  • July 09, 2025, 11:04:29 AM
Author Topic: P D K Ring master J R  (Read 6369 times)
Offline Bootlegger
« on: September 01, 2016, 10:52:57 AM »
  Has any body built a Pat King Ringmaster Jr, if so how well did you like it, and would you build another?
   T I A...
8th Air Force Veteran
Gil Causey
AMA# 6964
Re: P D K Ring master J R
« Reply #1 on: September 01, 2016, 10:56:57 AM »
If it is typical of his kits, it will be an easy build.   His kits that I have built came out light and straight.   It's the finish I added weight, but they fly great with the right engine/motor.
Offline dennis lipsett
« Reply #2 on: September 01, 2016, 11:10:40 AM »
Doc is right in that they are easy builds. This is an early build and it is powered with an OS10 FP and is more than adequately powered. Keep it light and you just might get the pattern in with it.
Dennis
Online badbill
« Reply #3 on: September 02, 2016, 10:48:44 AM »
   T I A...
Here's mine. I really enjoyed the build, awesome kit. The packaging didn't work to well, it had a broken leading edge and spar when I got it... I just glued them back together. I didn't enjoy bending the LG wire, but it still turned out good and flies great.
http://stunthanger.com/smf/open-forum/my-latest-a-jr-ringmaster/msg456278/#msg456278
Bill Davenport
AMA 28141
Online badbill
« Reply #4 on: September 02, 2016, 11:02:41 AM »
I just realized that I didn't answer your last question, would I build another. YES, I would. Matter of fact, I have a hankering for a Ringmaster JR Flash to replace the one I crashed on it's first flight when I was a kid. His kit of that looks great!
Also, I was looking at the pic of the one in the post above mine, and realized that I also altered my rudder a little bit to make it the shape of the one on my big Ringmaster. Not sure which is right.
Bill Davenport
AMA 28141
Offline Duke.Johnson
« Reply #5 on: September 02, 2016, 12:11:34 PM »
I built one a few years ago and it's an easy build and flies great. I put a OS 15FP on mine and it will do anything you ask it to do.
Offline pat king
    • PDK LLC
« Reply #6 on: September 02, 2016, 12:31:14 PM »
I thank everyone for the kind words. The Vertical Stabilizer on my Ringmaster Jr. kit is not the same shape as on a Ringmaster S1 because my kit has the same shapes as the Sterling kit S5 Ringmaster Jr. . That did not have the same shape as the Vertical Stabilizer on the Ringmaster.
Pat
Pat King
Monee, IL
AMA 168941
Offline Allan Perret
  • Proverbs
« Reply #7 on: September 27, 2016, 04:02:43 PM »
Dennis
Gotta love the checkerboard, Monocote ?
Allan Perret
AMA 302406
Slidell, Louisiana
Offline Joseph Patterson
  • AMA member- Supporter
« Reply #8 on: September 28, 2016, 07:03:58 AM »
    Gil you still have the RING jr. I gave you? It has hung on your shop wall for years! Your PET 09 or OS 10 will be good for it.
         Doug
Offline Bootlegger
« Reply #9 on: September 28, 2016, 11:13:01 AM »
 Doug I have flown  the "socks" off that thing with that O S Pet .099, it only weighs 16 OZ ready to fly.  Sorta thinking about one of Pat Kinks versions for my next build.
Gil Causey
AMA# 6964
« Reply #10 on: September 29, 2016, 06:36:11 AM »
Go for it,  He has several kits I would like to have if I didn't have so many.   Found out I already have his Ringmaster Flash along with a couple of other kits.    Besides as the commercial goes,  "Its your money use it the way you want".   H^^
Offline James Holford
« Reply #11 on: October 09, 2016, 02:58:52 PM »
Considering getting the Jr. Myself............
Jamie Holford
Baton Rouge Bi-Liners
Lafayette, La
AMA #1126767
Offline Bootlegger
« Reply #12 on: October 10, 2016, 07:42:58 AM »
  Mornin Guy's,
  I have ordered one an am lookin forward to building it.  Need to find another os 10 for power, and get started when the kit arrives.
  We have our annual contest this week end (Oct 15 & 16) here in Baton Rouge La.  All the info is in the events section here on Stunt Hanger.
       Thanks for that Sparky... y1
Gil Causey
AMA# 6964
« Reply #13 on: October 10, 2016, 07:49:30 PM »
   T I A...
A picture or 2 of the Ringmaster Flash. Power is a 15X. Pat King may still have this one in his collection.
Dennis
« Reply #14 on: November 06, 2016, 05:51:32 PM »
    Dennis that is a sharp looking airplane! I have to admit I have never really seen a ringmaster Flash. Gonna go have a look at Pat's vendor site!
« Reply #15 on: November 07, 2016, 11:59:25 AM »
Would you believe I have one of his Ringmaster Flash in a box under a stash of plans.  Had forgot all about it if I hadn't been looking for the plans of another plane.
Offline Bootlegger
« Reply #16 on: November 09, 2016, 01:00:11 PM »
 Nudder question, does any one use the stock lead out location on Pat's Ring Jr? And if not how do you make up your adjustable L/E guide??
   Again thanks..
Gil Causey
AMA# 6964
