  • June 18, 2025, 04:41:36 AM
Author Topic: two part expanding bead foam  (Read 4606 times)
Offline Bob Howard
« on: May 19, 2015, 06:59:37 PM »
Howdy,
I hope this is not a question already covered elsewhere that I just didn't find, so forgive me if it is, but here goes:
Do you remember that two part mix-together foam that came (from Sig I think) in pint cans (or 1/2 pint) cans that you poured together and poured into areas that needed foam to reduce Vibration?  It was kinda dark and took a while to cure as it continued to expand. I used it to pour into the area between the tank compartment and the leading edge, under the nose top sheet and wherever I needed dense foam that would form fit, be light, and lot let go.
Yup, 'can't find any. Does anyone know where to anything like that? The home depot wall insulating foam is not dense enough.
Thanks for the help!
Bob Howard
Offline Mike Keville
Re: two part expanding bead foam
« Reply #1 on: May 19, 2015, 08:03:21 PM »
". . . The home depot wall insulating foam is not dense enough . . ."
Bob Howard
Not sure if this would be the foam you're referring to, but Ace Hardware sells an aerosol foam product named "Great Stuff"...red or black label...one is stiffer than the other.  If this doesn't sound familiar, you may want to go ask an Ace person.  It's in the Paint department.
« Reply #2 on: May 19, 2015, 09:11:51 PM »
Great Stuff reminds me of Gorilla glue if you mist an area with water from a spray bottle, then paint the GG on with a brush.
Rusty
Offline Phil Krankowski
« Reply #3 on: May 19, 2015, 10:29:13 PM »
http://www.westmarine.com/buy/evercoat--two-part-pour-foam-kit-2-quarts--314080
Two cubic feet might be a bit much though...  1:1 mix means you can split it down.  This type of product is used in certain boat hulls as a structural fill and flotation.
Phil
« Reply #4 on: May 19, 2015, 11:25:05 PM »
That's polyurethane, if I remember correctly.  My dad's company used to build lifeboats for the Coast Guard, and used that stuff to fill the gunwales with enough flotation to keep boat and passengers afloat even if it was totally full of water.
The guys would always mix up too much and it would drip out, making these great big green piles of foam that looked like giant alien cow pats.
The West System stuff is probably the same thing.
Offline Bob Howard
« Reply #5 on: May 20, 2015, 09:36:06 AM »
Thanks very much, Gentlemen.
I really appreciate the lead on where to get this kind of foam. I hadn't thought of the marine application and I'll check out that DIY foam and I hadn't checked Ace Hardware, Mike.
I appreciate your help!
Bob
Offline Bob Johnson
  • Lone Eagle Stunt Flyers -Have stooge. will travel.
« Reply #6 on: May 21, 2015, 07:50:59 AM »
Check this out. I use their products at work. Very good stuff. Hope this helps.
www.smooth-on.com/Rigid-and-Flexible/c10/index.html
Bob
Offline Bob Howard
« Reply #7 on: May 21, 2015, 06:23:07 PM »
Very interesting, Bob. The two part foam I used dried hard but was easy to sand or dremel tool off the excess. But it and the other foams suggested here I don't think are flexible or rubbery.
Bob, are you recommending a flexible or more rubbery filler for high stress areas like the wing/fuse area I mentioned?
Thanks!
Bob
« Reply #8 on: May 21, 2015, 08:30:01 PM »
Polyurethane foam comes in all different densities and hardness.
http://www.smooth-on.com/Rigid-and-Flexible/c10_1122/index.html
Phil
Offline Bob Johnson
« Reply #9 on: May 22, 2015, 08:48:21 AM »
I can't say that I'm recommending any of these for the purpose you suggested (I've not used the products in aeromodeling) I was just offering a good source of quality alternative foams that might be useful to dampen vibration. Weight and other considerations might be prohibitive but I'll leave that for you to decide. Sorry for any miscommunication /confusion, I wasn't trying to mislead. I do thing a rigid foam would transfer more vibration than say a rubber type foam, but I could be wrong.
Bob
Offline Bob Howard
« Reply #10 on: May 22, 2015, 10:09:22 AM »
Thanks much, Bob!
« Reply #11 on: May 27, 2015, 10:13:58 AM »
Going totally into useless nit-pick mode (although it may save you some confusion at some point):
Expanded bead foam is the (usually white) stuff that has identifiable beads in it.  They get shipped to the factory as compressed beads (with, I assume, adhesive on the outside), blown into a mold, and then heated.
You're looking for foam, and closed-cell foam* to boot, but not expanded bead.
* Closed-cell foam is foam where the little bubbles haven't popped, so the foam does not absorb water or whatever.  The other kind is like celulose sponges, and I have no clue how you make not-closed-cell foam, or what the proper term is for it (open cell?).
Offline Bob Howard
« Reply #12 on: May 27, 2015, 10:34:07 AM »
Oh that's so right! I was using the wrong term, Tim.
Are the items suggested by Phil and Bob closed-cell?
Thanks, Tim!
Bob
« Reply #13 on: May 27, 2015, 03:29:42 PM »
My father-in-law worked at one of those plants for Dart making foam cups, among other things.  They used super-heated steam to expand, transport, and also fuse the styrene pellets.  No adhesives needed.  I'll admit that I don't know a whole lot more about the process.
Some polyurethane foams are closed cell, but not all.  The floatation foam I linked IS a closed cell product.  Evercoat's website is sparse on information, and I have not personally used the product to tell what the general properties are.
Some of the rigid products are open cell foam, others are closed cell foam.  I would look for products that specify the difference, as well as the density and strength.  I have looked at insulation foam and pourable foam before, both for flotation, insulation, and casting, but have not used it.  I am not sure what product to recommend as the details given are frequently sparse.
Phil
« Reply #14 on: May 27, 2015, 03:31:38 PM »
Hey Bob:
It sounds like Phil knows more about this than me!  All I know is that the stuff I've seen is closed-cell, but I'm pretty sure that it's basically the same stuff as the West Marine flotation foam.
Offline Bob Howard
« Reply #15 on: May 27, 2015, 04:04:26 PM »
Thanks much, Tim. I think I know what to look for.
Bob
