  • July 06, 2025, 11:51:20 AM
Author Topic: OS LA 46 mounting bolt size  (Read 1937 times)
Offline kevin king
« on: January 18, 2022, 01:49:27 AM »
What size bolts are you using to mount the OS La 46? I tried 440 but they seem a little loose on the engine's mounting lugs. Or is that ok?
Re: OS LA 46 mounting bolt size
« Reply #1 on: January 18, 2022, 02:02:35 AM »
The 4-40 screws are plenty. Lots of clamping force.  Four to five in-lbs results in around 240 lbs clamping force per screw as a first approximation.
These are usually called: Screw, Cap, Allen Recess .112-40UNC-3A. That just means .112 nominal OD; 40 threads per inch, which the reciprocal gives .025" per thread; Unified National Standard (60 degree threadform with root radius mods); the class fit is 3, which means not too tight or too loose for easy assembly but good strength; "A" signifies that we are talking about a male thread (bolt or screw) not a "B" female thread (nut)
Of course, I am assuming that we are talking about an engine that has not had the holes drilled out. Stock, they should be about .131" ID.
If you wanted to, you could use the 3mm screws shown in the OS owner's instruction manual. But they are only .006 inches (about two sheets of paper thickness) bigger in diameter. Your choice.
I prefer to do the most accurate job possible locating the holes in the engine bearers, including any engine offset I plan to use. Then I don't have to oversize the holes in the engine to try to get the thrustline trimmed in. Also, when there is a pattern of holes that go together, a machine shop will be given a "true position" tolerance, meaning how much each screw can be off, based on some math and geometry. As you probably intuit, the bigger the clearance holes in the engine lugs, the more tolerance can be alloted to the positional error when you drill the hole in the engine bearer. These numbers are directly related--or else it may not go together. The good news is that the OS tolerances for position error are going to be very small, so you can use up nearly all of the assembly clearance for drilling your holes in the bearers, or for some slop so you can shift the engine around a tiny bit for spinner fit (uniform gap) or thrustline adjustments.
You are using the bolts to clamp the engine lug down to the mount and the preload creates sufficient friction to avoid slipping. Bolts are not used to carry shear loads. Pins are used for that when it counts. So pins use a very close fit to the holes on both sides of the joint, often times even a press fit on one or both sides. But we don't need that on model engines.
Something to keep in mind is that when you torque a screw down, you are both stretching the screw and compressing the stack of materials between the screw head and the nut. (Equal and opposite forces.) If you are using wood bearers, the stiffness of the joint is dominated by the much less stiff wood. (Lower elastic modulus than the steel screw.) So, if you want a stronger installation with less loosening, etc. fix the bearer design, don't keep upsizing the screws!
A good way to stiffen up a wood joint and keep things from progressively loosening is to thread and glue in a steel or titanium threaded insert into your bearers. This is done on some racing models and works very well--but it is extra work. And, with good eastern maple or birch engine mounts you don't risk too much crushing if you keep the torque to reasonable numbers.
Generally, you want the nut to be of a softer material than the screw so that it micro-yields to cause load-sharing between all of the engaged threads. Remember, the bolt is stretching, and you don't want only the very first thread in the nut to carry all the load--because it won't. In a practical sense, any hardware you are going to buy has all of this engineering already baked into it. You do want a minimum of around five threads engaged to carry the load reliably. If everything was perfect (yada, yada, yada), then three threads would develop enough strength, but....
« Last Edit: January 18, 2022, 02:38:15 AM by Dave Hull »
« Reply #2 on: January 18, 2022, 11:18:56 AM »
   4-40. They are plenty strong enough, and while they don't exactly fit the holes, you have to be practical about it. You can't easily get blind nuts in anything but 4-40 and 6-32, you don't want to be out in the middle of nowhere looking for spare 3.5x.6 screws at a hardware store. 6-32 is excessively strong, far more than necessary, and if you try to drill a clearance hole for it in 3/8x1/2 maple, you cut away a large fraction of the strength and it's too close to the edge.
    The screws will not hold it in alignment perfectly due to the slop, but that is not the end of the world. If you need perfect alignment, drill you own holes for  dowel pin, or make a sleeve for shoulder bolts - making sure the shouulder does not get all the way through the lug, so it still clamps. DO use a stiff aluminum plate to spread the load on the mounts.
   I use 4-40s on everything, crank down on them with ball drivers, and it's proven plenty adequate over the years. I get the screws snugged up, then move the engine with the spinner and prop aligned with the nose ring by eye/feel, and that has also proven plenty good enough.
Offline Reptoid
« Reply #3 on: January 18, 2022, 01:07:06 PM »
During my younger years I always used 4-40's to mount almost everything (#2-56 or #3-48 for 1/2A) because that's what was available in Hobby Shops and some hardware stores and it worked fine. Of course, that's when there were numerous local hobby shops and most of the engines I was using were made in the USA. Fast forward to later years or to current times and that's no longer the case. I fly a lot of F2D combat planes and some High performance 1/2A and they are all drilled for 3mm mounting bolts and use 3mm or 2.5mm screws in the engine (some have no screws in the engine). Most of the items we use come from Ukraine , Russia, or European distributors and can't be sourced at a local shop. In fact local hobby shops are almost extinct or don't carry u-control items. The aluminum motor mounts we use are also tapped for 3mm bolts so I now use almost all metric hardware. Here are a couple of very good sources for metric (and US) fasteners. They stock everything you need for hardware; Socket screws, nuts, locknuts, washers, Blind nuts (t-nuts), etc.
https://www.boltdepot.com/catalog.aspx?gclid=CKulkdia0dECFQ9rfgodmgECdw
https://www.fastener-express.com/
       Don
       AMA # 3882
Offline kevin king
« Reply #4 on: January 18, 2022, 01:13:35 PM »
 Wow! Great answers. Thank you Dave and Brett & Reptoid. I'm glad you guys are in the hobby, willing to share your expertise and help others.
Thank you!
Kevin.
Offline kevin king
« Reply #5 on: January 19, 2022, 02:10:40 AM »
Thank you Motorman👍
« Reply #6 on: January 19, 2022, 08:31:00 AM »
   I also use 4-40 for just about everything up to ST.60s. Another reason for using this size is that they will shear in a head on crash and perhaps save you an engine as long as there is some room behind the engine for it to slide in the mounts. Early on in my stunt career I crashed my latest world beater straight into the pavement. The airplane exploded into balsa confetti and I thought the engine was gonna be kibbles and bits. I picked up the little slab of balsa that was the nose and saw that the mounting bolts had sheared because the engine had enough room behind it to slide back on impact, and then the maple motor mounts took the biggest brunt of the impact forces. I have tried to replicate that on every airplane I have built since and have not had to test the theory again but I feel confident that it will repeat itself.
