  • July 08, 2025, 02:29:13 PM
Author Topic: P 51  (Read 6374 times)
P 51
« on: April 06, 2015, 10:04:55 PM »
Seeing I accidently crashed someonesles P 51 trip , will throw these here , as its got some Building Tecniques . Descernable clicking on the pretty pictures .
Re: P 51
« Reply #1 on: April 06, 2015, 10:05:27 PM »
Re: P 51
« Reply #2 on: April 06, 2015, 10:07:07 PM »
youll have to click on these others here " http://stunthanger.com/smf/index.php/topic,38778.0.html "
to get the detail , if your after it . Hardly discernable on the pansey wee things . there down below .
« Last Edit: April 06, 2015, 10:39:19 PM by Matt Spencer »
Re: P 51
« Reply #3 on: April 06, 2015, 10:08:39 PM »
Re: P 51
« Reply #4 on: April 06, 2015, 10:33:12 PM »
At the moment its heading this way .
Had it all done very nicely , with the scoop etc in 98 , but a ascarlewt woman said she " Dropped a Load of Steel through it "
and a few others . I saw here destroying them . Seqquentially . A years work down the drain & a foul odour for Melbourn fo life ,
in my books . ANYWAY .
Threw this togeter last week or so . But sides are to soft ' Contest ' 3 / 32 . Planks are 1/8 & lower under ( shown ).
The tops a sheet of 1/4 let in between upper 1/8 runners . BUT i got it ( pressed Down 0 to low forward .
Working at 3 am with wombles tittering adjacent to get me Isomnic .
Tip ribs are 60 apart . Owes a lot to Al Rabe but designed outside his formular , though parralell .
Scale Dimensions for datumns , Tryn ta keep the aft light ( Tissue Cover ) and C.G. Fwd , with a
Airfoil to suit , so it ' Points ' a way , an hopefully ' hooks in ' to the turns , and doesnt bounce .
We Shall see , a way to go yet . doghouse up next - the F51H type as in the picture .
Ive used this ' planked Curve ' tecnique severaly . But the P 47 'l have a be Moulded if its for The Stalker .the bog Stalkers .
This gets you a P 51 without a lot of set up , but ou need to use a ruler to 1/32 of a inch . which is o.k. if you can pick a tength of a m.m.,
But a eyeglass , magnifying specs , strong light (s) etc arnt a bad idea .Easiest to lay out cut grid on formers , Tracing wobles it and
pasteing a photocopy on seems to get it out, nomatter how much cares ensued . So A TASK is to ' parrallellogram ' the bulkheads
and New Blade in the knife , trace cut the angles. And Mind the Fingers with the new blade - as itll go straight though em .
The G 51 turns a dual 11 x 5 Zinger ( 4 blade ) effortlessly , if it comes to it . But the old Como 51 is virtually a last pdp ST 60 cousin
so anticipate itll be fine with a 12 x 5 zinger .The G 40'll fit too , if I go fine pitch ( 4 in . ) seems at 20 knots 4 in is better ,
but as the wings just sheeted LE & capstrips aft of the spar , im not anticipateing its my ' windy weather ' model .
CONSTRUCTIVE criticism & discussion welcomed .
much to do and others on the stove , so it might not be nailed together ill christmass . So dont hold your breath .
Re: P 51
« Reply #5 on: April 07, 2015, 09:13:51 PM »
 Did this start out as a kit? What/who's design?
Re: P 51
« Reply #6 on: April 08, 2015, 06:15:04 AM »
Matt,
The Mustang is a great aircraft to model, Seen the real deal a few times.
I'm glad you have no issues talking about your construction. It's good to share so thanks for that.  H^^
About your "planking?" You said planking right?
How did you cut the planking strips?
I believe you said you used 1/8" thick planking. Could you have used 3/32" thick planking?
Why did you use planking?
I gotta tell ya, I'm really curious about your choice of using planking on your fuselage.  ;D
Have you ever used planking on a CL model before?
Re: P 51
« Reply #7 on: April 08, 2015, 11:10:11 PM »
" Why did you use planking? "
I Tried Ferro Cement moulding , but it was a bit heavy ! .  ;D >:D <=
Welll , . . .
' planking ' is generally something about right , maybe .
The sides are 3 / 32 or suchlike , but the ' curves ' need to be caught . So strips of sheet are nailed on , trimmed to the next ' cut line '
and the next strip added . Three Runs over sides & a 1/4 sheet let in for top . The rear underside needs only one run @ 45 deg .
Lets you capture the curves , carving back at the longitudeinal joins first with 80 / 100 Wt. on a block , or the dreaded coarse file .
as long as it doesnt slip .
Theres a TYPHOON ( More Violent Hurriocane ) in the design section - which youll see how it works .
Planked things five centuries ago. Butt Joined Cliker Built . ;D
SEASONED timbers essential , which is the problem with the grotty sides - though the dope stiffens it up .
the sides were GREEN timber , though thats not the half of it , when wood cracks across the grain or chunks , STORED - it aint quite right . :(
Inteligently done , the 1/8 strip ( these are around 9/16 max - then trimmed to conture ) act as lngitudeinal co joined spars
so is immensly strong / ridgid . Which is the objective. No flexy fliers . Wobbly Wizzbangs were didaianed by even a pre unit Bonneville.
unless it was a 59 .
« Last Edit: April 08, 2015, 11:47:22 PM by Matt Spencer »
Re: P 51
« Reply #8 on: April 08, 2015, 11:17:27 PM »
Re: P 51
« Reply #9 on: April 08, 2015, 11:20:38 PM »
Its designed by Moir ( who's the revolutionary Labour Movement according to wiki , but I thought it was ' Me ' .  :-\)
Ive Got a KIT after Ive cut out all the pieces ! . Free Firtytwo and youd end up holy .  %^@
Re: P 51
« Reply #10 on: April 08, 2015, 11:22:59 PM »
Im at the limit of my whittles electrickerally transfering the pictures , as the pix 500 thingo , so have to do them one per wotsit . IF I can manadge THAT >  n~ >:(
Re: P 51
« Reply #11 on: April 08, 2015, 11:24:38 PM »
Re: P 51
« Reply #12 on: April 08, 2015, 11:25:54 PM »
Re: P 51
« Reply #13 on: April 08, 2015, 11:26:58 PM »
 :P
[BAHG . wont delette .  :(
Re: P 51
« Reply #14 on: April 08, 2015, 11:30:28 PM »
Re: P 51
« Reply #15 on: April 08, 2015, 11:31:52 PM »
Re: P 51
« Reply #16 on: April 11, 2015, 10:17:47 PM »
Re: P 51
« Reply #17 on: April 11, 2015, 10:27:25 PM »
More infernal pictures , after 1/2 hour of . . . .
Re: P 51
« Reply #18 on: April 25, 2015, 10:52:24 PM »
The Cowl , 1/8 ply ' ingress ' , rest dual laminations of 1/ 32 ply over spay can & 1/4 x 3/8 cedar runners , cause they were there .
Re: P 51
« Reply #19 on: April 25, 2015, 10:53:37 PM »
Re: P 51
« Reply #20 on: April 25, 2015, 11:08:30 PM »
How to cheat authoritively .  ;D
Re: P 51
« Reply #21 on: April 25, 2015, 11:24:37 PM »
