  • June 19, 2025, 09:59:04 AM
Author Topic: Repairing open bay  (Read 935 times)
Offline James Mills
Repairing open bay
« on: July 06, 2008, 10:46:27 PM »
I am sanding out a coat of primer and managed to cut through an edge and opened up a bay (covered with polyspan).  Should I cover that bay with silkspan to repair since it is just one bay or use poly again shrink with heat gun?
James
AMA 491167
Offline Patrick Rowan
Re: Repairing open bay
« Reply #1 on: July 06, 2008, 10:53:07 PM »
When this happened to me I used silkspan for the patch.
Fly Stunt
75750
Poland, Ohio
Offline Bootlegger
« Reply #2 on: July 07, 2008, 08:33:30 AM »
 :!  A pal put me onto a way to help hide silkspan patches some time ago, I tried it and it works well. Instead of cutting your 'span tear ir on all 4 sides, wet and stick down, then some dope on the edges, let dry and finish.
 It will be hard to spot the patch with when finished as the torn edges feather in with the original finish.  Good luck... D>K
8th Air Force Veteran
Gil Causey
AMA# 6964
« Reply #3 on: July 07, 2008, 11:37:55 AM »
I do that with all silkspan. Tear the edges, that is. As Gil notes, it makes them disappear.
