  • June 21, 2025, 08:33:33 PM
Author Topic: Scroll Saw recommendations  (Read 2409 times)
Offline Douglas Ames
« on: August 08, 2012, 06:37:40 PM »
I'm in the market for a table top Scroll Saw and was astounded by the variances in price for what essentially is the same saw, made in the same country - China.
Brand name doesn't mean much anymore to me but quality does. Dewalt, Craftsman, Delta are pricey but how does Harbor Freight (Central Machinery) compare?
eBay is full of used but the shipping will kill any "deal" you might get, not to mention missing parts. Another option would be the local  Craigslist.
Any recommendations? I would really like a variable speed model.
Thanx, Doug
AMA 656546
Offline Leester
Re: Scroll Saw recommendations
« Reply #1 on: August 08, 2012, 07:33:06 PM »
I bought a reconditioned Dremell through www.cpooutlets.com They only show a Ryobi and a Skill available now. They usually have cheap shipping. I've also dealt with www.grizzly.com  shipping was 17.00  Best I can say is shop on line and try for the best deal you can. Harbor frieght is ok, I've never had problems with things I've bought.
Leester
ama 830538
« Reply #2 on: August 08, 2012, 07:51:52 PM »
Micromark has the discontinued Dremel saw, which is what you need for stunt ships.
http://www.micromark.com/
« Reply #3 on: August 08, 2012, 08:09:49 PM »
Mine is an old, all metal Delta. Works fine though I don't use it all that often. I have a 10" Delta band saw that gets a lot more use.
Offline Dick Pacini
« Reply #4 on: August 09, 2012, 10:09:45 AM »
I also bought the reconditioned Dremel saw.  It's very heavy, but will walk off the bench if not bolted down.
AMA 62221
« Reply #5 on: August 09, 2012, 02:37:33 PM »
I'll buy top quality blades but I don't need a $700 scroll saw. I'll check out HF and Steve's Wholesale here in Tulsa.
Thanks.
AMA 656546
« Reply #6 on: August 09, 2012, 03:19:28 PM »
I think any of the current models out there re OK.  There are usually quality differences that go along with the price- things like. Table that tilts both ways, variable speed, quality off the hardware like the table tilt bracket, etc.
I'd look for model that uses blade clamps, not pinned blades, cast iron or aluminum table and frame, and at least a 16 in. throat, and variable speed.
E
I have an old craftsman like that.  It can take pieces of standard hack saw blades and cut 3/4 in. Maple or go to any of the specialized blades for lighter cuts in thinner materials-.
Offline Leester
« Reply #7 on: August 09, 2012, 04:38:15 PM »
There's lots of 100.00-150.00 scroll saws on those web sites, I wouldn't buy a 700.00 one either. Any scroll saw will walk if not bolted down, I spent about 30.00 and made a portable stand with locking wheels....works great !!
Leester
ama 830538
steven yampolsky
« Reply #8 on: August 09, 2012, 04:38:37 PM »
When looking for a table scroll saw, there are several important features to consider:
1) Construction materials. Like any shop too, cheap models skimp on materials which result in warps and increased vibration. Unlike, saws, lathes or drills, table scroll saws are particularly prone to vibrate so quality(and heft) of materials used is particularly important.
2) Open/Closed casing. Entry level(read cheap) scroll saw are open so that the dust just falls down to the floor. This design has two issues: balsa dust just flows everywhere and difficulties with mounting the saw on a solid surface(dust falls right under the saw and eventually getting into the mechanics. The more expensive(and much better) design encloses the bottom portion of the saw and allows for hookup of a vacuum.
3) Tilting. Ability to tilt the blade/table is not really required for our needs. That said, table tilting is common but just like any other shop tools, if you till the table instead of the blade, you will end up with surface which is very hard to get perpendicular to the blade. It is better to find a model with a tilting blade instead. Of course, tilting head scroll saws are more expensive.
If you want a good table saw, Excalibur is excellent but somewhat pricey. Like everything in life, you get what you pay for. It has a port for a vacuum cleaner, tilting head(no the table) and of extremely sturdy, vibration isolating construction.This scroll saw is amazing. Cutting with it is just plane awesome.
http://www.amazon.com/Excalibur-Scroll-Saw-16-inch/dp/B004BG13FK/ref=pd_cp_hi_3
If $600 is a bit much, you can always go for Harbor Freight model($80). Yes, it's cheap, vibrates like crazy and won't stand up to regular usage but if you plan to use it occasionally(once a week for example), it will be enough. That said, these things are almost impossible to use to cut soft and thin balsa sheets(think ribs). you'll have to cut far away from the cut line and then finish by hand.
http://www.harborfreight.com/garage-shop/stationary-scroll-saw/16-inch-variable-speed-scroll-saw-93012.html
ShopFox makes a nice intermediate saw with dust enclosure and tilting table which is a copy of Dremel one with a few updates:
http://www.amazon.com/Shop-Fox-W1713-16-Inch-Variable/dp/B001R23T08/ref=sr_1_6?s=hi&ie=UTF8&qid=1344551510&sr=1-6&keywords=table+scroll+saw
DeWalt also sells a good one but I've never actually seen or used it.
Online Howard Rush
« Reply #9 on: August 09, 2012, 05:15:39 PM »
I got me a DeWalt.  I don't know how it compares with the others, but it's a whole lot more wonderful than my old Dremel.
Offline Dick Pacini
« Reply #10 on: August 09, 2012, 05:19:02 PM »
The reconditioned Dremel saw I bought is very heavy and vibrates as you increase speed and starts walking.
My old Dremel saw from the early '70s was very light, had a power take off and only one speed, but it stayed put.
AMA 62221
Offline scott matthews
« Reply #11 on: August 09, 2012, 05:32:56 PM »
I bought a Porter Cable saw at Lowes and it has all the features you need ( tilting table,variable speed, work light, vacuum hose port,And able to use pin blades or clamp on non pin blades). This cost me $170.00 a little pricey but should last a life time, check out Lowe's web site.
« Reply #12 on: August 10, 2012, 09:08:42 AM »
I guess my old Dremel scroll saw is getting old as I have to clamp it down to keep it in one spot.   Wife bought it as a Christmas present when we were first married.   Hate to think how much stuff it has cut.  But, saws are like any thing else,  how much money do you want to spend.   Went to a wood working show and the guy was do demo's on table saws.  Brand new table saws out of the box and could not get accurate cuts.   He stated 99% of the table saws are like that no matter how much you spend.  He showed us the several he had aquired over the years and were very great machines once set up.  Anyway he was selling the alignment tool for table saws, scroll saws and band saws.   Took the tool home and did the adjustment to my Shop-Mate and the Dremel.   Amazing much easiter it is to get accurate cuts.
« Reply #13 on: August 10, 2012, 03:46:33 PM »
Exactly Doc,
In todays world of sold off brand names and cheap imports I want to spend my money wisely and only once!
My 10" Delta table saw is good for rough cuts and my mini 4" table saw won't cut 1/2" hard maple.
AMA 656546
Offline dave siegler
  • sport flier
    • Circlemasters Flying club
« Reply #14 on: August 10, 2012, 07:00:36 PM »
There are 3 kinds of scroll saws, you want one of the parallel arm type.  If it has a spring tension or a C frame type, I would stay away.
Also look for one that will take both pin end and plane end blades.
Also look how easy it is to change blades, you need to change blades often per material and only the bottom 1/2 inch gets used.  Sanding belts are a nice option as well
next is throat depth.  I use mine for cutting out profile blanks, and my 16 inch isn't big enough.  Deeper is better.
Variable speed is a huge advantage, then you can cut metal and plastic with the right blade.
The mid priced dremel, delta and riobie saws are good, they look to me like they are made in the same place.  The Dewalt is an overkill for our use.  Compared to scroll sawyers, we cut straight lines.  Big wide blades wander less.  I would also look for an old 22" craftsman, delta grizzly.
I use mine often, but less since I have a table top band saw, and even less since I found a dremmel table saw.    It still does cuts that nothing in my shop will do like aluminum plate, inside cuts and plastic.
Dave Siegler
NE9N extra class
AMA 720731
Offline Bill Heher
  • Fix-it
« Reply #15 on: August 10, 2012, 08:37:36 PM »
got a 20 yr old Delta at yard sale,had to pay $50 -but 10yrs later it still works like new.
I have to agree with some othershere,a table top band saw will get  more use. Stacks of ribs, sheet tail surfaces,profile fuse blanks are no problem. For inside cuts a Dremeltool can do most ribs and former cutouts, or a simple coping saw and a starter hole.
Bill Heher
If it's broke Fix-it
