby
AMA 94433
MECA 5393-10
« Reply #13 on: April 02, 2007, 10:27:57 PM »
Or at least not until the next time!  LL~ LL~ LL~ LL~ LL~  H^^
Offline minnesotamodeler
  • Me and my Chief Engineer
    • Minnesotamodeler
« Reply #14 on: April 03, 2007, 02:21:57 AM »
Poor MIchael...asks a serious question and this is what he gets.
--Ray
AMA902472
Offline Keith Spriggs
    • khspriggs
« Reply #15 on: April 03, 2007, 06:57:23 AM »
I once read a tip that you could hold small parts for painting by sticking a pin in them. NEVER AGAIN
Offline Warren Wagner
  • Bradenton, FL
« Reply #16 on: April 03, 2007, 06:58:39 AM »
Michael,
There are a lot of good brains to pick on this forum, and one of the best is Randy Powell's.   Randy showed his manner of holding small parts for painted, I tried it, and it works great.
Mine are slightly different from his, but you can modify things to suit your own needs.   The base for mine is some 1/2" X 1" stock, with a cross piece glued on so that the holder will stand on its own, and a hook-eye in the end for hanging on the drying rack.
For the control surfaces, cut pieces of 1/32" ply the same width as your hinges, and a couple of inches long, and put two of them in your control surface, and THEN with a large staple gun, staple the plywood to the base.   Each holder has to be custom made to fit each different control surface, because no two are ever the same.   But you can keep one piece of plywood in place, and move the second one as needed for future projects.
As far as the cowl is concerned, each job is a little different.   You should be able to use the mounting brackets, and make a simple custom jig to hold the cowl.
Save all the holders that you make, because they can be modified to work with future builds, and a lot of time time will be saved.
These holders do make life a lot easier when painting.  You can prepare each part, mount it on a holder, do the final clean, and then hang them up in preparation for painting.   As you paint, you can take each one down, one at a time, do your spraying, and hang them up again to dry.
Great idea.....thanks, Randy !!   (See...we are paying attention)   :-)
Cheers,
Warren
Warren Wagner
AMA 1385
« Reply #17 on: April 03, 2007, 08:48:22 AM »
Warren,
Thanks for posting a picture. That's it, indeed. Works well. I have a stack of different setups under my workbench. Usually can find something close enough to work for a given parts.
Nice work, by the way.
Offline Bill Gruby
« Reply #18 on: April 03, 2007, 09:29:16 AM »
Randy;
  By the looks of that picture you people are using a thick hinge? What type or manufacturer is it, and where are they availlable. I like the way the hang rigid.
 "Billy G"   H^^
Bill Gruby
AMA 94433
MECA 5393-10
  • Bradenton, FL
« Reply #19 on: April 03, 2007, 11:27:03 AM »
Randy;
 "Billy G"   H^^
Billy,
I'm a little confused by your question.  What do you mean by "...the way the (sic) hang rigid..."?  What you see in the photo is the 1/32" plywood "dummy hinges".
 The hinges I use are made by Klett Plastics, #208.  Not sure where they are available anymore....they're getting more and more difficult to find, though DuBro makes one that is very similar, with a slightly smaller diameter pin.
The hinges are 5/8" wide, 1" long (total of both halves), and 1/32" thick....very convenient for the 1/32" plywood "dummy hinges".
If it's still not clear, please ask away.
Cheers.
Warren Wagner
Warren Wagner
AMA 1385
Offline Bill Gruby
« Reply #20 on: April 03, 2007, 11:45:44 AM »
Warren;
     Sorry about the confusion------You have answered my question exactly. There are still a couple of HS's in my area that have been around for a while. I will check them out for these hinges.  Thank-you.
  "Billy G"   H^^
Bill Gruby
AMA 94433
MECA 5393-10
  • Bradenton, FL
« Reply #21 on: April 03, 2007, 02:07:18 PM »
Warren;
  "Billy G"   H^^
Billy,
Don't sweat trying to find the Klett brand hinges....if they are available, great....use them.   A quick Google search did not come up with "Klett Plastics", the company that made them, or any distributors that were selling them.  Tower doesn't have them.
The DuBro #117 is very similar and readily available.    The barrel on the DuBro is a little smaller in diameter, so I preferred the Klett.
The very best glue to install the hinges with (this will generate some debate) is "Pacer Hinge Glue" #PT-55.  I've run tests with that glue and several other water-based glues, and the Pacer is head and shoulders above the others for adherence to the plastic used in the hinges.    I didn't consider epoxy, because it is difficult to clean up, and the strength is just not necessary.  If tested destructively, the Pacer will remove balsa before the joint will come apart.  If you have reservations, run a simple test and see for yourself.
Cheers.
Warren Wagner
Warren Wagner
AMA 1385
Offline Bob Disharoon
« Reply #22 on: April 03, 2007, 04:45:30 PM »
Ive found that painting large parts is easier than "rigid" hanging small parts because the large parts dont have to be "rigid" to hang because of the fact that the large parts are bigger than the small ones even when they are not "rigid" but when the large parts are "rigid" you dont have to hang them like you do with the small parts because you can paint the non "rigid" side first and the "rigid" last because at that time of the procedure the wife is able to help out much easier because she does not have to waste time fooling around with the non "rigid large parts and I fall asleep.Any questions?..BOB
« Reply #23 on: April 03, 2007, 11:15:55 PM »
Warren, I both them in bulk a coulpe years ago directly from Klett.  Went in with others and bought 1000 (minimum "Bulk order").
I understand, but haven't checked, that Klett HAS stopped production of their hinges...........  b1
Bill <><
